Old 01-16-2020, 12:09 PM #31
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Originally Posted by matoolie View Post
I think you are missing my point.....my starter battery died with nothing on. Parked in my garage. Cells inside the battery went bad. The battery simply crapped out. Nothing related to loads. This sometimes happens to batteries. And if it happens in the middle of nowhere you want to make sure you have a way to start the truck with auxiliary. And I am happy with my setup and it suits all my needs.
I understand what you are saying… I just went on my own tangent.
I have experienced the same thing before in my Silverado. Internally some of the cells failed, permanently lowering the operating voltage of the battery rendering it useless.
Old 01-16-2020, 05:20 PM #32
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
Spent two weeks in Baja Mexico with hundreds of off road miles and the new Redarc + solar system worked flawlessly. Ill update my original dual battery setup thread when I have time as I think this is a much better setup than using a basic solenoid. Although, one could probably get away with a solenoid + solar supplemental power.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 05:29 PM #33
Bumbo's Avatar
Bumbo's Avatar
Did you end up getting a new AGM, or are you trying to nurse your old one back to health?
Old 01-16-2020, 07:25 PM #34
Xtremluck's Avatar
Xtremluck's Avatar
Still using the original. The resting voltage is around 12.6V now which is totally normal. Seems to be ok at just about two years of use even after I drained it flat a couple of times and charged it with our weak alternator.
Old 01-16-2020, 08:02 PM #35
Bumbo's Avatar
Bumbo's Avatar
That sounds much better.
If you had a hard time holding voltage then your internals are sulfated, but it can be repaired if it’s not too far gone. Sounds like you still have some service life in it.
I would keep bringing it up to its full charge voltage as often as you can.
Old 01-17-2020, 02:17 PM #36
SnoRnR's Avatar
SnoRnR SnoRnR is offline
SnoRnR will become famous soon enough
SnoRnR's Avatar
Thanks for the recommend. I am planning on installing this system. What size AUx battery are you running? I am planning group 34 AGM. Also, what size and type of solar panels are you using? I am considering a flat panel on top of a rooftop tent. Mainly to charge at trailheads while we are away hiking and climbing. I will supplement with a flexible deployable mat when static at camp. Just don't fancy leaving a 1000 dollar solar blanket draped on the 4runner while away climbing for hours. What size wire did you use on the Redarc? Manual for the 1225D suggest 6AWG. I am going to add the Redarc smart solenoid down the line for jump starting and winching with both batteries linked.
2019 TRD PRO
Gobi Stealth No-Rise / C4 Fab Sliders / Xenon Depot HID Low LED High / Goose Gear Drawer & Sleeping Platform / RAGO MSP / ARB Dual Compressor / Shrockworks Dual Battery / ARB Differential Breather /
SnoRnR is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 09:46 AM #37
Xtremluck's Avatar
Xtremluck's Avatar
@SnoRnR Im running a Group 34 55ah Odyssey battery mounted in the secondary OEM location and honestly wouldn't really go bigger/heavier. Our engine bay is made of soda can thin sheetmetal and stress fracturing is a real thing. Reused most of my wiring from my original setup 0/1AWG so a little overkill but it works fine.
For solar im running two 120 watt Richsolar which is total overkill IMO. I dont really think you need a solar blanket with a setup like this. It produces a lot of power even in the shade which was surprising.
I honestly think the use case of linking of batteries for jump starting and winching is a bit overblown. Unless you are constantly winching for extended periods your standard battery should be fine. As far as jump starting I have a set of jumper cables that I could use between the batteries or even more convenient my LI-ION jump pack.
Old 01-18-2020, 03:37 PM #38
SnoRnR's Avatar
SnoRnR's Avatar
Awesome answers all my questions. Is the cable down the windshield from the solar permanent mount or do you set it up when you stop? I also carry a li-ion jump pack.
2019 TRD PRO
Old 01-23-2020, 03:25 PM #39
Xtremluck's Avatar
Xtremluck's Avatar
The wiring is permanent as well as the solar panels. On a side note I used my winch extensively this weekend when driving through 2-3 ft of snow on backcountry shelf roads (At least 15 times). Never had a problem with my M8000 drawing from my cheap Duracell 55ah starter battery.
Old 02-09-2020, 10:02 PM #40
OBDGUY OBDGUY is offline
Real Name: David
OBDGUY is on a distinguished road
Real Name: David
Cool Dual Battery Setup
I'm running two Odyssey group 24 batteries on an Off Grid Engineering system. I added a fuse from Australia that bumps the alternator output so it charges the Odysseys between 14.2-14.5. The system works flawlessly and keeps the batteries charged consistently at 14.5. I almost went with the Genesis system, but the battery module simply gets too hot which is never a good thing regardless of what the manufacturer says. The Off Grid Blue Sea module runs cool and efficient, it's totally water proof and in auto mode requires nothing from me. I can self jump from either battery and run my fridge, lights, and teardrop trailer off either battery or both. When it charges it charges both until they are at max volts and automatically shuts the aux battery off and goes back to main battery charging. I love the system, been almost 3 years now with zero problems. Pricey but worth every penny.
OBDGUY is offline   Reply With QuoteReply With Quote
agm , batteries , battery , charger , charging
Dual Battery Setup or Portable Battery Punjabi408 5th gen T4Rs 31 11-16-2020 01:54 AM
Dual battery setup filoufil 5th gen T4Rs 2 09-21-2018 04:27 PM
Why a dual battery setup. westtex 5th gen T4Rs 4 05-25-2018 10:03 PM
A different dual battery setup diddley.bo 5th gen T4Rs 5 07-18-2016 02:19 PM
My Dual Battery Setup airbur Engines / Suspension / Wheels / Tires / Audio / Accessories 22 09-04-2011 03:52 AM
