Old 11-25-2019, 11:34 AM #31
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Originally Posted by RusPro17 View Post
I’m leaving mine on for now. I would put some miles on it first before changing it out. If you do change it I don’t see why it is not a even swap getting the other Toyota exhaust that was used for the older Pros.
Should fit.
The tailpipe will not bolt up. The TRD muffler has three bolts connecting the tail pipe to the muffler, the regular 4runner muffler has two bolts connecting the muffler to the tail pipe. It would have been nice if Toyota made the parts interchangeable. I would like the TRD muffler with the rear exit exhaust. It can't happen because of the way Toyota made the TRD muffler tailpipe connection.
Adding...... A 2020 TRD Pro exhaust can be swapped out, from the cat back, including the tailpipe that goes straight back.
'20 TRD Pro Exhaust-trd-tailpipe-2020-jpg
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 01:07 PM #32
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
So if you want to change it out. Can you still replace the whole exhaust? Or can you not even do that? Thanks for the heads up.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 02:10 PM #33
Yep, from the cat back using the straight tailpipe.
1999 4runner
Old 11-25-2019, 02:15 PM #34
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough
Real Name: Jason
Theoretically, you should be able to replace one of the flanges, either from the muffler or the non-TRD OEM exhaust from muffler-back to get these to mate. Looking at the photos, the flange appears to be a sleeved unit.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 08:06 AM #35
jros3484's Avatar
jros3484 jros3484 is offline
jros3484 is on a distinguished road
jros3484's Avatar
Maybe I’m missing something, but I bought this exhaust to put on my 19.
Unbolted old one... bolted up this one. Fit perfectly. No modifications to flanges, etc. I see zero reason why someone couldn’t take a stock exhaust (from a 19 at least) and bolt it on a 20. Also can’t imagine a difference between a 19 exhaust and other fifth gens. But have no specific knowledge of that. Only that there are zero issues with a 19 fitting.
Also, doesn’t sound bad to me at all. I actually really like it. Different strokes. Have about 4,000 mi on it. (I drive a lot). Definitely seemed to smooth and mellow out. Either that or I’m used to it. Seems quieter.
jros3484 is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 09:35 AM #36
Real Name: Jason
Real Name: Jason
What I had gathered, someone was looking at the potential of bolting the non-TRD muffler-back to the TRD muffler because they were looking at a rear exit with the TRD muffler characteristics. This is where they highlighted the difference in flanges to make this work.
Old 11-26-2019, 12:30 PM #37
gSwift's Avatar
gSwift gSwift is offline
gSwift has a spectacular aura about gSwift has a spectacular aura about gSwift has a spectacular aura about
gSwift's Avatar
I just swapped my stock TRDP exhaust with a standard exhaust from a forum member here. No issues with the swap as long as you swap the full exhaust from the muffler back. As stated above, the standard exhaust flange bolts to the tail section using 2 bolts. And the TRDP exhaust bolts to tail section using 3 bolts.
@Brabbit took some pictures with both exhausts side by side before we reinstalled them. I'm sure he will post up the pictures after he wraps up his Thanksgiving festivities
gSwift is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 12:43 PM #38
Real Name: Don
Real Name: Don
Thanks Gswift,
That’s what i was asking if you do the whole exhaust swap I did not think it would be a problem. Because if the TRD exhaust gets to be annoying then you can just swap it out like you did. Thanks for confirming that!! Also did you have any issues coming out where the tail pipe ends. Does it come straight out the back like the old Pro exhaust? Thanks
Old 11-26-2019, 01:34 PM #39
gSwift's Avatar
gSwift's Avatar
Thanks Gswift,
No problems at all. All of the hangers for both exhausts are the same. You just need to take off the right rear wheel/tire and then make sure you get it jacked up high enough that you can rotate it out and over the axle. Theres also a small heat shield that shields heat from the spare tire that comes off with two 12mm bolts.
I thought we were gonna have to drop the spare but we were able to get it out without doing that. We probably had both exhausts off and reinstalled in like an hour or so.
Old 11-26-2019, 02:15 PM #40
Real Name: Don
Real Name: Don
So I take it the TRD exhaust got to you. You did not like it. You don’t have many miles on your Pro correct. I’m picking mine up tomorrow.
Old 11-26-2019, 02:30 PM #41
gSwift's Avatar
gSwift's Avatar
It's got 3000 on it now. I'm just not a fan of V6's with "performance" exhausts in general. Plus, I live around a decent amount of hills, so with the way the 4Runner is constantly searching for the most efficient gear, it gets annoying hearing the exhaust note.
I didn't buy the TRDP for performance, I wanted a Pro for the Army Green. I didn't want my daily driver making noise, that's what my straight piped C7 Z06 is for.
Old 11-26-2019, 02:37 PM #42
Real Name: Don
Real Name: Don
I agree. What year is your Z06? I have a 19 Z06. Love it. Have had Corvettes for a long time and Toyota’s.
Old 11-26-2019, 02:44 PM #43
vipers28 vipers28 is offline
vipers28 is on a distinguished road
Well shit, if someone is in my AO and wants a Borla S and trade for stock, LMK! And I also have a Gibson sitting in the garage that I want to get rid of, but it would need a little weld as I had to cut a piece of it.
vipers28 is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 03:16 PM #44
gSwift's Avatar
gSwift's Avatar
Mine is a 2017...I love mine as well! Most likely gonna move up to a C8 whenever they release a Z
Old 11-26-2019, 06:52 PM #45
Real Name: Don
Real Name: Don
Sounds good. I will be keeping my Z06 for a long time. I don’t see myself moving up. I love my manual beast. But good for you if you get one!!
drone , exhaust , long , pro , trd
Exhaust Sounds From Outside Above Exhaust liqourish 4th Gen T4Rs 4 06-13-2017 07:03 PM
4runner exhaust vs highlander exhaust bgibbs11 General Discussions 0 07-01-2013 01:09 PM
Trade my Borla Dual Exhaust for your stock exhaust Sarasota Pimp Zone 1 06-17-2011 03:53 AM
Will trade my Magnaflow exhaust for a stock Toyota exhaust vpritchina Classifieds - buy & sell (no commercial ads please) 31 07-19-2008 01:31 AM
TRD Exhaust Vs. Aftermarket exhaust warrior3313 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 01-25-2008 11:07 AM
