Old 06-10-2020, 11:59 PM #16
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Originally Posted by Dreaddy72 View Post
I have been researching kits and decided on the ironman stage 2 nitro shock kit as well. I have 33in tires and they said I would have no problem bumping up the front to 3in using their forged UCA's. I would like to see some more pics when more people have that kit installed.
I preordered my kit, i should have it in a couple weeks. From what I have seen so far it looks like some people with that kit can go above 3 inches.
Why go above 3? Cv angles could be rough and youd lose alot of down travel
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 12:46 AM #17
Dreaddy72 Dreaddy72 is offline
Dreaddy72 is on a distinguished road
No I'm not trying to go above 3, it's just that I'm at 3 now with my readylift spacers and I have 33in tires that, after minor trimming, dont rub. I just dont want to upgrade my suspension and be stuck with a 2in lift and have to deal with rubbing is all. My measurement up front is just over 38in from ground to fender and would like to keep it around there.
I almost went with a OME/Bilstein combo, but with Ironman I get uca's and I save a bunch of $ with what seems to be a solid product with a 3yr warranty.
Dreaddy72 is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 01:18 AM #18
Run Forrest Run's Avatar
Run Forrest Run Run Forrest Run is offline
Run Forrest Run will become famous soon enough
Exactly what I was considering too. My Nitro kit with performance springs should be here soon. If it helps anyone, below are my current center hub to fender measurements:
DF 19.5
PF 19.875
DR 21.625
PR 21.75
After conversation with several Ironman gents, I confirmed T4R springs are same length, not L/R specific. I’m having them preassemble my coils with one 5mm spacer on DF that should equate to 10mm (.4”) to level the front.
Estimate for a stock TRD ORP with sliders is that performance springs should give me 2.5” lift. If all goes to plan, I hope for 2.9” DF and 2.5” on the rest.
Forged UCA’s combined with my OEM wheels should yield good clearance for 285’s. I will report back as it comes together.
2023 TRD OR, Lunar Rock
Run Forrest Run is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 04:37 PM #19
FishNerd FishNerd is offline
FishNerd is on a distinguished road
Need a little clarification on the spring ratings. I noticed for the front springs constant load is rated up to 220lbs, currently with bumper, skids, sliders and various accessories im pushing an additional 430+lbs overstock. Will the constant load in the front be sufficient? As for the rear I dont have much weight (less that 660lbs+ the constant load calls for). In this instance would it be best to have constant load springs in the front and performance springs in the rear?
Cheers!
FishNerd is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 05:58 PM #20
RedRunner_87's Avatar
RedRunner_87 RedRunner_87 is offline
RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light RedRunner_87 is a glorious beacon of light
Cheers!
You can email them or get on their live chat they are super helpful. But you can mix and match the coils between front and rear depending on what you are running.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
RedRunner_87 is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 07:15 PM #21
Awesome thank you! Ill reach out to them
Cheers!
Old 06-12-2020, 05:46 PM #22
Got it back from alignment today. Here are the numbers and the recommended numbers from Ironman.
Untitled by redrunner87, on Flickr
5th Gen Build
Old 06-12-2020, 06:20 PM #23
[QUOTE=RedRunner_87;3503551]Got it back from alignment today. Here are the numbers and the recommended numbers from Ironman.
Did you install new UCAs or is this with OEM?
How did the lift settle? Any final measurements?
I was at 3.5” in front but that settled to 3” after a short drive. Rear is holding steady at 2.5”
Old 06-13-2020, 02:27 AM #24
[QUOTE=Run Forrest Run;3503574]
That is with the Ironman UCA'S
Stock/Day of/today
DF: 19.5"/ 23.5" / 22.5"
DR: 21”/ 24 1/8" / 24"
PF: 19.5" / 23.5" / 22.5"
PR: 21" / 24 3/8" / 24.25"
5th Gen Build
Old 06-13-2020, 07:05 PM #25
Dinosaur Overland's Avatar
Dinosaur Overland Dinosaur Overland is offline
Dinosaur Overland is on a distinguished road
Just ordered a stage 3 with nitro shocks for the wife's 2019 4Runner. I have had Ironman on my 1995 Landcruiser since 2007 and have nothing but praise for it. Made it easy when we decided to lift the 4Runner what brand lift we would go with.
Dinosaur Overland is offline   Reply With QuoteReply With Quote
Old 06-14-2020, 12:23 PM #26
Here is some comparison pictures of stock vs Ironman
IMG_8699 by redrunner87, on Flickr
IMG_8711 by redrunner87, on Flickr
IMG_8705 by redrunner87, on Flickr
IMG_8702 by redrunner87, on Flickr
IMG_8715 by redrunner87, on Flickr
5th Gen Build
Old 06-29-2020, 04:51 PM #27
LA260's Avatar
LA260 LA260 is offline
LA260 is on a distinguished road
LA260's Avatar
What are everyone's though of Ironman Foam Cell Pro Stage 2 vs Dobinson's IMS/UCA setup ? Pricewise both are close enough that the difference is not material. I've narrow down to these two but having a tough time deciding which one to go with.
LA260 is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 05:17 PM #28
That's a good question, do you plan on adding a lot of weight (back and front) on your 4runner? If so, the variety of spring options Dobinsons offer is something worthwhile to consider (if just added rear weight then not so much as you can run a Ironman back there + dobinson spring if needed).
Old 09-04-2020, 09:34 PM #29
Posting an update to this thread- below is a link to my Ironman Nitro Stage 2 kit. Very happy with the result. With 5mm spacer on Drivers Front, lean is now gone.
Before measurements:
DF 19.5”
PF 19.875”
DR 21.5”
PR 21.75”
After measurements:
DF 22.5” +3”
PF 22.75” +2.875”
DR 24” +2.5”
PR 24” +2.25”
Ironman 4x4 Nitro Stage 2 Lift
Before (265’s) and after (285’s) shots:
Ironman 4x4 Lift-c0e26f95-2d15-4c8a-8195-58c0ec7b0425-jpg  Ironman 4x4 Lift-d8310ca8-c20b-4a3a-85dc-c8a026aaa559-jpg
Old 02-03-2021, 10:12 PM #30
SilverTEP's Avatar
SilverTEP SilverTEP is offline
Real Name: Luke
SilverTEP will become famous soon enough SilverTEP will become famous soon enough
SilverTEP's Avatar
Real Name: Luke
Very happy with my Ironman 4x4 Foam Cell Pro lift. You can't beat the price, the ride is super nice. The lift came out to more than 3" in front, it still needs to settle, but I'm actually happy with this result. It floats over bumps and it's firm during breaking.
Here is exactly what I've got.
Toyota 4Runner 2010+/Lexus GX460 Foam Cell Pro Suspension Kit - Stage 2
(Front Springs: 3" Lift Performance Load (0-110LBS Additional Payload), Rear Springs: 2" Lift Performance Load (0-660LBS Additional Payload), Pre-Built Coil Overs: Yes)
2018 TRD ORP w/ KDSS, Hefty Front Bumper, Ironman4x4 Pro Foam Cell, RSG Sliders, Nitto RGs 285/75/17 E, Victory 4x4 full steel armor, Diode Dynamics Fogs
SilverTEP is offline   Reply With QuoteReply With Quote
4x4 , brand , compare , heard , lift
Ironman 4x4 lift Gstick 5th gen T4Rs 8 08-15-2020 08:54 AM
Ironman 4x4 lift MandAtaco 4th Gen T4Rs 2 07-13-2013 11:35 AM
Ironman lift and DDM hi/low kit for sale cj80cruiser Classifieds - buy & sell (no commercial ads please) 2 02-05-2011 10:42 AM
Ironman lift and DDM hi/low kit for sale cj80cruiser 3rd gen T4Rs 6 02-02-2011 12:15 AM
Ironman front lift cj80cruiser 3rd gen T4Rs 11 09-02-2010 03:45 PM
