Old 11-05-2019, 07:35 PM #1
axel1's Avatar
axel1 axel1 is offline
axel1 is on a distinguished road
axel1's Avatar
Ignition-off Battery Draw
Hi all!
Woke up this morning to a dead battery. First deep freeze of the year so that definitely wasn't helping things. Normally I'd suspect the battery but it's only six months old and hasn't seen a winter yet. A test at Advanced auto confirmed that it was A-OK.
Started poking around a decided to measure the current draw with the truck powered off. Disconnected all aftermarket accessories and probed the current from the battery terminal to the main power lead and got an initial burst of 500-600mA and a stable 160-180mA after that. Now, that seems exceedingly high from my point of view.
Curious if anyone else has measured the ignition-off current from their battery. If this is actually normal than so be it, but I'd like to know if I need to start poking around the factory fuses to see if something's drawing more than it should be.
Looking around, I couldn't find a thread on 5th gen current draw but please direct me if I'm wrong.
Cheers!
'14 SR5 in Classic Silver, Wilpeak AT3Ws, miscellaneous electrical odds and ends.
axel1 is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 08:38 PM #2
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
I think it should be about half of what you are getting.
Weird that it would spike how long did you leave it on and did it spike again to 500mA?
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 08:46 PM #3
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Mine runs 125ma. See my old post
Battery Ran Down
BobsTrail is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 08:46 PM #4
PK930's Avatar
PK930 PK930 is offline
PK930 will become famous soon enough
PK930's Avatar
I think there is something screwy with our electrical systems. My current battery is about to crap the bed. Sometimes it cranks right up and sometimes it acts like it’s dead and eventually starts.
This is the third battery I’ve had since I bought it (‘12 model) in 2016.
Something, something, something.
PK930 is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 09:02 PM #5
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
I have a Limited with PTS and proximity key so my data may be different from yours since the prox key system draws additional current. I also have a Maestro RR module for the radio, dash cam with park recording and a remote start with Drone that draws current talking with cell towers.
I will have an initial 130ma current draw when hooking up the meter. After waiting 35 minutes the truck goes to sleep and the draw is around 60ma.
Ideally you want under 50ma.
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 10:40 PM #6
axel1's Avatar
axel1's Avatar
Typically I'd expect somewhere between 50-100mA tops which is why I'm asking.
I'm using a multimeter inline with the main battery line so the initial current spike is likely everything powering on for the first time when it gets connected. It only lasts for maybe ten seconds tops before going to ~150mA and staying there. I left it for about three minutes and it stayed there so I'm assuming that's the actual sleep current.
I've got everything aftermarket disconnected including the remote start (unless there's another 12v tap I can't find - it was very poorly installed by the previous owner).
We'll see if she starts tomorrow morning. I ran it a decent amount today so it should be relatively charged up. If it wasn't so damn cold I'd be more inclined to do some fuse pulling to further narrow things down but I value the tips of my fingers too much.
Old 11-06-2019, 04:32 AM #7
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
I measured mine at 130 mA.
Old 11-06-2019, 05:48 PM #8
rwrobs777's Avatar
rwrobs777 rwrobs777 is offline
Real Name: Rob
rwrobs777 is on a distinguished road
rwrobs777's Avatar
Real Name: Rob
Measure the voltage drop using the voltmeter across each fuse until you find the one that is NOT reading zero !!...you can convert the millivoltage to milliamps using a chart that you can Google !!...just make sure that all the cars modules are "sleeping" ...maybe 20-30 minutes...and if you leave the drivers door open to check the fuses there manually lock the door !!
rwrobs777 is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 06:32 PM #9
Say what?
So you want him to check mV on one fuse and convert that to mA to find his draw. But this is only reading one circuit?
2018 TRD OFF ROAD
My Build
Old 11-06-2019, 07:20 PM #10
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
Originally Posted by Dillusion View Post
Say what?
assuming your goal is to find which circuit has the parasitic loss, then measureing voltage drop across each is a great way to quickly do it
for overall you can just put your multimeter in series with one of your battery cables to get the overall amperage, but if you want to know what circuit is pulling that amperage you have to check each one individually and voltage drop is quicker than pulling fuses to check amperage
jhguth is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 08:07 PM #11
I must be having a major brain fart moment on how to convert mV to mA.
2018 TRD OFF ROAD
My Build
Old 11-06-2019, 08:21 PM #12
axel1's Avatar
axel1's Avatar
Ohm's law, super easy. V=IR. Voltage is proportional to current and resistance. Of course, you'd have to know the resistance across the fuse which is likely on the order of 1/10th of an ohm or less.
The idea is more that any fuse that has a slight voltage drop between the two terminals is one that's drawing current from the battery. It's more of a quick test than an accurate measurement.
Old 11-06-2019, 09:36 PM #13
I figure we were talking mA, which is damn small already, here already we would want something accurate.
Guess people troubleshoot "in the ballpark" now days.
Not to mention there is more than just the fuse resistance. Guess I don't see the point in doing it this way.
2018 TRD OFF ROAD
My Build
Old 11-06-2019, 11:12 PM #14
we suggest a 25-milliamp draw is normal and anything that exceeds 100-milliamps indicates an electrical issue that needs to be addressed
What is "normal" for a parasitic draw?
Be sure to allow the vehicle to go to sleep when disconnecting the battery and hooking up your meter.
Old 01-04-2020, 06:28 PM #15
epjfsa epjfsa is offline
epjfsa will become famous soon enough epjfsa will become famous soon enough
Did you ever make headway on this? I'm dealing with a similar problem, hoping to troubleshoot tomorrow.
'16 TEP
'21 Model 3 LR
epjfsa is offline   Reply With QuoteReply With Quote
battery , current , draw , ignition-off , poking
Battery and Winch Amp Draw Chilow 5th gen T4Rs 23 06-06-2019 09:48 AM
1985 4runner battery draw... 88rnr Classic T4Rs 3 08-22-2018 08:59 PM
Phantom battery draw mn_homesteader Classic T4Rs 5 11-04-2008 02:06 AM
Battery Draw coming from Dome light? predatorsniper1 3rd gen T4Rs 2 04-09-2008 07:22 PM
