Old 02-13-2020, 11:37 PM #16
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
Originally Posted by niadh0 View Post
refer to my pot here
2019 Pro Basket Rack - Deleted
and jump to post#37 within it for instructions. no need for any additional sealant etc. just make sure to use the OEM rubber washers or equivalent.
Thanks for the info, I read post 37 and not sure I caught it? here you say use factory washer. did you use the metal double hole washer/bracket from the pro?
The black rails I bought had no washer as it was worn off
ForRun is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 01:49 PM #17
niadh0 niadh0 is offline
niadh0 will become famous soon enough niadh0 will become famous soon enough
it depends on what rack you are putting on after removing the pro rack.
- if you are using an after market rack, then use what the rack comes with
- if you are using a 2010-2013 Trail Edition rack then you will need to use the metal-double-hole-bracket before you put the rack on, and then use the rubber factory washers in-between the rack and the bolt.
- if you are using a non-Pro and non-2010-2013-Trail rack (which mean the standard silver, chrome, or the black 5th gen rails), then you do NOT use the metal-double-hole-bracket (that you found under the Pro tack) before you put the replacement rack on, but still use the rubber factory washers in-between the rack and the bolt.
BTW if the factory rubber washers are worn off like you said, then buy equivalent ones from a local hardware store. - or- you can buy a Toyota hardware kit that comes with bolts and the washers.
hope this helps.
niadh0 is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 01:52 PM #18
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
BTW if the factory rubber washers are worn off like you said, then but equivalent ones from a local hardware store.
hope this helps.
I know I'm just swapping my Pro rack for his 2020 Off Road with black rails. I would think the swap would be easy.
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 02-14-2020, 04:48 PM #19
ForRun's Avatar
ForRun's Avatar
hope this helps.
Thanks, I went from pro rack to stock 2019 black rails. They do not sell a washer as the mounting bracket comes with a butyl type gasket attached, brackets cost I think 60 each wholesale. I imagine could have a thin butyl gasket made but I tried it myself and when tightening the rail down it.squished out the sides and did not seal
Old 02-05-2022, 03:45 PM #20
Nole-Runner Nole-Runner is offline
Nole-Runner is on a distinguished road
This thread has been useful as I’m thinking about adding a TRD Pro roof rack, primarily because I haven’t heard of any leaking issues like those with non-OEM racks. Just wanted to make I didn’t miss anything. Has anyone had or heard of any leaking issues when using the OEM rubber washers on the TRD Pro rack?
Nole-Runner is offline   Reply With QuoteReply With Quote
list , pro , rack , roof , swap
2019 TRD Pro Roof Rack JimJr15 5th gen T4Rs 70 04-06-2021 11:16 AM
Waiting for 2020 TRD Pro - should I buy Gobi Roof Rack now? TeamHeq 5th gen T4Rs 66 01-07-2020 12:11 AM
5th Gen 2019-2020 Roof Rack/Basket steven350 5th gen T4Rs 1 09-04-2019 01:01 PM
Rack pads on 2019 TRD Pro roof rack Ri_Bri 5th gen T4Rs 0 04-08-2019 01:53 PM
WTB: 2019 TRD PRO Roof Rack doyoueventraps Want to Buy/Trade 0 01-11-2019 10:29 AM
