11-01-2019, 10:11 AM
need all weather tires: 2019 limited
Need advice.
Want some good quality all weather tires for my 2019 4 runner limited.
Year round use.
The snow flake rating is required in some parts of BC where I live.
I do not need aggressive quasie off road tires.
I considered buying 18" rims, winter tires, and doing the swap 2x per year.
2 tire dealers advised no due to recalibration requirements each time
Stock tires are 245/60/R20
Looked on line and found they are supposed to be 31.5" diameter.
I looked at some Michelin all weathers in a size close to mine.
But they do not give the diameter on the website.
advice please...
Reason: typo
11-01-2019, 10:21 AM
have you looked at tirerack.com? i would suggest starting there since they have recommendations and do reviews on tires.
What is an Unlimited?
11-01-2019, 10:26 AM
Originally Posted by 4runnerinbc
Need advice.
Want some good quality all weather tires for my 2019 4 runner unlimited.
Year round use.
advice please...
Had the same thoughts recently, decided to just go with another set of new OEM Rims (TRD OR). Was able to pick them up for $650 I thought that was decent, and just had the Michelin X Ice 2's put on them with aftermarket sensors at $50 each.
So total out with taxes I'm into that for almost 2K but I know the benefit of dedicated winter tires for sure. You may not need them in your parts. Not sure if you have Active Green & Ross out there but that place matched every other place I checked in the GTA. & sensor calibration literally takes 5 mins.
Guy told me to just wheel back in when I put them on no appointment required. Free puncture repairs there too and the Michelin's have a 60K warranty. Going to replace my stock Dueller tires next year as well I think, they ain't so hot.
Seems there is always a set of these somewhere on Kijiji: https://www.kijiji.ca/v-tires-rims/b...6292?undefined
2017 TRD OR / KDSS / Canuckistan Edition
11-01-2019, 10:52 AM
Real Name: Paul
Real Name: Paul
I put a set of Goodyear WeatherReady tires on my wife's 2018 Crosstrek and they are an excellence tire. In the winter driving the tires completely changed the handling to what an AWD should be. Also summer driving the tires were quiet and comfortable. I see they make a 255/55/20 which is only slightly smaller than OEM.
Goodyear Assurance WeatherReady Tires | Performance Truck All-Season Tires | Discount Tire Direct
2016 Trail MGM. P265 70/17 Falken Wildpeak AT3W. Matte Black TRD Wheels. Leveled with 2" spacer. Heated Front Seats. All LED interior. Mud flaps deleted. TRD Air & Oil Filter. TRD Oil Cap. FJC Shifter. Subaru Kicker tweeters. Hikari LED Low Beam. Cougar Motor LED DRL/High beam. Hood "scoop" and lower door wrap.
2006 SR5 4WD V6 - Owned from July 2009 with 38,200 miles to March 2017 with 150,100 miles.
11-01-2019, 10:54 AM
FYI, you have a Limited, not Unlimited, unless you have a Wrangler.
Not sure what they mean by re calibration. There shouldn't be any reason why you can't just get a second set of wheels and throw snow tires on.
2012 Shoreline Blue TE
11-01-2019, 11:07 AM
Michelins M/S are highly recommended.
2017 TRDORP White | 275 KO2 on Stock Rims | Stock Stereo with JBL GX302/GTO638/938, Kenwood KSC-SW11 | DDM 35W HID Ultra | Shrockworks Step Sliders | FR 5100s @1.75 RR Daystar 1.5 | Victory 4x4 Rack
11-01-2019, 11:51 AM
what re-calibration are they talking about?
11-01-2019, 12:17 PM
I believe that would be the TPMS.
11-01-2019, 01:08 PM
Yeah I presumed you can't have 8 programmed into the vehicle? ( 4 OEM and 4 aftermarket ). And since I had the rims in boxes and they were not going on the truck yet I presumed you can't program 4 new ones while the OEM's are on there either hence why I have to go back to the shop for 5 mins while they program the winter ones.
Now since they are aftermarket I'm also presuming in Spring I have to return for another 5 mins when the OEM's go back on as the system won't be looking for those... not a big deal it's not like there's a charge in fact they would do all the swaps for free since I bought the tires there I just like to do it myself as well as rotations and such.
11-01-2019, 04:57 PM
After running two Canadian winters on my Michelin Premier LTX 245/60R20 Michelin Premier all-season tires (20" Limited rims), I began searching for a second set of OEM alloy rims last summer (2018) to run a set of dedicated winters.
I found some 2018 TRD Off-Road take-off rims with very low mileage at a reasonable price, and then installed Toyo Observe GSi-5 265/70R17 winter tires. Fit perfectly on my 2011 Limited.
The Toyos did a very good job up here in Northern Ontario.
Having a second set of rims removes some of the hassle associated with the seasonal changeovers with only one set of rims. The winter rims may take a beating (corrosion!) if road salt is used on your BC roads. That is why I decided not to run steelies - they rust far too quickly here in Northern Ontario.
I also did not put TPMS sensors in the winter tire/rims. I do not get any low tire pressure warning lights on the dash because the Limited has a sensor in the spare tire. All I have to do is manually check the tire pressures every week or two.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
11-01-2019, 09:14 PM
First thing I did when I bought my limited was to ditch the 20" wheels and go with 17"s - just saying...
I run Cooper AT3 4S and they are snowflake rated and awesome year around..
2014 4Runner Limited - Barcelona Red
LFD Offroad 3/4 Roof Rack, Eibach Pro-Truck suspension kit, TE rocker conversion, OEM running boards from a TRD OR, 17x8 -10 FN Countersteer Type-X wheels, Cooper AT3 4S tires 265/70-17.
11-01-2019, 09:31 PM
2015 4Runner Limited with X-REAS Sport Enhancement Suspension, 37qt ARB fridge wired directly to battery with ARB Wiring Kit.
11-01-2019, 09:56 PM
I vé had yokohama geolander AT's for the past 3 seasons and they have been fantastic. They did really well in the last snow storm when we had 300 accidents in Colorado. I go sking up the slope and have never had any issues or lack of confidence in these tires.
11-02-2019, 03:00 PM
Or do what I do. I just use a regular valve stem on my KO2 tires (no tpms) and put a small piece of electrical tape over the light on the dash.
11-02-2019, 09:08 PM
Real Name: Justin
Real Name: Justin
@ 4runnerinbc
A lot of the Canucks on mud and the GX forum run Nokian either as their dedicated winter tires or the all weather version. The leafs that run a dedicated winter tire are mainly running the Nokian Hakkapeliitta. I haven't seen any negative reviews for that specific tire.
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
