Old 11-11-2019, 07:33 PM #1
str8flexed's Avatar
str8flexed str8flexed is offline
str8flexed is on a distinguished road
str8flexed's Avatar
Click/pop from front when turning steering wheel
Hi guys, after doing a moderate trail I started hearing a loud click, or sometimes two clicks in succession, when I turn my steering wheel.
It doesn’t happen every time I turn, but it happens maybe a fourth of the time. It happens when I turn to one side more often than the other. It kind of sounds like there is some tension that is released. I can be turning the wheel without the car going forward or reverse and it'll still happen.
It doesn't happen with each wheel revolution, just with extreme wheel turning to the left/right.
This weekend I spent a few hours retightening up the suspension bolts to spec on the left side, and it didn’t make a difference. I did install my own suspension so I was worried something may have loosened. I didn’t get to the right side so I’ll try that next but I didn't think the sound was coming from the right.
The CV and tie rod boots all looked intact but I worry that maybe something inside is broken. I did put my car into a large flex situation on the trail, but I drive pretty slow and carefully so I’ll be surprised if it was damaged.
Any ideas? Thanks in advance.
Click/pop from front when turning steering wheel-74614783_10104772625097847_8713813023753502720_o-1-jpg
2017 TRD Off-Road Premium: Dobinsons lift, Icon UCA, Gobi Stealth, Cooper AT3 XLT 295/70r17, Race Relations Wheels -12 offset 8.5”, CBI front bumper, Xenon HID headlights, RCI skids, RSG sliders, Focal 690TOY front speakers, Kicker DS rears
str8flexed is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 08:40 PM #2
ProfessorP's Avatar
ProfessorP ProfessorP is offline
ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough ProfessorP is a jewel in the rough
ProfessorP's Avatar
Exactly what suspension bolts did you tighten? Lots of stuff to tighten on each side. Miss one and that could be it.
Did you tighten the long upper control arm bolt?
ProfessorP is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 08:45 PM #3
str8flexed's Avatar
str8flexed's Avatar
I retightened everything except the few bolts that had a metal rod going through them through them, like the one in between the two LCA bolts and the tie rod one (I think). Yes I tightened the UCA bolt, and also regreased the bushings because they were squeaky...
Old 11-12-2019, 05:15 PM #4
matoolie's Avatar
matoolie matoolie is offline
matoolie has a spectacular aura about matoolie has a spectacular aura about
matoolie's Avatar
Retorque LCA bolts. 130lbft. Cam bushings will not move.
Michael
2021 Pro Lunar Rock: RCI tranny/transfer case/tank skids, Victory roof rack
2014 LE Nautical Blue: 285/70R17 Falken A/T3W, FX Pro wheels, Fox TRD Pro suspension with Wescott lift, Dobinson UCA's, Metal Tech sliders
matoolie is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 05:43 PM #5
str8flexed's Avatar
str8flexed's Avatar
You know, I did that last night and think it fixed the problem. Those bolts are so tight that they clunk when turned initially. I’m glad that was it and not any CV axles or anything that are broken!
Old 11-13-2019, 05:03 PM #6
matoolie's Avatar
matoolie's Avatar
That was just little bit of binding releasing itself. One of my bolts did that too after I torqued them to spec. after an alignment at Toyota dealer where the tech did not torque them correctly. The high torque on the bolts prevents any inappropriate slipping within the bushings (metal washers, sleeves, brackets) and forces all movement in the rubber bushings, which are designed to flex and twist....quietly.
Michael
happen , side , turn , turning , wheel
Steering wheel noise when turning Mutt B 4th Gen T4Rs 3 07-02-2023 09:30 PM
Squeaking when turning the steering wheel jeeper1 3rd gen T4Rs 18 04-18-2023 10:20 AM
Click/pop from front when turning steering wheel str8flexed 5th gen T4Rs 0 11-11-2019 01:34 PM
Loud Creaky steering wheel when turning superg3 4th Gen T4Rs 7 02-05-2014 08:12 PM
difficulty turning steering wheel miagi Problems & Warranty Issues 3 04-09-2008 07:07 PM
