Old 11-02-2019, 10:38 PM #1
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
FJ Cruiser shift knob - No cutting or trimming!
Instead of trimming the shaft or taking off the bottom piece of the shift knob, I simply inserted a socket set screw into the shift knob prior to install. It gives just enough space to clear the side of bezel/console when shifting out of park. I used socket set screws, metric M8 x 1.25 x 10mm purchased from our local hardware store. Cost under $2.00 for 2pcs. (only 1 required for this mod, allen keys not included).
FJ Cruiser shift knob - No cutting or trimming!-20191102_191445_resized-jpg
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 12:09 AM #2
zonzin's Avatar
zonzin zonzin is offline
zonzin has a spectacular aura about zonzin has a spectacular aura about
zonzin's Avatar
I just recieved my FJ shift knob and installed without spagers or cutting and do not see an issue with the fit or clearance. It's gtg as is. Am I missing something?
zonzin is offline   Reply With QuoteReply With Quote
Old 11-10-2019, 12:15 AM #3
The issue is when you shift out of park. The bottom of the shift knob hits/rubs against the bezel/console.
Old 11-10-2019, 09:03 PM #4
zonzin's Avatar
zonzin's Avatar
Hmm,, I have about 1 mm of clearance.
Old 11-10-2019, 10:19 PM #5
Nice! You seem to be the exception as there are posts about having to trim the shaft and or removing the bottom piece to prevent hitting the console.
Old 11-11-2019, 08:35 AM #6
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough
Real Name: Jason
I went with a 6mm set screw. I’m guessing anything longer than 3mm would suffice.
Thanks @emmantik
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 12:48 PM #7
bane bane is offline
bane is on a distinguished road
Same here. I just threaded it on, no spacer no cutting needed.
2012 SR5 4x4 Magnetic Gray, Third Row, Cooper Discoverer AT3 LT 265/70/17 load range C, Bilstein 5100s at 0.85, Husky Weather Beaters and Mud Flaps, Front Air Dam Removed, Canvasback Cargo Liners
Former Tacoma Owner https://flic.kr/p/s1m3mS
bane is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 12:57 PM #8
zw470's Avatar
zw470 zw470 is offline
zw470 has a spectacular aura about zw470 has a spectacular aura about zw470 has a spectacular aura about
zw470's Avatar
Mine fit with no modifications. Just unscrewed the old knob and rescrewed the new knob.
zw470 is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 12:51 AM #9
zonzin's Avatar
zonzin's Avatar
It's definitely cooler looking and just the right height to rest my hand on from the center console while driving.
Old 11-13-2019, 01:39 AM #10
adrummingdude's Avatar
adrummingdude adrummingdude is offline
adrummingdude will become famous soon enough
I've thought about getting one of these, even though my Pro came with a TRD shift knob...which is quite homely. Really, if the TRD is the "fancy" one I'd hate to see the regular. It looks like it'd be more at home in a Sienna minivan.
2020 TRD PRO - Morimoto 2 stroke LED's - KC flex pillar pods - Rigid rack pods - Goal Zero 100w panel/ Yeti 200X - Rago MOLLE panels and shelf - Thule cargo box - Gobi Ladder - Rotopax
adrummingdude is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 04:48 PM #11
PaulB-2006 T4R's Avatar
PaulB-2006 T4R PaulB-2006 T4R is offline
Real Name: Paul
PaulB-2006 T4R will become famous soon enough
Real Name: Paul
If you do take off the TRD shift knob you will lose HPs.
If you get a FJC shift knob, there are enough people out there to buy your TRD shifter you could make enough to buy beer!
BTW I had to my FJC shift knob, I used a mitre saw and still have not found the shrapnel after it shot off the blade.
2016 Trail MGM. P265 70/17 Falken Wildpeak AT3W. Matte Black TRD Wheels. Leveled with 2" spacer. Heated Front Seats. All LED interior. Mud flaps deleted. TRD Air & Oil Filter. TRD Oil Cap. FJC Shifter. Subaru Kicker tweeters. Hikari LED Low Beam. Cougar Motor LED DRL/High beam. Hood "scoop" and lower door wrap.
2006 SR5 4WD V6 - Owned from July 2009 with 38,200 miles to March 2017 with 150,100 miles.
PaulB-2006 T4R is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 07:38 PM #12
Smitty19TRD Smitty19TRD is offline
Smitty19TRD will become famous soon enough
I used a 6 mm set screw on mine as well. Only needed 1-2 mm but 6 is what they had at the store and it worked perfect.
Smitty19TRD is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 09:54 PM #13
RockyM's Avatar
RockyM RockyM is offline
RockyM is on a distinguished road
RockyM's Avatar
All this yakking and no pic of the shift knob?
RockyM is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 12:31 AM #14
zw470's Avatar
zw470's Avatar
You gotta go for the matching t-case knob, too.
Old 11-24-2019, 08:07 PM #15
RockyM's Avatar
RockyM's Avatar
Now that's what I'm talking about
These do look good.
knob , set , shift , socket , trimming
How To: Trimming/Cutting Fenders Troymclure 4th Gen T4Rs 13 06-30-2022 02:36 AM
FJ Cruiser Shift Knob mod Todbld 5th gen T4Rs 15 05-24-2021 10:29 PM
FJ Cruiser Shift Knob ? Emman 4th Gen T4Rs 10 09-27-2020 05:26 PM
SOLD: FJ Cruiser Shift Knob Modded to fit 5th Gen T4R, $45 shipped, Denver, CO FatGopher For Sale: T4R Items 0 04-21-2019 01:53 PM
FJ Cruiser Transfer case shift Knob SIKHILUXSURF 3rd gen T4Rs 7 01-05-2011 10:33 AM
