Old 11-13-2019, 07:44 AM #31
onemoreokie onemoreokie is offline
onemoreokie is an unknown quantity at this point
2019 TRD Pro. Not many miles so I haven't noticed many unusual noises, but man is the engine loud at cold startup/idle.
It causes my kid to cover her ears and run when I fire it up in the morning.
onemoreokie is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 07:57 AM #32
JPGood's Avatar
JPGood JPGood is online now
JPGood is on a distinguished road
JPGood's Avatar
when it rain or drivers side window is wet it squeaks when being rolled down. All other windows OK when wet. There is no noise when dry.
JPGood is online now   Reply With QuoteReply With Quote
Old 11-13-2019, 01:01 PM #33
Mack1611 Mack1611 is offline
Mack1611 is on a distinguished road
I get a high pitched whining that intermittently emanates from the front passenger seat.
Mack1611 is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 02:05 PM #34
lunchboxtheman lunchboxtheman is offline
lunchboxtheman is on a distinguished road
Originally Posted by JAXJeremy View Post
Great thread!!!
I've got a noise that sounds like a rustling piece of paper, it's on the drivers side and I can hear in the cabin with the windows up and the radio off..at fisrt I thought it was some leaves caught near the base of the windshield under the hood, cleared a couple out but it's still there..real head scratcher..
I have the same issue! I’m so glad it’s not just me. I only hear it on the highway when there’s lots of airflow which is why I too thought it was leaves but no dice. I even popped off the grills to the dash speaker to see if the speaker was lose but it was plenty tight.
Drives me absofrickenlutely mad.
lunchboxtheman is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 03:07 PM #35
austinquick austinquick is offline
austinquick is on a distinguished road
The brake pedal squeak. The first half inch of travel makes a small but very distinct squeak/hiss.
austinquick is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 03:12 PM #36
SLC Punk SLC Punk is offline
SLC Punk is on a distinguished road
Originally Posted by omaguz View Post
Had a squeeking sound that I thought was coming from the front driver side suspension componenents. Went to the dealer for the 30k maintenance And explained the sound to the tech. Turns out it was the driver side hood mechanism, they apparently lubbed it up and the sound was gone. Go figure!!!
Same here. I lube the hood latch and hinges monthly or the sound comes back
-Travis
2014 4Runner TE: 275/70/17 KO2's, 5100's 2.5" front/1.5" DS rear, Spidertrax spacers, nFab Steps, FrontRunner Slimline II, Gobi Ladder, TRD Intake, Borla Catback, Pedal Commander, TRD Pro: Wheels, Skid, Grille
2018 Audi S5 Sportback, 1978 F250 Custom
SLC Punk is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 06:15 PM #37
quicksandTRDPRO's Avatar
quicksandTRDPRO quicksandTRDPRO is offline
Real Name: Trent
quicksandTRDPRO is on a distinguished road
Real Name: Trent
I have a faint rattle that sounds like it is behind my gauge cluster or steering wheel, what almost sounds like wiring ticking or tapping against plastic, i have no mods anywhere in the area. It's definitely more noticeable when cold. I have checked all the usual suspects with the window, under the hood, the wheel wells etc. I haven't figured out what it would be though.
2016 Quicksand TRD PRO
quicksandTRDPRO is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 07:18 PM #38
Grape Ape Grape Ape is offline
Grape Ape is on a distinguished road
As I previously posted, its the Vortex Generators on the mirror and mount.
Grape Ape is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 08:40 PM #39
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 will become famous soon enough
Real Name: Dave
‘18 SR5. Whenever somebody uses the rear passenger side seatbelt and removes it, the tang that goes into the buckle hangs down and rattles against the door plastic. For some reason Toyota uses weak seatbelt retractors and are reluctant to reel in seatbelt straps all the way without help. My previous ‘02 Tacoma TRD was the same way.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 10:15 PM #40
4RunnerL2016 4RunnerL2016 is offline
4RunnerL2016 is on a distinguished road
Currently, I have a rattle that is driving me nuts! On my 2010, the sunroof always had a bit of movement that would become evident when I went over rough road. They're not quite these 4R's!
4RunnerL2016 is offline   Reply With QuoteReply With Quote
Old 11-13-2019, 10:41 PM #41
photoleif photoleif is offline
Real Name: Leif
photoleif is on a distinguished road
MY GARAGE
Real Name: Leif
MY GARAGE
edit: sorry, posted up to the wrong subforum, gaa.
front-end squeaks when i hit any bumps in pavement. it started after a particularly dusty, bumpy backroad. i need to get the hose and sprayer on it.
'99 4R SR5 5VZ-FE | Manual transmission | mostly-LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm and uniball conversion | Rancho steering stabilizer | Smittybilt front & rear tube bumpers | Sportsman topper | Aisin hubs | Dual Optimas | Extended diff breathers | Custom center console and jumpseat conversion | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 12:08 AM #42
Horsethief Horsethief is offline
Horsethief will become famous soon enough
The god awful sound coming from under the hood. The 4 liter that sounds like it's about to throw a rod.
I also have the splash guard rattle, I'll get around to fixing that soon.
Also had a squeek coming from the driver's door, lubing the weather stripping with silicon spray seems to have stopped it, knock on wood. All in all, very good for a 6y/o vehicle will almost 100k.
The worst part BY FAR is that piece of trash under the hood.
Horsethief is offline   Reply With QuoteReply With Quote
Old 11-14-2019, 07:56 AM #43
omaguz's Avatar
omaguz omaguz is offline
Real Name: Omar
omaguz is on a distinguished road
MY GARAGE
omaguz's Avatar
Real Name: Omar
MY GARAGE
What kind of lube do you use for the hinges and latch???
2016 Super White Trail Edition, non KDSS.
omaguz is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 01:37 PM #44
aceee aceee is offline
aceee is on a distinguished road
2011 and i hear rattles all over my interior. So annoying
aceee is offline   Reply With QuoteReply With Quote
Old 11-15-2019, 03:20 PM #45
tm965 tm965 is offline
tm965 has a spectacular aura about tm965 has a spectacular aura about
i have tis too. for me its the plastic shield at the bottom of the windshield. there are threads on how to deal with it, but none of the solutions were permanent for me. just get a plastic tapping noise over bumps in the cold.
tm965 is offline   Reply With QuoteReply With Quote
annoying , coming , make , noise , rig
Help me not to be annoying!! fightman80 3rd gen T4Rs 4 04-19-2017 07:43 AM
Anyone else think this is annoying? Brian3676 4th Gen T4Rs 28 04-22-2016 03:28 PM
Annoying issue yotallycrazy 3rd gen T4Rs 5 05-30-2014 01:08 PM
Annoying ads on T4R.ORG? fightman80 General Discussions 5 03-18-2014 02:09 PM
annoying squeak dpreich 5th gen T4Rs 5 08-10-2013 05:09 PM
Copyright © 2019
