**Problem Solved* front end metallic clanking sound
Several threads have been posted here about that "clanking/metallic sound" coming from the front end. Mine ended up being LCA lower bolts not tightened to spec. Service manual states 129 pounds of torque... After the stealership had to replace my p/s LCA under warranty because of a stripped out eccentric bolt, which requires it to be realigned. They apparently didnt tighten up the lower bolts to spec. I had only about 80 pounds of torque on these bolts both d/s and p/s. Tightened to spec and the clank is gone. Problem solved.
2021 4Runner TRD ORP: Bilstein 5100's all 4 corners, 1" Cornfed spacers in the rear, Firestone Air Bags rear, Poly bushings for sway bars, Scangauge 2, Vent Visors, Pro Comp 32 wheels and Wildpeaks 265-70R17 tires.
