01-25-2015, 05:31 AM
Driver door light / dome light problem
Having an issue with my driver door light and dome light. I have a 2011 SR5. All other doors work fine. When drivers door is opened, door light does not go on and dome light also doesn't go on.
Swapped door switch from driver to passenger side and switch is good. Bulb is good.
Any clue what could be the problem?
01-25-2015, 09:18 AM
Real Name: Um, Phil?
What are the last 3 mods you've done?
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
01-25-2015, 03:17 PM
Changed out all interior and exterior bulbs to LED's.
01-25-2015, 03:40 PM
Real Name: Jeff
Real Name: Jeff
HERE FISHY FISHY FISHY!
01-25-2015, 07:20 PM
01-25-2015, 07:55 PM
door sensor is sticking... it tells you when it's opened or closed.. you should also not get the red light that shows a door open on the dash if it opens and the light doesn't come on..
2011 TE KDSS NAV- K&N drop-in, Toytec/Eibach, Bilstein 5100's, Diff Drop, 295 Cooper STT Pro, OPOR Sliders, 17X9 XD Addicts, Sonoran Steel Panhard Bar, SPC UCA, RCI Skids
'97 Corolla, 90 Alltrac Celica, 94 Camry, 99 Solara 5spd, 98 GS400, 93 Accord, 97 Avalon(current daily), 2010 T4R LE sold, 2011 T4R TE
01-26-2015, 12:45 AM
Thanks. Yes, no indication on dash when drivers door opened. You mention possible bad door sensor. Is this the same as the door switch? Thanks.
01-26-2015, 01:22 AM
yes!
01-02-2020, 10:25 PM
Hoping to bring this thread back up. I'm having the exact same problem, after having done the exact same mod. I swapped the interior lights out for LED, and while I was replacing the driver door puddle mirror, it seemed like there was a short and now neither the door light nor the door position switch work correctly. Really the issue is that now if I have the headlights on, and I get out of the car, it doesn't know that I've gotten out and so the headlights stay on. I've check the fuses. Any thoughts?
