06-10-2020, 11:59 PM
#16
Originally Posted by Dreaddy72
I have been researching kits and decided on the ironman stage 2 nitro shock kit as well. I have 33in tires and they said I would have no problem bumping up the front to 3in using their forged UCA's. I would like to see some more pics when more people have that kit installed.
I preordered my kit, i should have it in a couple weeks. From what I have seen so far it looks like some people with that kit can go above 3 inches.
Why go above 3? Cv angles could be rough and youd lose alot of down travel
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
06-11-2020, 12:46 AM
#17
No I'm not trying to go above 3, it's just that I'm at 3 now with my readylift spacers and I have 33in tires that, after minor trimming, dont rub. I just dont want to upgrade my suspension and be stuck with a 2in lift and have to deal with rubbing is all. My measurement up front is just over 38in from ground to fender and would like to keep it around there.
I almost went with a OME/Bilstein combo, but with Ironman I get uca's and I save a bunch of $ with what seems to be a solid product with a 3yr warranty.
06-11-2020, 01:18 AM
#18
Exactly what I was considering too. My Nitro kit with performance springs should be here soon. If it helps anyone, below are my current center hub to fender measurements:
DF 19.5
PF 19.875
DR 21.625
PR 21.75
After conversation with several Ironman gents, I confirmed T4R springs are same length, not L/R specific. I’m having them preassemble my coils with one 5mm spacer on DF that should equate to 10mm (.4”) to level the front.
Estimate for a stock TRD ORP with sliders is that performance springs should give me 2.5” lift. If all goes to plan, I hope for 2.9” DF and 2.5” on the rest.
Forged UCA’s combined with my OEM wheels should yield good clearance for 285’s. I will report back as it comes together.
2023 TRD OR, Lunar Rock
06-11-2020, 04:37 PM
#19
Need a little clarification on the spring ratings. I noticed for the front springs constant load is rated up to 220lbs, currently with bumper, skids, sliders and various accessories im pushing an additional 430+lbs overstock. Will the constant load in the front be sufficient? As for the rear I dont have much weight (less that 660lbs+ the constant load calls for). In this instance would it be best to have constant load springs in the front and performance springs in the rear?
Cheers!
06-11-2020, 05:58 PM
#20
Cheers!
You can email them or get on their live chat they are super helpful. But you can mix and match the coils between front and rear depending on what you are running.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
06-11-2020, 07:15 PM
#21
Awesome thank you! Ill reach out to them
Cheers!
06-12-2020, 05:46 PM
#22
Got it back from alignment today. Here are the numbers and the recommended numbers from Ironman.
Untitled by redrunner87, on Flickr
5th Gen Build
06-12-2020, 06:20 PM
#23
[QUOTE=RedRunner_87;3503551]Got it back from alignment today. Here are the numbers and the recommended numbers from Ironman.
Did you install new UCAs or is this with OEM?
How did the lift settle? Any final measurements?
I was at 3.5” in front but that settled to 3” after a short drive. Rear is holding steady at 2.5”
06-13-2020, 02:27 AM
#24
[QUOTE=Run Forrest Run;3503574]
That is with the Ironman UCA'S
Stock/Day of/today
DF: 19.5"/ 23.5" / 22.5"
DR: 21”/ 24 1/8" / 24"
PF: 19.5" / 23.5" / 22.5"
PR: 21" / 24 3/8" / 24.25"
5th Gen Build
06-13-2020, 07:05 PM
#25
Just ordered a stage 3 with nitro shocks for the wife's 2019 4Runner. I have had Ironman on my 1995 Landcruiser since 2007 and have nothing but praise for it. Made it easy when we decided to lift the 4Runner what brand lift we would go with.
06-14-2020, 12:23 PM
#26
Here is some comparison pictures of stock vs Ironman
IMG_8699 by redrunner87, on Flickr
IMG_8711 by redrunner87, on Flickr
IMG_8705 by redrunner87, on Flickr
IMG_8702 by redrunner87, on Flickr
IMG_8715 by redrunner87, on Flickr
5th Gen Build
06-29-2020, 04:51 PM
#27
What are everyone's though of Ironman Foam Cell Pro Stage 2 vs Dobinson's IMS/UCA setup ? Pricewise both are close enough that the difference is not material. I've narrow down to these two but having a tough time deciding which one to go with.
06-29-2020, 05:17 PM
#28
That's a good question, do you plan on adding a lot of weight (back and front) on your 4runner? If so, the variety of spring options Dobinsons offer is something worthwhile to consider (if just added rear weight then not so much as you can run a Ironman back there + dobinson spring if needed).
09-04-2020, 09:34 PM
#29
Posting an update to this thread- below is a link to my Ironman Nitro Stage 2 kit. Very happy with the result. With 5mm spacer on Drivers Front, lean is now gone.
Before measurements:
DF 19.5”
PF 19.875”
DR 21.5”
PR 21.75”
After measurements:
DF 22.5” +3”
PF 22.75” +2.875”
DR 24” +2.5”
PR 24” +2.25”
Ironman 4x4 Nitro Stage 2 Lift
Before (265’s) and after (285’s) shots:
02-03-2021, 10:12 PM
#30
Real Name: Luke
Real Name: Luke
Very happy with my Ironman 4x4 Foam Cell Pro lift. You can't beat the price, the ride is super nice. The lift came out to more than 3" in front, it still needs to settle, but I'm actually happy with this result. It floats over bumps and it's firm during breaking.
Here is exactly what I've got.
Toyota 4Runner 2010+/Lexus GX460 Foam Cell Pro Suspension Kit - Stage 2
(Front Springs: 3" Lift Performance Load (0-110LBS Additional Payload), Rear Springs: 2" Lift Performance Load (0-660LBS Additional Payload), Pre-Built Coil Overs: Yes)
2018 TRD ORP w/ KDSS, Hefty Front Bumper, Ironman4x4 Pro Foam Cell, RSG Sliders, Nitto RGs 285/75/17 E, Victory 4x4 full steel armor, Diode Dynamics Fogs
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
