Old 11-06-2019, 05:46 PM #16
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
Originally Posted by matoolie View Post
Can you self jump, i.e. connect the two batteries together if needed? Other than using jumper cables.
If you want, I guess you could switch positions on the distribution block to jump one to the other but there is no need since it is impossible to drain the main battery.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 11:35 PM #17
slprciv slprciv is offline
Real Name: Nick
slprciv has a spectacular aura about slprciv has a spectacular aura about slprciv has a spectacular aura about
Real Name: Nick
Redarc 25 is what I run on my truck with a Odyssey 34 for the accessories. Stock battery sees 13.9 while accessory battery see 14.4. Haven't had any issues yet. DC to DC is the way to go.
'18 TRD Off Road Premium w/KDSS.....and Kings, etc...
slprciv is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 07:32 PM #18
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
Understood but there is always a need. If the main battery takes a dump make sure you can use the aux. battery to start the vehicle and get you back to civilization and a new main. Which sounds like you can by switching leads or carrying jumper cables. Had my main battery take a dump overnight where it dropped cells and resulting voltage was only 6v. I self jumped with aux battery to get truck started and buy new main.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 10:31 PM #19
ruff4runner's Avatar
ruff4runner ruff4runner is offline
ruff4runner will become famous soon enough ruff4runner will become famous soon enough
Originally Posted by Xtremluck View Post
So I built my dual battery setup just about 1.5 years ago. Which consists of two AGM batteries connected via a National Luna Intelligent solenoid. It has been working really well with close to 60 days of camping under its belt. Details on the build are here:
Dual Battery Setup (5th Gen Toyota 4runner) - Google Docs
I've recently noticed that my secondary battery hasn't been holding a charge sitting at around 12.2 volts after charging from the alternator for three hours. My battery isolator also will disconnect the batteries when the engine is running if I turn on all my off-road lights at the same time at night while traversing trails. I think some of this may be related to battery degradation especially since our alternator's charging voltage isnt ideal for AGM.
I dont have the ability to charge both batteries via shore power unfortunately. So I'm trying to find a solution. It would seem that ripping out the current solenoid system for an intelligent DC-DC charger would make the most sense but one of my requirements is the ability to link the batteries to winch or jump start the vehicle. With a DC-DC charger this would not be possible.
I know there are other folks here who have similar setups. What have you been doing? Augmenting with solar? Moving back to lead acid?
You can link/jump your batteries with a DC/DC charger. I have it on my rig. Here's the Redarc wiring guide.
BCDC Dual with Jump-Start - The New Ultimate Dual Battery Setup | REDARC Electronics
Dual Battery Setup 1.5 Years In (AGM Woes)-screen-shot-2020-01-14-6-19-17-pm-jpg
2019 TRD ORP with stuff bolted to it and my Alaskan Malamute benevolent overlord, Farley. KN6HZJ
ruff4runner is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 10:53 PM #20
jerad jerad is offline
jerad will become famous soon enough
I'm running 2 Odyssey batteries connected via a Blue Sea ACR. My batteries can charge via Alternator, Shorepower (CTEK hardwired) and I have a 100w solar panel on the roof rack.
I absolutely love this system, I haven't turned my ARB fridge off in over 2 years and my Victron battery monitor is at 100% almost full time even if sitting parked. If camping I do have 2 100w panels that I'll rig up to my 4R via the rear Anderson plug that powers my turtleback trailer when attached.
If you search my username I did a pretty detailed write up somewhere along the way on how I wired everything up.
16 TEP Mag Grey
jerad is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 02:39 PM #21
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Based on that diagram, the REDARC has nothing to do with jumping.
You are just using a solenoid to temporally put both batteries in parallel, bypassing the REDARC completely.
This could be applied to any system regardless of a ACR or DC-DC charger.
Old 01-15-2020, 04:29 PM #22
SnoRnR's Avatar
SnoRnR SnoRnR is offline
SnoRnR will become famous soon enough
SnoRnR's Avatar
This is the setup I will be starting to build late Feb. I am leaving the solenoid jump-start until later. The solar and DC/DC will be going in with group 34. You can also carry a lithium starter pack as a fail-safe. I mainly want the parallel running for winching. Don't intend to fit a winch until next year though.
2019 TRD PRO
Gobi Stealth No-Rise / C4 Fab Sliders / Xenon Depot HID Low LED High / Goose Gear Drawer & Sleeping Platform / RAGO MSP / ARB Dual Compressor / Shrockworks Dual Battery / ARB Differential Breather /
SnoRnR is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 04:39 PM #23
Bumbo's Avatar
Bumbo's Avatar
How are you putting both in parallel for the winch load?
I actually went to a triple battery setup... I still have a traditional ACR based system with two regular starters, and then use a DC-DC and a smaller battery for the small accessory loads like the fridge.
Also, you could consider separates from Victron Energy instead of REDARC. I think they have a better overall system.
DC-DC
Orion-Tr Smart DC-DC Charger Isolated - Victron Energy
MPPT Solar Charge Controller which is substantially nicer than the integral one in the REDARC. Phone application, bluetooth connected.
SmartSolar MPPT 75/10, 75/15, 100/15 & 100/20 - Victron Energy
Both are programmable voltages so you can match it to any type of battery you want, including lithium.
Victron makes really good gear... been using them for years in my custom builds.
Here is a good case study when looking at solar and self recovery from a flat battery.
PROBLEM WITH REDARC DC to DC
Old 01-15-2020, 04:46 PM #24
matoolie's Avatar
matoolie's Avatar
Agreed. Simply using jumper cables to connect the two batteries for emergency starting when needed just as effective and cheaper than the additional fuses, wiring, and solenoid.
Michael
Old 01-15-2020, 05:13 PM #25
Bumbo's Avatar
Bumbo's Avatar
If you consider most people would be carrying around a set of jumper cables anyways, I find little reason to wiring up an entire bypass circuit for the off chance you do need to self-jump. It adds cost and complexity for something you really shouldn’t even need.
The entire point of these dual battery systems is to prevent starting issues in addition to having more capacity for accessory loads.
If you are constantly running your starter flat, you designed your system incorrectly. I have yet to actually need to jump start myself, but I have helped others which is why I still carry cables.
On a side note: There is a reason ACRs like the BlueSea ACR SI-Series have a low voltage lockout protection. If the voltage is too low, internal short as an example, then you might end up with two dead batteries forcing them in parallel. If you killed your starter in the dual battery system, it would be best to investigate if you are on the trail where you can’t get quick help.
Old 01-15-2020, 05:53 PM #26
matoolie's Avatar
matoolie's Avatar
Yep. A proper dual system should prevent drain, but you have to be prepared for when a starter battery suddenly takes a dump. I woke up one morning with my truck completely dead. The starter battery was only at 6v. It had dropped cells overnight. I was able to start the truck with auxiliary battery. In my opinion not having that capability when you have two batteries is not smart. And it can be done with typical solenoid dual systems or jumper cables. Just make sure you have the capability.
Michael
Old 01-15-2020, 09:12 PM #27
Thats right, The Redarc has nothing to do with the jump/linking of the batteries, but as @Xtremluck implied there are some that think it will damage the Redarc if the batteries are linked temporarily.
Old 01-15-2020, 09:36 PM #28
Bumbo's Avatar
Bumbo's Avatar
Yes, bypassing the REDARC would not harm it in any way.
Perhaps I misunderstood your post… I though you implied the REDARC is doing the jumping.
Old 01-15-2020, 09:43 PM #29
Bumbo's Avatar
Bumbo's Avatar
There are some OEM loads that can help run down the starter…. Leaving doors open, lights on, radio on.
I do use my stereo often when camping and because of that moved the main power feed for the head unit to the AUX battery side. It is more work but it was part of my design to ensure that there isn’t anything that I can really do under normal operating conditions that would leave me without power to start the truck.
If you find you use a lot of OEM loads and are unable to re-wire those circuits, then you should consider:
Adding a low voltage disconnect to the starter side
Adding solar to charge the starter to provide supplemental charge
Adding a basic DC-DC converter to charge from AUX to Starter to help supplement those loads.
Use a BlueSea BatterLink ACR which allows you to lower the disconnect voltage, essentially creating a bigger battery as both stay in parallel longer.
Here is a link to a basic DC-DC which would work very well for this.
For $65 bucks, you can have this on a switch to provide 9 amps of charge current from the AUX to the starter. It’s got a remote port so you don’t have to worry about any relays or high current switching.
Victron Energy Orion-Tr 12/12-9A (110W) Isolated DC-DC converter
Old 01-15-2020, 10:27 PM #30
matoolie's Avatar
matoolie's Avatar
I think you are missing my point.....my starter battery died with nothing on. Parked in my garage. Cells inside the battery went bad. The battery simply crapped out. Nothing related to loads. This sometimes happens to batteries. And if it happens in the middle of nowhere you want to make sure you have a way to start the truck with auxiliary. And I am happy with my setup and it suits all my needs.
Michael
agm , batteries , battery , charger , charging
Dual Battery Setup or Portable Battery Punjabi408 5th gen T4Rs 31 11-16-2020 01:54 AM
Dual battery setup filoufil 5th gen T4Rs 2 09-21-2018 04:27 PM
Why a dual battery setup. westtex 5th gen T4Rs 4 05-25-2018 10:03 PM
A different dual battery setup diddley.bo 5th gen T4Rs 5 07-18-2016 02:19 PM
My Dual Battery Setup airbur Engines / Suspension / Wheels / Tires / Audio / Accessories 22 09-04-2011 03:52 AM
