Old 10-30-2019, 05:34 PM #1
Beansworth Beansworth is offline
Beansworth is on a distinguished road
Recently installed a switch for an LED bar, now I have no gear/HVAC/radio lights.
Hopefully someone here can help with my problem:
I recently installed a CH4X4 switch (same wiring as an AOB) so I can turn on my led bar. I did the normal hook-ups: ran a wire to a bolt for the ground, add-a-fuse from an "ignition on only" slot for power and hooked the correct wire to the LED bar relay. The switch works fine and lights up when pressed on.
The problem came when I tried to hook the switch wire to give illumination when the switch is in the off position and my headlights are on. To do this, I t-tapped into the green wire coming from the wiper de-icer switch. Every time I tried to hook the switch up to the tap, it would blow my 7.5A panel fuse.
Not knowing why this was, I very stupidly just increased the fuse size to 15A. I probably shouldn't have done this! I've since put a 7.5A fuse back into the panel slot, but the damage is done.
My lights for the gear shifter, HVAC knobs, and radio side buttons no longer turn on when I turn my headlights on! I've checked all fuses (both cabin and engine boxes) and all are fine. My tail lights still turn on. It's also not the dimmer switch, I've checked it and it still correctly dims my gauges.
I fear that I shorted the backlight harness and damaged something important, does anyone know what happened or how I can fix this?
Thanks in advance! You guys are the most helpful online forum I've ever seen... keep being awesome!
Beansworth is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 06:00 PM #2
Originally Posted by Hindsight View Post
Recheck all fuses.
Thanks for the response, but I already did that (please check original post). All fuses are fine.
Old 10-30-2019, 06:42 PM #3
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Better start sniffing for burnt stuff.
Not sure if this helps don't have time to go through the whole diagram.
http://www.toyota-4runner.org/attach...2-4runner-.pdf
But find where that green wire goes and have at it.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 06:50 PM #4
I wouldn't have messed with the wiper circuit for illum. I wouldn't have increased a 7.5A to a 15A fuse. There's a reason they spec them.
Your username is very appropriate!
To be clear, I didn't use the actual wiper circuit, I used the wiper de-icer switch circuit. If you look around on this forum, you'll notice that this is actually a very common place to tap into.
Old 10-30-2019, 07:11 PM #5
Thanks for the help, but this appears to be specifically for the cabin lights, such as dome, map, etc. It doesn't detail the console button/knob backlights.
Old 10-30-2019, 07:30 PM #6
I'm going to have to look more I think I got a 4R wiring on my home computer.
2018 TRD OFF ROAD
My Build
Old 10-31-2019, 01:40 AM #7
Deep_palancar's Avatar
Deep_palancar Deep_palancar is offline
Deep_palancar will become famous soon enough
Here are the wiring diagrams
Attached are all of the diagrams that you should need to trace the path for the illumination wires.
As you will see there are a lot of bridges on the back panel of junction boxes 4 and 5 that interconnect to the different switch and knob lighting. With a multi-meter or test light with a pin probe you can track the power from the panel fuse pin 40 of connector 2B through to where it breaks.
If you are not familiar with reading these diagrams but have the time, equipment, and interest, I or others here can explain most of it.
As far as what went wrong, the symptoms indicate that the wire from the tapped green @ the deice was somehow providing a direct path to ground either by a rub, cut, or the wrong pin on the add-on switch. Fix one problem at a time....
Deep_palancar is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 02:04 AM #8
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
Yikes. In the future, keep in mind that any time you snap fuses that quickly, it's because you've connected +12V directly to a ground. Recheck your switch wiring, the instructions OR your pin-out leads may be incorrect. Not to beat a dead horse, but a tiny LED light in the switch should only pull a few milliamps - not enough to merit bumping up fuse size.
You should consider yourself lucky. There's a thread on here of someone incorrectly tapping into the switch dimming circuit and smoking his instrument cluster.
Good luck with sorting the problem.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 09:18 AM #9
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
Tail lights working? That is where panel fuse gets power from
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 06:13 PM #10
Wow, this is great. Gonna take some time to poor through this. Thanks!
Yeah they work, which is another reason why it doesn't seem like a blown fuse.
fuse , lights , switch , turn , wire
I recently installed ebay headlamps they look great but I need more brightness bassmacka 4th Gen T4Rs 6 07-06-2017 06:03 PM
Recently installed lift, question about diff drop Want24Wheel 3rd gen T4Rs 5 07-10-2015 11:09 PM
LED daytine running lights. Anyone done this recently opticsguy 4th Gen T4Rs 6 08-24-2012 02:04 PM
PIAA Lights with Tacoma Switch Finally Installed ts9790147 4th Gen T4Rs 24 07-10-2011 08:21 AM
Installed new radio now dashboard lights aren't working Deputy1211 3rd gen T4Rs 4 08-21-2010 11:52 PM
