Shot in the dark here cuz I feel your pain...have you checked every fuse using a voltmeter set for ohms preferably with the continuity beep on? Pulled the negative terminal off the battery, said a prayer and checked it in the morning? Beyond that it gets spooky if you don’t know what 2 wires shorted..if you do then we need some schematics.
Just to help others avoid this easy mistake always disconnect the negative terminal of the battery before working on the truck.
2015 TRDPRO SUPER WHITE ~ ROOF RACK DELETE ~ REAR SEAT DELETE ~ LED ANYTIME FOGS ~ DRL DISABLE ~ DOMETIC CFX-28 ~ BORLA CAT BACK ~ SPRINT BOOSTER V2 ~ aFe MOMENTUM GT INTAKE ~ OTHER JUNK N STUFF
