I’ll throw my 2 cents.
I don’t have a snorkel on my 4Runner yet but my friend has one on his with a AEV Prefilter. However I do have a USMC M1044 HMMWV that does have a snorkel and I have done a deep water river crossing.
DUST
My friends and I often travel off road in the Nevada desert and there is always a fair amount of dust but when you are in a groups of vehicle and your behind the lead vehicle there is a lot of dust! In these conditions a snorkel really does help. I know with my 4Runner I have to tap the dust out of my filter every now and then. Not my friend. Also, as I mentioned he has a AEV prefilter which he thinks helps even more. He said he also doesn’t have to worry about rain or snow with it either.
WATER CROSSING
If you’re going to do water crossings there’s more you need to do than just add a snorkel.
Before I get a snorkel the first thing I would invest in is adding breathers for your transmission and differentials. If you bust a seal and water gets in it can be a mess because at minimum you will have to replace all your fluids plus the seal or seals! In my case I didn’t realize my breather had popped off my transmission previously from off roading and the nipple clogged with mud. So when I did a river crossing the seal leaked and I got water in my whole hydraulic line. Also I didn’t know at the time about letting the engine cool before going in. I thought military vehicles were indestructible. Wrong! It ended up costing me about $1,500 to replace all the fluids, seals and I decided to replace all the breathers too. (The joys of owning a old military vehicle)
The next thing you need to do is modify your exhaust. As long as your engine is running there is no problem. The exhaust pressure will keep the water out but if your engine stalls and you’re deep enough, water will flow too your engine and ruin your day. Ideally you want to have a exhaust that is as high as your snorkel but this is impractical mod for most people not to mention it’s can be expensive if you want to make it look nice. I’ve heard of rubber hose attachments that you can put on your exhaust. It’s just a temp mod to use only when crossing. I also saw a guy modify his exhaust pipe by putting it in his wheel well. I basically worked as a upside down “P” pipe. So if the engine stalled it would trap air in the P and prevent a water back flow.
Now if you go into deep water you should disable your fan. If you don’t you could possibly break the fan blades when it hits the water if they are spinning fast. I think many newer cars the fan only comes on when needed. So letting your engine idle should turn it off. The USMC HMMWV has a snorkel switch which turns off the fan to prevent just that. Also if your fan is real close to the radiator it can pull forward when it hits the water and damage the radiator.
Someone also mentions that you should also waterproof some of you electrical connections too although I don’t have much knowledge in this area. With military vehicle all their wiring is already water proof.
Also, avoid letting water get into the vehicle. It will smell like stinky river afterwards. (Not to mention the electrical gremlins it will create.) The one time I did a river crossing the water flooded inside, which the HMMWV is designed to do, and my vehicle reeked for months after that.
So as far as water goes, if you are planning to go in water as deep as your snorkel you need to think about a lot of other things. Here is a good link to check out on water crossings. It seems the Aussie love crossing rivers.
Water Crossings in your 4WD
That said, I like snorkels. I think they add to the macho factor big time. And throw a AEV prefilter on top of that, is icing on the cake!
One final note. With the ARB or Dobsinso. Snorkels, they do stick out a fair amount on the side. You have to use caution when going down a tight trail. A guy I know side swiped a tree with his snorkel. While the snorkel was fine it push in his fender. I’m guess it wasn’t a cheap repair.
So final verdict.
Help with dust? Yes. Prefilter? Even better!
Moderate water crossing? Sure. It will keep the splash water out. Deep water crossing? You need a whole lot more than a snorkel.
Macho factor? Absolutely!
