Old 11-05-2019, 01:57 PM #1
Big Daddy K's Avatar
Big Daddy K Big Daddy K is offline
Real Name: Kevin
Big Daddy K will become famous soon enough
Real Name: Kevin
OTRATTW switches.
I recently installed the Rigid industries SRM back-up light kit in m T4R. The switch it comes with is functional but less than appealing. I like that it can be on /off/auto and would like to retain that functionality. AOB does not have any DPDT switches for Toyota direct replacement. But they do have this-
12 volt 20amp ON-OFF-ON LASER Etched Rocker Switch white -Air On Board
This switch- High quality Carling Technologies custom laser-etched rocker switches, using Carling Technologies L-Series line of rockers and switches is about the closest thing I could find to a drop in solution but I can't find mention on anyone using the L series in a 5th gen.
So I am looking for suggestions of switches that will work. I considered using a switch pros but they said it won't work with an auto function.
Pics would be great if you have a DPDT 3 position switch in your dash somewhere.
Thanks all.
2016 Trail Edition Supa Dupa White
3" OME lift, SPC UCAs, 285/70R17 Yokohama X-AT tires on Icon Rebound wheels, RCI Sliders and Skid Plates, Prinsu full length rack, C4 Fabrication rear bumper and fuel tank skid, and BPF molle panels.
Big Daddy K is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 10:14 AM #2
Real Name: Kevin
Real Name: Kevin
Does anyone have any other suggestions for a DPDT 3 position switch that will fit in the factory cut-outs? Both of these give slightly different dimensions and both say they fit the industry standard knock out holes.
Old 11-30-2020, 10:20 PM #3
nm_t4r nm_t4r is offline
nm_t4r is on a distinguished road
I am in the process of installing some Rigid back up lights as well and am wondering if you found a ON-OFF-ON switch for this purpose?
Thanks...
nm_t4r is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 11:25 PM #4
ToyotaMacGyver ToyotaMacGyver is offline
Real Name: Justin
ToyotaMacGyver is on a distinguished road
Real Name: Justin
Id check the FJ forums. We use the same switches and I know I have seen OTRATTW switches used on some rigs there when I owned my FJ.
ToyotaMacGyver is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 11:52 PM #5
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
Not sure if these will work. Im using on board switch for my 20 inch bajadesigns led light bar.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 12:43 PM #6
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Anytime Backup Camera (forgot their username here) sourced a switch for their camera, maybe contact them and see if they can source one for you
Front and Rear Camera Switch - Toyota
– Anytime Backup Camera
jhguth is offline   Reply With QuoteReply With Quote
dpdt , find , switch , switches , work
Contura V Rocker Switches from OTRATTW bsdoig 3rd gen T4Rs 1 04-19-2014 06:57 PM
otrattw N/A 5th gen T4Rs 13 02-20-2014 11:58 PM
OTRATTW Switches Center Console Romanred62 5th gen T4Rs 11 09-18-2013 06:21 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
