Old 11-11-2019, 08:34 PM #1
dehoopta dehoopta is offline
dehoopta is on a distinguished road
Spacers on a 2020 TRD Pro
I am getting a 2020 TRDP after selling my 2016 Taco TRDOR. My Taco had a 3 inch lift kit with 275/70/17 KO2s and had a great look. I would like to see my 4Runner look as aggressive. I don't necessarily want to replace the FOX suspension to get the lift, and the parts and accessories guy recommended adding a 2 inch lift with spacers. The ride will be a bit stiffer but otherwise should be good to go. I would love to hear your opinions.
dehoopta is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 08:58 PM #2
Whippersnapper02's Avatar
Top plate spacers won't change the ride but as with all top plate spacers, you have the possibility of bottoming out and bending the coilovers. Less so with smaller spacers but it can still happen.
Old 11-11-2019, 10:03 PM #3
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
For damn sure it will change the ride.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 10:34 PM #4
RusPro17 RusPro17 is offline
Real Name: Don
RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about RusPro17 has a spectacular aura about
Real Name: Don
Just my opinion. I had that all done to my 15 Tacoma years back. Leave it stock for a while and just put spacers on to give it a better stance with the tires out a little.
RusPro17 is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 12:46 AM #5
Bruin1md's Avatar
Bruin1md Bruin1md is offline
Bruin1md is on a distinguished road
Bruin1md's Avatar
I'm glad the OP started this thread, b/c I'm debating what to do.
New '20 TRD Pro, and wanting a better stance/look with stock wheels/tires, and have been reading a ton about spacers.
I have zero plans to fool with my stock suspension, but I've contemplating putting
My concerns:
1. Rub, even with the stock 265/60/17 Nitto's.
2. Vibrations at higher speeds, which I read on another thread that happened to someone with TRD pro wheels (wonder if the narrower Pro wheels contribute to this?)
3. Premature wearing of the the wheel bearings.........not as concerned about this, as this seems minimal, at best.
Ideally, I would love to do 1.25" spidertrax with 285/70/17's. HOWEVER, I like the performance of the Nitto's more than I thought I would (much better than my prior KO2's), and I would have to sell the set of 5 and spring for a new set of 285's, which I'm not sure about. Second, I'm not sure I have many options for 285's with 7" Pro wheels. I think the one option I did see was the Falken AT3's LT tire (not their P rated tire, which needed a bigger wheel), which allowed for 7" wheels. I have no desire to swap out my stock Pro wheels for aftermarket wider rims.
Therefore, if I do anything now, it would be to keep the stock tires and add the 1.25" spacers, although I'm a bit reluctant based on a couple of reviews in PRO's that c/o of vibration.
Bruin1md is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 01:19 AM #6
Did you mean “when the tires wear out a little”. If not , what did you mean to do once you waited
a while?
Old 11-12-2019, 01:24 AM #7
The_Green_Wang's Avatar
The_Green_Wang The_Green_Wang is offline
The_Green_Wang is a jewel in the rough The_Green_Wang is a jewel in the rough The_Green_Wang is a jewel in the rough
My concerns:
Lifting your 4runner will bring your wheels closer to the body. To solve this, running spacers can help but may even widen your stance making your wheels turn further out and hitting your bumper. This is solved by the fender mod so lift it and put wheel spacers on. You wont regret it
Running spidetrax spacers and a 2.5ish lift.
Sent from my SM-N970U using Tapatalk
The_Green_Wang is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 01:29 AM #8
If you plan on upgrading suspension in the long run (whether performance, looks, both?), just do it now. Not a big fan of spacers but it will effect the ride. The TRD Pro fox suspension is nice... but Fox 2.5 with External res and DSC adjusters is nicer... and adjustable to the lift you want ;) to offset the price there's always someone wanting to buy your suspension.
P.s. I believe since the TRD Pro shocks already give a lift and your adding 2in lift spacer possibly. May need to look into UCAs to return to the factory alignment specs
Old 11-12-2019, 08:38 AM #9
Real Name: Don
Real Name: Don
a while?
Since the 4runner is new with the fox suspension I would leave it like it is now. Just go with spider trac spacers to push the tires out a little for a aggressive look. Then maybe when you get some miles on it then do something with the suspension. I think it is a waste of money messing with a new truck. That is the reason I chose to get a Pro because I did not want to go thru changing everything like I did my Tacoma. Hope this helps.
Old 11-12-2019, 10:20 AM #10
Cranberry's Avatar
Cranberry Cranberry is offline
Cranberry is on a distinguished road
Cranberry's Avatar
don't do it....
Been running my 4R now for a year and its hands down my fave vehicle I have ever owned. Literally I was just like you, upgraded to the 4R and wanted it lifted without going away from factory suspension... in the end, I spent well over $5000 experimenting with several different options and by the time I was finished I ended up just going with Bilstein 5100's with a 2.5 front and 1.5 rear.
I did run spacers in the beginning and it was the worst experience I had with suspension. It did not change the ride in any way on the highway, so if someone is arguing that, I would argue they don't actually have experience with spacers. The main issue was noise and durability when in aggressive articulation and off roading.
A spacer set up will only do on the 4Runner if you intend on keeping it parked in a mall. The second you start going on the grass and gravel, your going to notice the clunking and movement they hinder or create.
hear is a write up from me about a year ago on the daystar spacer kit. HERE
Long and short, your not going to find a spacer kit that provides off road quality lift. if your actually going off road, stay with the factory lift on the factory suspension or go full new suspension all around... if your not off roading then you should be ok with the spacers.
2019 4Runner TRD Off Road / Bilstein 5100 Lift 2.5 F 1.5 R / TRD Pro Front Skid Plate / BFG KO2's 275/70/17R / Rhino Rack Pioneer SX Roof Rack / N-Fab Nerf Bars / Yellow Lamin-X Fog / ARB 12V Compressor
Cranberry is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 01:20 PM #11
brtnstrns brtnstrns is offline
brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice brtnstrns is just really nice
My concerns:
You're likely to rub with spacers on the mud flap even with stock wheels/tires. I just drilled two holes in my mud flap and ran a black zip-tie through them and around the frame rail behind it to hold it back. Got rid of my rubbing. Since you have a TRD Pro, the fender liner should already be pushed forward since they do that at the port when it gets off the ship for Pros.
I get a little shimmy between 55 and 65 mph even with the TRDOR wheels. It's not just a skinny wheel thing. Small balancing issues definitely get more pronounced with wheel spacers.
edit: whoops, just realized this thread is about suspension spacers, not wheel spacers.
Voodoo Blue 2020 Tacoma TRD Off Road
brtnstrns is offline   Reply With QuoteReply With Quote
Old 11-12-2019, 03:23 PM #12
Bruin1md's Avatar
Bruin1md's Avatar
Totally with you-- and it's the main reason I got the Pro. I have no desire to fool with the stock suspension in any way, at least not for the forseeable future.
I'm just wanting bigger tires/wider stance, but the problem is that the 7" wheels on our Pros limit our ability to go bigger than 275's, and the ride on the 265 Nitto's is pretty nice.
It seems as though you kept your stock Nitto's and just put in 1.25" spacers. Did you have to mess with your mud flaps or fender liner (b/c of rub) or were you good?
Old 11-12-2019, 03:25 PM #13
Bruin1md's Avatar
Bruin1md's Avatar
lol-- yeah I thought the same. It wasn't until your edited response that I realized he was talking about suspension spacers.
Old 11-12-2019, 03:28 PM #14
Real Name: Don
Real Name: Don
I did not doing anything to my 17 Pro. When I get my 202 AG coming in shortly I might just do spacers to put the tires out a little. I would rather not do that an get another set of 17x8.5 SCS wheels that are nicer than the TRD wheels. But cannot Justie the money to spend on new wheels when my Pro wheels will be new. So to get that look cheaper would be to buy the spider trac spacers.
Old 11-12-2019, 04:10 PM #15
Bruin1md's Avatar
Bruin1md's Avatar
That's exactly what I was debating: getting wider wheels with 285 tires and a negative offset. But won't that put the same strain on the wheel bearings as putting spacers would do? Plus, like you, it's hard to justify doing that on a brand new truck.
I love the TRD pro wheels and don't want to get rid of them unless I could get the same wheels in an 8" diameter. I don't know why they made them 7" for us.
P.S: you will love the AG Pro
hear , inch , lift , spacers , taco
2020 tss-p GetOut 5th gen T4Rs 10 08-04-2020 07:22 PM
Got my 2020 PRO! Araj82 5th gen T4Rs 32 10-21-2019 04:42 PM
Need help with 2020 Venture T4Rsoon 5th gen T4Rs 6 08-30-2019 04:53 PM
2020 TRD PRO or 2020 GX460.... What do?!?! spc54 5th gen T4Rs 35 08-13-2019 08:58 PM
Will the 2020 off-road have the camers like the 2020 Tacoma? jmichael99 5th gen T4Rs 15 08-13-2019 03:42 PM
