Old 11-04-2019, 04:11 PM #1
Brage Brage is offline
Brage is on a distinguished road
A few suspension questions...
I have a ORP without KDSS and am putting a set of 6112s on the front at ~1.2. 5160s on the rear.
1. Should I drop the sway bar or diff? Based upon research, it doesnít sound needed.
2. I am interested in raising the back about .5 in... is a cornfed spacer my only option? Anyone make springs that would be a better upgrade while Iím in there?
Brage is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 04:25 PM #2
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I saw an Eibach 1" rear spring somplace....
Eibach Pro-lift kit springs 1" rear
Eibach E30820710102: Pro-Lift Springs 2010-2018 Toyota 4Runner - 1.00" Rear Lift | JEGS
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 04:33 PM #3
Originally Posted by badattitude View Post
Thanks... thinking if I go up 1Ē in the rear that I should probably go up 1.6ish in the front.. ? that would probably be about as high as I would want.
Old 11-04-2019, 04:37 PM #4
I also think corn fed will cut a rear spacer any size you want. A 1/2 inch spacer lifts one inch, just the way it works with spring compression. Depends if you like the level or raked look.
1999 4runner
Old 11-04-2019, 04:41 PM #5
Given the reviews on those Eibach springs, that sounds like a winner. At the 1.2 or 1.6 setting, I shouldnít need to drop the sway or diff, right?
Old 11-04-2019, 04:55 PM #6
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Given the reviews on those Eibach springs, that sounds like a winner. At the 1.2 or 1.6 setting, I shouldn’t need to drop the sway or diff, right?
Definitely not necessary to do a diff drop at that height. Once you get to 2-2.5 I would recommend doing though, a lot of people do a 2.5/1.5 and still don't run so you are all good.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 05:33 PM #7
TEujunga's Avatar
TEujunga TEujunga is offline
TEujunga has a spectacular aura about TEujunga has a spectacular aura about
TEujunga's Avatar
Pretty sure there's no "multiplication factor" for rear spacer lift. The spring rests directly on the axle housing, so 1" of spacer gets you 1" of lift.
It's different in the front, where the geometry of the spring's mounting point on the LCA means you get around the 2:1 ratio you mentioned -- 1/2" of spacer gets you close to 1" of lift.
Always a good idea to read through the lift buyer's guide thread -- lots of great into there: 5th Gen 4Runner Lift Buyers Guide - Toyota 4Runner Forum - Largest 4Runner Forum
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
TEujunga is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 06:37 PM #8
not true. back end is a 1:1 ratio. front is a arm setup so yes there is a roughly 1:2 ratio.
Old 11-04-2019, 09:05 PM #9
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
I have Eibach Pro truck 1" rear springs and this is how it looks. Front is lifted about 2-2.25" over stock.
Daikon is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 09:20 PM #10
Daikon's Avatar
Daikon's Avatar
I'm at 2-2.25" over stock in the front. CV angles look straight. Did not install a diff drop.
A lot of people say its unnecessary. Companies like Toytec 'push it' because its a product they manufacture and sell.
Old 11-04-2019, 11:40 PM #11
brtnstrns brtnstrns is offline
brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice
Are those 265 or 285 Wildpeaks?
Voodoo Blue 2020 Tacoma TRD Off Road
brtnstrns is offline   Reply With QuoteReply With Quote
Old 11-04-2019, 11:51 PM #12
Daikon's Avatar
Daikon's Avatar
Originally Posted by brtnstrns View Post
are those 265 or 285 wildpeaks?
265!
Old 11-05-2019, 12:02 AM #13
265!
Yeah right after I wrote that I came across a photo of someone with 285 Wildpeaks and they're noticeably way huge.
Old 11-05-2019, 12:43 AM #14
Daikon's Avatar
Daikon's Avatar
265's have done me fine. I think too many people jump into 285's because of what they see online as 'cool' versus looking for something to fit their actual needs.
Old 11-05-2019, 01:02 AM #15
Yeah, sometimes the 285s seem "just right" in photos and sometimes they look absurdly gigantic.
I've got 265 Wildpeaks on mine and with my only "lift" being a Cornfed 1" spacer, they look perfect. Just never sure how I'd feel if I went another inch taller.
interested , iím , needed , raising , spacer
Suspension questions JazzAvi8r 3rd gen T4Rs 2 11-21-2017 04:46 PM
Suspension Questions ziegler 3rd gen T4Rs 2 11-29-2016 10:28 AM
IFS Suspension and Questions. DanSocal619 Engines / Suspension / Wheels / Tires / Audio / Accessories 7 05-31-2014 04:02 PM
Suspension questions TXRick 3rd gen T4Rs 1 01-08-2013 12:25 PM
Suspension Questions gmata 3rd gen T4Rs 4 10-18-2011 12:35 AM
