Old 10-31-2019, 07:21 AM #1
hogwild86 hogwild86 is offline
hogwild86 is on a distinguished road
Driving with a flat-Replace or Good to Go?
Yesterday I had the pleasure of seeing the low pressure tire sensor appear starting the 4runner....Thought nothing of it due to it finally getting cold in my neck of the woods and drove 60-70 mph for 20 min to come back and see I was running on 10 psi and a flat....
Noticed a screw in the wheel, pumped the wheel back up to 34 psi to take it to the tire store and have the screw removed/tire patched.
They did not indicate that I needed a new tire, but seemed awfully rushed. How can I tell if there was any damage done re-inflating the tire with the screw in it/driving it at those speeds with such low psi? Not sure if I need to replace or roll with the patched tire now.
hogwild86 is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 07:27 AM #2
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
You would have needed to see the inside of the tire to tell for sure. That is assuming no obvious signs of damage on the outside. Often times tires ran low on pressure will chew up from the inside with no signs of damage on the outside. That being said it’s usually lower pressures than your talking but every tire is different. What kind of tire ? How many ply side wall? These are definitely going to play a role. But in a nutshell without a proper inspection no one can tell you anything.
Arnezie is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 07:29 AM #3
Nitto Terra Grappler G2 All-Terrain tires
Old 10-31-2019, 10:52 AM #4
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Did they dismount the tire and do a plug/patch the proper way?
As long as the nail/screw wasn't within an inch or so of the sidewall, plugging is totally fine and will last the rest of the life of the tire.
Check the sidewall of the tire and see if there is a ring the entire way around. If there is, I would replace. This ring happens when the tire is driven on when flat, and basically destroys the sidewall from the inside of the tire.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 10:57 AM #5
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
most tire shops will try to sell you a new tire if there is even any question of it being an issue.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 11:06 AM #6
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
That tire is unsafe you chewed up the tire inside so the side wall will not be able to withstand the heat generated on the highway
Mike
Mudballz is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 11:40 AM #7
pDubs's Avatar
pDubs's Avatar
Mike
I was posting that picture as an example for him to check. That's not his tire....
2014 SR5P
Old 10-31-2019, 11:57 AM #8
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
The problem is that nobody knows. Short of x-raying the tire, there is no way of determining what damage was done internally to the tire. A visual check (inside or outside) won't tell you anything.
How many miles are on the tires? I'd certainly replace that one and (unless the tires were near new) at least the other one on that axle.
That tire could be a catastrophic failure waiting to happen. There is no way to tell.
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 02:41 PM #9
4Reak Show's Avatar
4Reak Show's Avatar
I drove on a flat BF mud terrain which is a load C but supposed to be strong as shit. Tire guys looked at it and it was toast. I did less than 5 miles. But it was also FLAT flat. Zero psi.
Dust on the right is rubber being chewed up.
Here's the metal I picked up.
Bottom line: I wouldn't chance it. Sucks, but not worth the risk. If you don't already have a full sized spare, get 2 new ones for that axle and mount the remaining good tire on the spare rim. Then you have a good full size spare also. And keeps tire rotations a little more easy to follow.
Old 10-31-2019, 02:42 PM #10
Mudballz's Avatar
Mudballz's Avatar
Is your life of you and yours worth a tire.???
I wouldn’t take that chance sorry
Mike
back , low , psi , screw , tire
Lift with good handling? - Mountain driving willo 5th gen T4Rs 33 10-01-2018 12:20 PM
CarID Replace bumper parts any good Crashnrondo 3rd gen T4Rs 4 01-17-2014 07:25 PM
Driving Playlists (good songs only) carter316 Engines / Suspension / Wheels / Tires / Audio / Accessories 31 09-10-2012 11:09 AM
Driving Lights - Which are Good ? heavydm Engines / Suspension / Wheels / Tires / Audio / Accessories 2 12-08-2008 04:26 PM
88 4runner driving not so good linuxgeek Classic T4Rs 13 04-19-2005 12:07 PM
