Old 11-06-2019, 10:01 PM #1
carlodonz's Avatar
carlodonz carlodonz is offline
Real Name: Carlo
carlodonz will become famous soon enough
carlodonz's Avatar
Real Name: Carlo
Question Adjustable Height Lift - Suggestions?
So, it is finally time to go for a proper lift for my 5th gen 4R and I'm currently shopping around for some options.
My requirements:
  • cost: around $1500
  • has to improve ride quality and reduce nose dive/body roll
  • has to improve off-road performance (of course!)
Ideally, I would like to find something that is adjustable after install, or with minimal effort/cost.
I need this because I'm running BGF KO2 256s and for the time being, I would like to go with something like 2" front and 1" back, but eventually when (hopefully) going with a 285/295, I would like to have for example 3" front and 2" back, without having to buy a new lift kit.
Does something like this even exists?
Thank you for you help!
2014 4Runner Trail Super White
carlodonz is offline   Reply With QuoteReply With Quote
Old 11-06-2019, 11:15 PM #2
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
My requirements:
That's a super unusual situation. I'm not sure it's ever come up before. You might want to start here though:
https://www.toyota-4runner.org/search.php?f=85
5th Gen 4Runner Lift Buyers Guide - Toyota 4Runner Forum - Largest 4Runner Forum
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 01:05 AM #3
carlodonz's Avatar
Real Name: Carlo
carlodonz's Avatar
Real Name: Carlo
Thanks, I already went through that thread and search a bit but as you said it's kind of an unusual situation
I saw some adjustable lift kits that can be set at different heights but I don't understand if it has to be done pre-installation o can be done after.
If it's too complicated I might just go for an 'in between' setup which would work fine with both tire sizes...
Old 11-07-2019, 09:43 AM #4
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
those threads also include adjustable coilovers
jhguth is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 11:34 AM #5
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
You're going to have to remove the suspension to change ride-height.
Using the threads on coilovers to change ride height is not the correct way to do it; it's just going to set the pre-load super high and have a crappy ride.
llDemonll is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 11:35 AM #6
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
TTBOSS-4R210 - ToyTec BOSS Suspension System for 10+ 4Runner and GX460
2010-UP Toyota 4Runner 0-3.5" Suspension System - Stage 1 | K53061
2010-UP Toyota 4Runner 0-3.5" Suspension System - Stage 2 (Tubular) | K53062T
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
adjustable , back , front , lift , time
Why no adjustable height suspension? elemint 5th gen T4Rs 21 09-19-2015 08:37 AM
Anyone using the 3" lift kit wth Bilstein 5100 Height Adjustable front shocks Dbadtoy 4th Gen T4Rs 3 07-11-2014 05:23 PM
Ahh ... Height control and adjustable tail end height? coconutpete 4th Gen T4Rs 3 02-26-2013 11:49 AM
Tundra Adjustable Bilsteins: amount of lift for stock height springs? Dagobah 3rd gen T4Rs 5 12-08-2012 07:15 PM
New Height Adjustable Full Lift Kit for 4th and 5th gen 4Runners! ToyTec Lifts Toytec Lifts 2 10-08-2012 09:29 PM
