Old 11-12-2019, 04:59 PM #16
ax2021 ax2021 is offline
ax2021 will become famous soon enough ax2021 will become famous soon enough
Originally Posted by Bruin1md View Post
That's exactly what I was debating: getting wider wheels with 285 tires and a negative offset. But won't that put the same strain on the wheel bearings as putting spacers would do? Plus, like you, it's hard to justify doing that on a brand new truck.
I love the TRD pro wheels and don't want to get rid of them unless I could get the same wheels in an 8" diameter. I don't know why they made them 7" for us.
P.S: you will love the AG Pro
Well that is my problem was too,that make me not to buy TRDP back in 2018. I mean you paying all those $$$ just for better suspension as dealer was saying. I just went the other way. I got 2018 TRD ORP, suspensions cost nothing, installed some Kings 2.5 , 285/70 Falkens M/T ,got ~3” front lift, installed 1” taller spring on rear and got ~ 6k in my wallet,in case if I bought TRDP . Well about the spacers they will make your rubbing even worth. I had those for 3 months and took them off . One thing for sure you will have to lift front at least 2”-2” in order to fit 285/ 70 on TRD PRO rims. But it is possible, I did on mine
ax2021 is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 05:14 PM #17
MGordo MGordo is offline
MGordo has a spectacular aura about MGordo has a spectacular aura about
Not an answer thats 100% complete since nothing is installed (and truck only arrived at the dealer today) but what I ordered is the Eibach 1" lift rear coil and 2" front cornfed spacer. I plan on going to the front Eibach lift coils when they are released for a simple lift that still works with the stock Fox.
Main reason I did this was to fit my upgraded wheels & tires a bit better. (18x9, 0 offset) and 285/65/18 tires.
MGordo is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 05:22 PM #18
I hope it will work for you. I am just don’t like spacers at all. But it is me . Good luck with your modes!!!
Old 11-12-2019, 05:23 PM #19
dehoopta dehoopta is offline
dehoopta is on a distinguished road
Spacers for lift and not for width
I wasn't very clear in the OP. It was recommended to place a 2 inch spacer for lift, not a wheel spacer kit. My fault for the confusion. Carry on and thanks for the feedback. It is invaluable.
It was mainly for looks and not function. I wouldn't want to lose function for looks.
dehoopta is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 05:30 PM #20
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
Yeah I cannot wait. Not sure about that. But I would think running the bigger tires put more a strain on the truck and your gas. I know when when I had SCS wheels on my Tacoma with 265-70-17 same size as the 4runner with that 8.5 inch wheel my truck looked much better with the wheels making the tires fit at better stance. It’s a tough call.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 05:38 PM #21
That’s why I don’t want spacers anywhere. It definitely gives you the look, but functionality will be poorer. I had spacers on front, on rear and wheels. Took them all off driving so much better. I just after quality right now. If you want hight get longer,higher grade springs and aftermarket UCAS. Thanks
Old 11-12-2019, 05:56 PM #22
Yeah it definitely gives your 4RUNNER Bad ass look. I love it . But like someone already said. Bigger tires , bigger rims that’s great, just make sure you have enough motor to push it. Those are Heavy rims and tires. Your truck won’t run the same. But I like that stands!!! Thanks
Old 11-12-2019, 07:19 PM #23
Front spacer is meant as a stop gap until Eibach releases their front lift coil.. Not meant to be long term at all. I really like the ride of the Fox suspension and just want a bit more height.
Old 11-12-2019, 07:36 PM #24
Yep. That’s the way to do it. I got Eibach springs on rear so far like them. Much better then OEM holds the weigh, and almost doesn’t sagging when loaded. Good choice!
Old 03-29-2020, 12:54 PM #25
feelingstoned's Avatar
feelingstoned feelingstoned is offline
feelingstoned is on a distinguished road
Originally Posted by The_Green_Wang View Post
Lifting your 4runner will bring your wheels closer to the body. To solve this, running spacers can help but may even widen your stance making your wheels turn further out and hitting your bumper. This is solved by the fender mod so lift it and put wheel spacers on. You wont regret it
Running spidetrax spacers and a 2.5ish lift.
Sent from my SM-N970U using Tapatalk
Do you by any chance have links on your lift and wheel spacers? Seems everything I find doesnf fit the pro models
Sent from my SM-G975U using Tapatalk
feelingstoned is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 03:00 PM #26
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
I did Burtman Industries 1.5”/1” spacer lift on my Pro and I really like it. I have 275 KO2’s and fully articulated off road there is no contact. Spacers will create a rubbing problem. I did not want to remove my mud flaps or make any other modifications. Fender liner mod is already done on the Pro. With the combination of the E rated tire and the spacers, it does ride slightly rougher. I have been running this setup for 15 months without issue. It was only $400 for the spacers, installation and alignment. I personally like the look of the Pro wheels and the offset offers no problems clearing the UCA’s and the body mount.
Spacers on a 2020 TRD Pro-8c916479-3ca8-4b71-8c99-b44048b2a480-jpg
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 03-29-2020, 05:15 PM #27
CRB Racing CRB Racing is offline
CRB Racing has a spectacular aura about CRB Racing has a spectacular aura about
TRD PRO 5th Gen
Get the corned 2/1.5 kit and don’t look back.
It will stiffen up the suspension a bit. Road manners become better with less body roll and nose dive.
I have some rubbing on the front bumper, but only at full lock in reverse.
I’m running 285/70x17
CRB Racing is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 11:19 AM #28
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
I've lifted every 4x4 vehicle I have ever had. It has changed the ride quality every time. When I was younger I didn't care. I bought the Pro for the suspension. I wish it was taller and had a better stance, but I love the ride quality so I'm not touching the suspension at the moment.
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 04-01-2020, 11:27 AM #29
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
The truth about spacers:
-they can make rub worse
-they can fail if improperly installed and/or torqued
-many tire shops and some dealers won't work on a vehicle with spacers, the others may damage the studs with an impact gun by overtorquing the hell out of the wheel nuts
-they provide mostly a cosmetic appearance as widening the track typically won't affect a properly aligned vehicle
-your truck, your money, your time
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 04-03-2020, 11:45 AM #30
TRDHULK's Avatar
TRDHULK TRDHULK is online now
TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold
TRDHULK's Avatar
This thread got confusing.
I think the OP was initially asking about a spacer LIFT (Cornfed, ToyTec etc), not wheel spacers (Spidertrx etc. )
It seems most of the responses are referring to wheel spacers and not a spacer lift.
I am getting a 2020 TRDP after selling my 2016 Taco TRDOR. My Taco had a 3 inch lift kit with 275/70/17 KO2s and had a great look. I would like to see my 4Runner look as aggressive. I don't necessarily want to replace the FOX suspension to get the lift, and the parts and accessories guy recommended adding a 2 inch lift with spacers. The ride will be a bit stiffer but otherwise should be good to go. I would love to hear your opinions.
To the OP:
If you want to maintain TRD Pro capabilities and ride quality but want it to sit higher, spacer lift is the answer. It seems 2019 and 2020's are different than previous year TRD Pro's, so the options are very limited.
I'll be doing the Cornfed or Westcott Designs spacer lift kit in the next few weeks to my 2020. Haven't decided which one yet and was planning on starting a thread asking about opinions.
Cornfed 2" front 1" rear: $129
Westcott 1.5" front 1.25" rear: $350 (advertised to be different than a spacer lift, but same concept IMO)
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
TRDHULK is online now   Reply With QuoteReply With Quote
hear , inch , lift , spacers , taco
2020 tss-p GetOut 5th gen T4Rs 10 08-04-2020 07:22 PM
Got my 2020 PRO! Araj82 5th gen T4Rs 32 10-21-2019 04:42 PM
Need help with 2020 Venture T4Rsoon 5th gen T4Rs 6 08-30-2019 04:53 PM
2020 TRD PRO or 2020 GX460.... What do?!?! spc54 5th gen T4Rs 35 08-13-2019 08:58 PM
Will the 2020 off-road have the camers like the 2020 Tacoma? jmichael99 5th gen T4Rs 15 08-13-2019 03:42 PM
