Old 06-04-2020, 02:49 PM #46
Lost-Again's Avatar
Lost-Again Lost-Again is offline
Real Name: Old man
Lost-Again will become famous soon enough
Lost-Again's Avatar
Real Name: Old man
I don't like how the Inno has feet. Pass
2018 T4R TRD Pro Stock - RSG Sliders - Lock'er Down Console Safe - Yaesu 7900 - Cobra 75 - Garmin 55 Dash Cam - Gaia GPS - Garmin InReach Mini - Earthmate - Baja Designs Squad Sport Ditch Lights w/ Cali Raised Low Profile Ditch Light Brackets -Diode Dynamics SS3 Fog Light Kit - LFD Crossbars - BFG K2s - Warn VR EVO 10s - Warn Semi-Hidden Bumper
Lost-Again is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 03:19 PM #47
Fool-on-the-Hill Fool-on-the-Hill is offline
Fool-on-the-Hill is on a distinguished road
Not optimal, but they do provide protective clear decals to put under them to protect the paint.
Fool-on-the-Hill is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 03:19 PM #48
MidniteTRD's Avatar
MidniteTRD MidniteTRD is offline
MidniteTRD will become famous soon enough
MidniteTRD's Avatar
Originally Posted by raab02 View Post
Mind posting a pic of how you used the third bar to mount their fairing?
The LFD crossbar + stock side rails is damn near perfect for my needs but I'm also about to do a few long highway trips and don't want to add a bunch of noise.
no prob. here's a look at how I have it spaced out, but keep in mind this is because we're currently using it 100% for carrying our Thule box.
i should point out that in the current front bar position, we have enough aero buffeting at 70+ mph up there that with the fairing extended out, it was vibrating up and down and actually tapping the roof sheetmetal. by pushing it back on its mounting adjustments it took out enough movement that it not longer does that at any speed or over any terrain. i DON'T think its a problem with the product, just an anomoly of the aero at that speed with the fairing in that exact position. elsewhere, it may not have that issue.
i don't mind having to buy 3 bars. in the future i may push the middle bar further back to accommodate different gear loads at which point i might need to utilize the front bar too.
'19 T4R TRD Off-Road | @go_scott_go
MidniteTRD is offline   Reply With QuoteReply With Quote
Old 06-05-2020, 03:50 PM #49
Lost-Again's Avatar
Real Name: Old man
Lost-Again's Avatar
Real Name: Old man
Is that the aluminum or steel crossbar? I'm planning on getting the steel version next month.
Old 06-05-2020, 05:08 PM #50
biratley biratley is offline
biratley will become famous soon enough biratley will become famous soon enough
LFD Cross Bars / Roof Box Combo Suggestions
Does the faring help wind noise , i have 4 crossbars mounted like that and its duper noisy
Sent from my iPhone using Tapatalk Pro
biratley is offline   Reply With QuoteReply With Quote
Old 06-06-2020, 02:24 PM #51
MidniteTRD's Avatar
MidniteTRD's Avatar
These are the ruggedized steel units. If I was running 4-5 bars i might have considered the alu ones to keep weight off the highest point of the vehicle, but for 2 or 3 bars steel felt like a great deal.
yes it does. we had roaring and resonance that would come in hard at about 50 and 70mph, both speeds we cruise at often. the fairing eliminated it all. i think the "C-channel" shape of the bars makes this especially problematic although I think its a worthy tradeoff for the height, strength, mounting options and cost.
Old 06-07-2020, 02:31 AM #52
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
You can always just find a box you like and bolt is down. This should give you and idea.
YouTube
itr1275 is offline   Reply With QuoteReply With Quote
Old 05-22-2021, 07:14 AM #53
4runnerchibcha 4runnerchibcha is offline
4runnerchibcha is on a distinguished road
By the way, just want to point out to people looking at this thread that this bar configuration DOES NOT work with the Yakima Skybox 16. The clamps are a certain shape where you cant both clear the front wind fairing and open the rear hatch door. If you want the LFD wind fairing, you need a thile box.
It seems it does work with thule boxes, so I'll try that now.
4runnerchibcha is offline   Reply With QuoteReply With Quote
Old 05-06-2022, 06:30 PM #54
Govbud NH Govbud NH is offline
Govbud NH is on a distinguished road
Roof Box Clearance above antenna?
Just bought 2018 LTD and it did not come with crossbars. I plan on a roofbox, would there be clearance problems above the antenna? The OEM crossbars mount midway on the rails. If so, maybe raised Thule crossbars that mount around the rails would raise the box? Has anyone dealt with this?
Govbud NH is offline   Reply With QuoteReply With Quote
Old 05-07-2022, 05:32 PM #55
Humble Leader's Avatar
I would recommend thule crossbars over OEM (I have thules). If you need more of a platform LFD will work with stock side rails. Thule will sit up higher and clear the antenna no issues with a thule cargo box. LFD may clear the sharkfin antenna if you have a box with a cutout for the fin. I have seen a couple post here that they were able to fit cargo boxes (I think Yakima) on LFD bars.
The LFD Off Road Thread
Old 05-16-2022, 02:25 PM #56
PNW_Red4Runner PNW_Red4Runner is offline
PNW_Red4Runner is on a distinguished road
Just wanted to make my contribution, as this forum has been incredibly helpful.
2018 SR5 4Runner with 2 LFD Crossbars - was able to mount a Yakima CBX18 rooftop box. Mounted fully forward - clears the shark fin antenna with ~3/4" clearance. I did however have to slide the front crossbar fully fwd (so no wind fairing, for now) in order for the front claws to properly grasp the crossbar. Can get photos if people are are interested.
Noise: not too bad, still able to hold a conversation (I hardly drive over 75)
MPG: lost about 1.5 mpg after the addition of crossbars and cargo box.
PNW_Red4Runner is offline   Reply With QuoteReply With Quote
Old 05-16-2022, 10:03 PM #57
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Check out my setup on Pages 100 and 101. Fairing is a must.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 03-25-2023, 09:04 PM #58
DosYotas DosYotas is offline
DosYotas is on a distinguished road
I've had a similar issue getting my Yakima Skybox hooked up with my LFD Crossbars. The LFD Crossbars definitely have better height than stock and would keep the box clamps/feet from scraping the roof, but I couldn't get the built in Yakima clamps to wrap around the crossbars. Did anyone ever get that to work? I ended up having to swap back to the factory crossbars to get it to work, but the fit is mighty tight.
2020 4Runner ORP V6, Falken WildPeaks AT3, LasFit bulbs, and other small mods/desires in progress
2004 4Runner Limited V6, TRD Pro wheels, 2" lift, K&N intake
2001 Tacoma V6, 5spd, ARB front bumper, Fabtech coilovers, Borla catback exhaust, finally had to swap out my CD/Cassette
DosYotas is offline   Reply With QuoteReply With Quote
Old 03-26-2023, 08:46 PM #59
YT-1300's Avatar
YT-1300 YT-1300 is offline
YT-1300 will become famous soon enough
YT-1300's Avatar
Trying to understand, do you mean you couldn't get the skybox's jaws open or closed enough around the LFD bars or you have their fairing and it gets in the way? I use my Skybox 16 on the LFD bars and it's solid as hell!
Sent from my moto g(7) using Tapatalk
2019 SR5 Prem, Nautical Blue, 3rd row, TRD wheels, 255/75/17 Cooper Discoverer AT3 4S (SL), Leveled with Eibach shocks, Rav4 mirrors
YT-1300 is offline   Reply With QuoteReply With Quote
Old 03-31-2023, 09:30 AM #60
Thanks for the reply. The issue is I wasn't able to get the skybox jaws to close (I wasn't using the fairing up front yet either, just 2 LFD cross bars). The jaws open up enough, but I could never get the jaws to snap back to the closed position. User error on my part?
Last edited by DosYotas; 03-31-2023 at 09:31 AM. Reason: adding note about fairing
bars , box , cross , lfd , roof
TRD Pro Roof Cross Bars TRDP-FL 5th gen T4Rs 14 09-12-2016 12:23 AM
FS: roof cross bars: 3rd and 5th Gen: PNW Orlyg1521 For Sale: T4R Items 2 10-29-2015 01:58 AM
WTB: cross bars for 2014-15 cross bars for factory roof rack BowJanked For Sale: T4R Items 0 08-27-2015 01:24 PM
looking for some roof cross bars... morbidsanity 3rd gen T4Rs 4 08-23-2013 06:23 PM
Roof rack and cross bars NIKBPIK 4th Gen T4Rs 0 07-26-2009 02:42 PM
