11-04-2019, 07:37 AM
Lock N Roll or Max Coupler
I have an off road camper and looking to change out the hitch. I am trying to decide on a Max Coupler or a Lock N Roll. Anyone have suggestions for one over the other? I am able to find the Lock N Roll for sale at Amazon and several other places but the Max Coupler is hard to find.
2018 TRD Off-Road Premium XP Predator
My Build Thread
instagram @al4runnr
Bilsteins 5100s (max setting), Icon 2" rear springs, Frontrunner 3/4 Slimline II, C4 Fab Summit ladder, Firestone Ride-Rite air bags, 2018 WeeRoll Wrangler X
11-04-2019, 10:59 AM
I used both on my AT Horizon trailer. I found that the Max Coupler was less likely to bind in tighter backing up and generally had less slack.....just fewer parts.
That being said, getting the pin in place on the Max can sometimes be a challenge especially if your trailer is on rocky terrain and hard to move by hand...I ended up putting a larger pneumatic tire on my drop leg and that took care of it. Also helps if you have a backup camera for those solo trips.
atoverland.com will fix you up with either one. I’d buy the Max hands down.
11-04-2019, 11:51 AM
Real Name: Patrick
Real Name: Patrick
Max coupler...9 years...no problems
White 2016 TEP .....My ROAM Truck Build....... My ROAM trailer Build
11-04-2019, 12:10 PM
I went with pintle :Shrug: cheap. easy. no maintenance. Honestly a regular ball mount was fine for me though but i was worried it'd pop off and roll down a hill lol. Even tho i have safety chains.
11-04-2019, 07:45 PM
Real Name: Chris
Real Name: Chris
I had a pintle on mine as well. I was worried at first that I would have issues, but was pleasantly surprised by how well it tracked. I found no reason to change it out. They key is having the pintle and lunette sized appropriately for each other. That being said if I did change it out I would have gone Max Coupler. Overall from everything I researched it has less issues although there are pluses and minuses to every setup.
2015 SR5 Premium 4wd Magnetic Grey w/3rd row: Frontrunner Slimline II 3/4 Rack - Yakima Skybox 16 - Weathertech - 22" Behind Grill Light Bar - TRD Skid w/Full Aluminum RCI Skids - RCI Sliders - Falken AT3 265 SL - Lamin-X - Taxa Cricket
"If I Can Do it You Can" Light Bar Install
ARB Breather Mod
Cymon's Weekend Warrior/MFD Thread
11-04-2019, 08:24 PM
yea true, there's tons of info out there on expo portal too. from guys who do way more sh1t with their trailers. my homemade trailer on 33's has more ground clearance than the toyota ever could have, and it goes on forest service roads
11-05-2019, 02:18 PM
[QUOTE=Dude;3383070]I used both on my AT Horizon trailer. I found that the Max Coupler was less likely to bind in tighter backing up and generally had less slack.....just fewer parts.
QUOTE]
Interesting observation although I have not had any binding issues backing up nor issues with slack. Mine is as tight as when I installed it. (Lock-n-Roll)
'16 T4R Trail P
JFR equal length Y-pipe, URD High Clearance 3" exhaust, Volant resonator, ICON
