11-14-2019, 01:18 PM
#61
Originally Posted by zonzin
No, mine are factory aimed factory bulbs, they give out just enough light to the sides to improve the visibility in that area where deer jump right out in front of you, 100 feet down the road is covered by the low beams.
Gotcha. Being an old guy, I wouldn't be able to react to a deer jumping out in front of me that closely unless I was just idling along - LOL!
11-14-2019, 01:35 PM
#62
Originally Posted by 17KT4R
Your info is appreciated, there are obviously a multitude of factors present with these so called 'upgrades' but there are certainly better options than others and I think you get what you pay for with the DD product. After looking into the R&D that they seem to be doing with their lights, it's the reason I made the choice and as I said - they appear pretty darn close to the OEM halogen shine on the road ( I wear a tinted visor at night on the motorcycle so I consider my night vision to be half decent LoL ).
So why even change then? Personal choice, I just don't like the halogen look so I'm on that side of the fence.
https://www.youtube.com/watch?v=eytcPqKD4k0
Well if nothing else you've proved my original point quite well so thanks I guess
11-14-2019, 02:27 PM
#63
angerbot, What do you think about just doing an H9 conversion instead? We can easily fit them by removing the bulb tab.
11-14-2019, 02:40 PM
#64
H9 bulbs will indeed outperform the H11 bulb swaps but at the cost of increased glare. They'll exceed what is street legal so I wouldn't recommend them.
FWIW I've been running the GE Megalight +130s and I live in the mountains where there are no street lights. I don't feel I need more light, certainly not enough to justify blinding other road users.
From my understanding, the H9s may be alright if you aim them downward slightly, but I have not tried it/seen data.
12-01-2019, 03:52 AM
#65
Thank you so much! Your picture and data is fantastic.
12-01-2019, 08:58 PM
#66
Real Name: Jeff
Real Name: Jeff
With all the research I’ve done on lighting over the years, I still allowed myself to get suckered into trying a set of the Diode Dynamics SL1’s in my 2013. It only took two weeks before I pulled them and went back to halogen. The color temp made my eyes feel strained and they certainly didn’t light up the road any better. Currently I am running a set of the Osram Night Breaker Laser H11’s and have no complaints. It was the post on hidplanet showing what you posted here that steered me toward the Osram bulbs. Another downside to running H9’s is that they produce more heat due to being a higher wattage bulb. With that in mind, I didn’t want to run the risk of having to purchase new headlight housings due to burned reflectors.
2015 Limited, bone stock for now
12-02-2019, 01:59 PM
#67
Forgive me if this has been asked as I didn’t comb through all 5 pages of this.
Where do LED conversions like what Kustom 54 lighting does fall?
12-02-2019, 07:15 PM
#68
Real Name: Jeff
Real Name: Jeff
This thread is pretty much about led replacement bulbs for the factory headlight assemblies. The Kustom 54 units use Morimoto MLED projectors which are purpose built to get the most performance out of the led chips. Based on that fact alone, the MLED projectors will probably outperform any drop in bulb in the factory housings.
12-02-2019, 07:19 PM
#69
That makes sense, thanks.
I wasn’t sure if would be considered the same since they’re going into a light housing not made for LEDs, but since those lights are essentially self contained the housing doesn’t matter?
01-02-2020, 08:59 PM
#70
Get GE Megalights, or Philips X-Treme vision H11 bulbs
Does anyone know why GE Megalight +130 H11s are impossible to find right now? No one has them in stock.
2018 Toyota 4Runner SR5 4WD, Black, 3rd row seating
Valentine 1 Gen 2/Savvy/concealed display hardwired, with custom power button. DRLs disabled. H9 / 9011 bulbs. Automatic locks disabled. Center console and glove box organized. Custom garage door opener button. Nav wire mod hack (with custom button). CarTrimHome motorized folding mirrors. Anytime backup camera with front parking camera & custom OEM-matching backlight LED.
01-02-2020, 10:28 PM
#71
I bought my low beams from Headlightrevolution.com. They posted a YouTube video where they tested dozens of aftermarket LEDs and found a set that had the correct throw and cut off. Yes they are bright, but my wife’s 2019 Subaru with stock low beams gets flashed all the time. I was flashed maybe twice in 18 months.
01-03-2020, 01:47 PM
#72
Real Name: Chris
Real Name: Chris
Plus, MLED projectors are designed with cutoffs to not blind oncoming drivers
01-03-2020, 04:57 PM
#73
Originally Posted by thennen
Good information, OP! Thanks for sharing.
I, for one, can’t stand most of the “blue” headlights I see because they’re mostly too bright, poorly aimed, and as you describe, unevenly lit (the word faceted comes to mind). It seems many or most of these folks are happy because their world is all lit up. They don’t seem to consider that the people flashing high-beams at them are doing so for a reason.
Perhaps an even bigger pet peeve is fog lights. Probably 98% of the time I see them, it’s a clear night with no rain, fog, snow, or dust. Perhaps the drivers think it looks cool. The fact is that it’s simply too much oncoming light on a dark road, regardless of how they’re aimed. It’s not cool, it’s idiotic if conditions are clear. They’re called fog lights for a reason.
Unfortunately, there’s no easy way to educate everyone on proper lighting usage. But thanks for contributing good info!
i run my fogs always. they put light against the road close to the vehicle. ive toggled them on/off a few times to see how it is, and it IS better with them on.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
01-03-2020, 07:41 PM
#74
I’ve been doing a some research on this and I think I’m going to go with Philips h11 and 9005 crystalvisions halogens.
Do these seem like the right choice? I want something brighter than stock but I don’t want to be blinding anyone with LEDs. Any help much appreciated.
01-03-2020, 07:51 PM
#75
Real Name: Jeff
Real Name: Jeff
Check out the Osram Night Breaker Lasers or the GE Mega Light +130’s for a good H11 replacement. Either one should be under $40 on Amazon. For the 9005 highs you can easily modify a set of 9011’s. So far I’ve been very happy with the Osram’s and 9011’s. Both are brighter than the standard H11 and 9005 setup.
