Old 04-03-2020, 12:30 PM #31
BlueEyedDevil's Avatar
BlueEyedDevil BlueEyedDevil is offline
BlueEyedDevil is on a distinguished road
Originally Posted by LandCruiser View Post
The truth about spacers:
-they can make rub worse
-they can fail if improperly installed and/or torqued
-many tire shops and some dealers won't work on a vehicle with spacers, the others may damage the studs with an impact gun by overtorquing the hell out of the wheel nuts
-they provide mostly a cosmetic appearance as widening the track typically won't affect a properly aligned vehicle
-your truck, your money, your time
The OP is asking about LIFT spacers.
BlueEyedDevil is offline   Reply With QuoteReply With Quote
Old 04-03-2020, 12:44 PM #32
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser is a splendid one to behold LandCruiser is a splendid one to behold LandCruiser is a splendid one to behold LandCruiser is a splendid one to behold LandCruiser is a splendid one to behold LandCruiser is a splendid one to behold LandCruiser is a splendid one to behold
Real Name: Sparky
Lockdown has made me take up day drinking.
Apologies.
Throw yourself a dip son!
LandCruiser is offline   Reply With QuoteReply With Quote
Old 04-03-2020, 01:12 PM #33
Apologies.
Lol, me too.
Old 04-29-2020, 06:54 PM #34
dehoopta dehoopta is offline
dehoopta is on a distinguished road
Originally Posted by TRDHULK View Post
This thread got confusing.
To the OP:
If you want to maintain TRD Pro capabilities and ride quality but want it to sit higher, spacer lift is the answer. It seems 2019 and 2020's are different than previous year TRD Pro's, so the options are very limited.
I'll be doing the Cornfed or Westcott Designs spacer lift kit in the next few weeks to my 2020. Haven't decided which one yet and was planning on starting a thread asking about opinions.
Cornfed 2" front 1" rear: $129
Westcott 1.5" front 1.25" rear: $350 (advertised to be different than a spacer lift, but same concept IMO)
You read me right. I look forward to seeing what yours looks like and the ride quality before I pull the trigger. Let me know when you do it.
dehoopta is offline   Reply With QuoteReply With Quote
Old 04-29-2020, 07:18 PM #35
BIGpharma's Avatar
BIGpharma BIGpharma is offline
BIGpharma has a spectacular aura about BIGpharma has a spectacular aura about BIGpharma has a spectacular aura about
BIGpharma's Avatar
Spacers on a 2020 TRD Pro
Originally Posted by Cranberry View Post
don't do it....
Been running my 4R now for a year and its hands down my fave vehicle I have ever owned. Literally I was just like you, upgraded to the 4R and wanted it lifted without going away from factory suspension... in the end, I spent well over $5000 experimenting with several different options and by the time I was finished I ended up just going with Bilstein 5100's with a 2.5 front and 1.5 rear.
I did run spacers in the beginning and it was the worst experience I had with suspension. It did not change the ride in any way on the highway, so if someone is arguing that, I would argue they don't actually have experience with spacers. The main issue was noise and durability when in aggressive articulation and off roading.
A spacer set up will only do on the 4Runner if you intend on keeping it parked in a mall. The second you start going on the grass and gravel, your going to notice the clunking and movement they hinder or create.
hear is a write up from me about a year ago on the daystar spacer kit. HERE
Long and short, your not going to find a spacer kit that provides off road quality lift. if your actually going off road, stay with the factory lift on the factory suspension or go full new suspension all around... if your not off roading then you should be ok with the spacers.
Lol bilsteins would be a downgrade from the Pro suspension. He is only looking for a more aggressive look and spacers will work just fine.
I have done spacer lifts on three different 4Runners in the last ten years and it has not created any issues. Ride will remain the same unless you throw on some E rated tires at the same time. Iím definitely not the only one that thinks this.
OP, lift spacers will work great with your OEM Fox suspension.. they are super cheap and there is a reason that hundreds of people in the lifted Pro thread went that route. There are members on this forum that will make custom size spacers to cater any lift you desire.
2015 Limited Blizzard Pearl: TRD-OR 17" | Eibach Pro Shocks | Dobinsons 302/325 | Falken Wildpeak AT3W | Spidertrax |
BIGpharma is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 10:55 AM #36
TRDHULK's Avatar
TRDHULK TRDHULK is offline
TRDHULK is a jewel in the rough TRDHULK is a jewel in the rough TRDHULK is a jewel in the rough TRDHULK is a jewel in the rough
TRDHULK's Avatar
I ended up going with Burtman Industires becasue they are the exact same quality and material as Cornfed, but offered more sizes. I went with 2.5/2". The ride is just a little more firm than I prefer, but I got the look I wanted and fit the tires I wanted, so I'm happy and would do it again.
2020 Army Green TRD Pro | IG: @TRDHULK
34" Yokohama Geolandar G003 MT 285/75R17 | Burtman 2.5/2" Lift | Spidertrax 1.25" Wheel Spacers | Revtek Mudflap Deletes | Adams Ceramic Coating | Sprintbooster | + Lots more
TRDHULK is offline   Reply With QuoteReply With Quote
Old 04-30-2020, 08:38 PM #37
Looks great!
Old 05-05-2020, 05:43 PM #38
NAHHT4R's Avatar
NAHHT4R NAHHT4R is offline
NAHHT4R is on a distinguished road
NAHHT4R's Avatar
That looks nice!
2018 TRDOR W/KDSS
NAHHT4R is offline   Reply With QuoteReply With Quote
Old 05-13-2020, 10:29 AM #39
steven350 steven350 is offline
steven350 is on a distinguished road
BUMP: Interested in Westcott FOX TRD PRO LIFT.
anybody have any input on these ?
2020 S/W TRD Pro
steven350 is offline   Reply With QuoteReply With Quote
Old 05-13-2020, 10:38 AM #40
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of
Jetboy's Avatar
Doesn't matter whether the spacer is on top or bottom of the spring - the result is the same. It's just a more expensive version of a spacer lift. Not a better version.
Old 05-13-2020, 11:22 AM #41
NAHHT4R's Avatar
NAHHT4R's Avatar
I have a few friends that has the TRD Pro and they went with that route for a few years before they decided to get a lift. When they had that setup, they said the ride is pretty nice and it's not too stiff either. Note that a few years ago wasn't the Fox shocks, but it was the Bilsteins. I have 1 friend that had the Fox shocks and he also said adding a spacer wasn't that bad and the ride was still pretty smooth with a slight stiffness.
2018 TRDOR W/KDSS
hear , inch , lift , spacers , taco
Got my 2020 PRO! Araj82 5th gen T4Rs 32 10-21-2019 04:42 PM
Need help with 2020 Venture T4Rsoon 5th gen T4Rs 6 08-30-2019 04:53 PM
2020 TRD PRO or 2020 GX460.... What do?!?! spc54 5th gen T4Rs 35 08-13-2019 08:58 PM
Will the 2020 off-road have the camers like the 2020 Tacoma? jmichael99 5th gen T4Rs 15 08-13-2019 03:42 PM
2020 tss-p GetOut 5th gen T4Rs 3 08-06-2019 02:44 PM
