Old 11-07-2019, 09:24 AM #16
the_economist's Avatar
the_economist the_economist is offline
the_economist will become famous soon enough
Here is the set up I went with earlier this year, with all the details. I'm really happy with how it turned out, and was totally worth the time and money: An Outsider's Review: Bilstein 6112s/5160s + 2in Icon Springs Lift + 275 BFG KO2s
2016 4Runner SR5 4x4. BFG A/T K02s (275/70/17 E Rated). 2-inch Icon rear springs. Bilstein 6112s front (1.2" setting), 5160s rear. RCI skid plates package + gas tank (3/8 in. steel), RCI rock sliders. Warn semi-hidden winch mount + Warn Zeon 10-S Platinum winch. Raingler cargo nets (roof and rear). TRD wheels. LFD rooftop crossbars.
the_economist is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 12:06 PM #17
CharlesNellis CharlesNellis is offline
CharlesNellis has a spectacular aura about CharlesNellis has a spectacular aura about
Dobinsons makes taller stock spring rate springs for front and rear. That's the route i went for a mild lift. Front 5100 at 1.75 with stock spring and rear 5100 with stock spring rate at 1.25" lift dobinsons spring.
Ride is not harsh at all, more like planted. Stock = soft, after = planted
CharlesNellis is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 12:14 PM #18
Dwest Dwest is offline
Dwest is on a distinguished road
Originally Posted by Harrisnc View Post
I think you’ll have a hard time finding an aftermarket front spring that nets under 2”. From my research everybody got at least that from the toyotec coils. If you use the factory coils on the bilstein or the eibach shocks you know what your end height will be and what ever drivers lean you have now( or don’t have) will be the same.
I used the eibach front shocks and their 3/4” rear spring for a 1.75/.9.
Harisnc,
Thank you for the photo! That setup looks like what I'm after. Appreciate your thoughts on the front coil. That's what I was running into as well, is people getting 2" or higher with just a coil. Not what I want.
I looked into the Eibach adjustable pro truck shocks and they are alittle more than the Bilsteins but seem to offer the same adjustment range. I'm looking at the PDF install instructions now, did you set them to the 1.6" front lift setting? To confirm, on stock coils, that netted you 1.75" front lift?
Also, do you have a part # for the 3/4" rear spring? The only one I was able to find states 1" of rear lift.
Thank you!
Dwest is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 12:20 PM #19
Appreciate everyone's input on this, was a little worried as there is so much out there already I'd just be told to search more.
After some more replies I feel I'm leaning towards either the Bilsteins all around at 1.75 on stock coils and 1" spacer,
or
Eibach pro truck shocks all around with front at 1.6 with stock coils and the Eibach rear coil for 3/4 to 1" rear lift.
I'm thinking the Eibach setup might be a little better as with the new rear coil I would have a little more load capacity.
Again, thanks for everyone offering insight. This will be my first modified and lifted vehicle and just trying to avoid surprises and regrets.
Old 11-07-2019, 12:56 PM #20
ebadai98 ebadai98 is offline
ebadai98 is on a distinguished road
I have the following and love it;
Bilstein 5100's all around
Front, Toytec 112-620-P front Coil 1.6” lift, strut at 0.
Rear, Wheelers T13 1.5” lift.
Camburg UCA Ball Joint
Which Mild Lift Setup Would You Do?-61885330-36e7-429b-abda-273224702cd7-jpg
2018 TRD Off Road
ebadai98 is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 01:27 PM #21
ebadai98, Great looking truck! Are you on stock size tires? Do you have before and after measurements for the front, or do you know how much lift that coil gave you?
I know every truck is a little different and not to expect the exact same outcomes but getting a great idea of how everyone's setups have turned out is fantastic!
Old 11-07-2019, 01:49 PM #22
cortney76 cortney76 is offline
cortney76 is on a distinguished road
Dobinsons 1" to 3.5" Lift Kit Toyota 4Runner 2010-19 (Non KDSS) – Dobinsons Direct
cortney76 is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 02:19 PM #23
cortney76, I had looked into options from Dobinsons and the main difference I noticed is they use twin tube shocks vs monotube on the 5100's and Eibach. From what I've read the consensus was monotube was better. Not entirely sure why. That link you provided though is great for selecting the exact setup you want. I wish other websites were as direct. Here's your coil and what it will do, here is your shock and what it will do. Very straightforward.
Old 11-07-2019, 02:22 PM #24
Jeff_DML Jeff_DML is offline
Jeff_DML will become famous soon enough Jeff_DML will become famous soon enough
interesting, did not know that.
Random google article
The Difference Between Twin-Tube and Monotube Shocks - Strutmasters
Jeff_DML is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 04:36 PM #25
That article seems to confirm what I've read here and that monotube is the way to go. Thanks for linking to that, good read.
Old 11-07-2019, 05:44 PM #26
N2TRKYS N2TRKYS is offline
N2TRKYS is on a distinguished road
I went with Bilstein 5100s all around with the fronts set at 0.85" with factory springs and tire size. I swapped over to factory sized BFG ATs when I put the shocks on. I love the looks, ride, and gas mileage didn't suffer because of it.
It's exactly what I wanted.
N2TRKYS is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 07:39 PM #27
Harrisnc Harrisnc is offline
Harrisnc will become famous soon enough
Harisnc,
Thank you!
I used the 1.6 setting but I’m closer to 1.75 than 1.5. The rear springs are the ones from the 4th gen kit. 1/4” shorter.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
Harrisnc is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 08:35 PM #28
Thank you!
Yes stock size C load KO2’s. I did not record the measurements unfortunately, but the springs were pretty dead on as advertised.
2018 TRD Off Road
Old 11-08-2019, 09:51 AM #29
Drobs Drobs is offline
Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light
After spending hours reading the Dobinson's thread, I went with the Eibach Pro Truck Lift. It's more or less one size fits all.
Eibach Pro-truck lift
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
Drobs is offline   Reply With QuoteReply With Quote
coils , front , lift , rear , stock
New TRD Pro - Need mild lift options CplTurner 5th gen T4Rs 83 09-05-2017 05:26 PM
Mild Lift w/ KDSS dproberts 5th gen T4Rs 6 12-08-2014 09:16 PM
Mild lift kit? 01sr54x4 Off-Roading 4 08-31-2009 09:38 AM
Really Mild Lift hulk311 3rd gen T4Rs 9 03-22-2009 10:00 AM
