Old 11-16-2019, 11:55 PM #1
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
Rear end creak/squeak? Check your bracket for foot brake cable
Just a heads up for those of you that may be trying to hunt down a loud sqeak/creak when rear suspension is cycled up and down. It was affecting my 2019.
Symptom:
Loud creaking noise in rear suspension when cycled up and down. Happens when cycling slow and fast. Sounds like a swaybar bushing; a bit gritty and creaky.
Cause/details:
Check the bracket that holds the rear foot brake cable. The bracket is located right by the rear swaybar link. There's one on each side of the frame rail. Jiggling would reproduce the noise. This bracket puts sideways pressure on the housing for the footbrake cable and when suspension cycles, the cable rubs in the housing. Mine was showing grooves from rubbing.
Solution:
Take pliers and bend the bracket just a little in order to alleviate the sideways tension and thus rubbing. Enjoy your truck again.
I hope this helps someone. My 2019 with 15k miles was making this creaking noise that was driving me nuts. I was down there undoing the swaybar thinking it was the swaybar bushings only to be surprised when the noise was still there with the sway off. When I did find the issue after an hour crawling under and effectively doing bench presses with my truck to cycle the suspension (I was sore next day) I had to facepalm myself because it was in my face all along.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 03:48 AM #2
O2RunnerSR5's Avatar
O2RunnerSR5 O2RunnerSR5 is offline
O2RunnerSR5 is on a distinguished road
I had the same issue. Dealer fixed it, I thought it was a shock
2001 SR5 4x4 Premium
2017 SR5 4x4 Premium
17 SR5
O2RunnerSR5 is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 04:00 AM #3
aaronRR's Avatar
aaronRR aaronRR is offline
aaronRR is on a distinguished road
aaronRR's Avatar
I've got a 19' as well and that noise has been driving me crazy, only happens after off-roading. I'll be sure to check this, as it's pretty loud. Thanks!
@offRoadxp | 2019 4Runner TRDO ⁌ RSG Rock Sliders ⁌ RCI Skid Plates ⁌ ICON Stage 2 Extended Travel w/ SPC UCAs ⁌ ICON Rebound Wheels ⁌ 285/75/17 Yokohama Geolandar G003s ⁌ Prinsu Full Roof Rack ⁌ FSR Evolution RTT ⁌ SSO Offroad Bumper w/ Smittybilt 12k Winch
aaronRR is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 09:36 AM #4
kenwilliams0803 kenwilliams0803 is online now
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Good stuff, I'll check it out. I can hear mine creak every time I get in or out. I had assumed swaybay bushings but this is interesting.
kenwilliams0803 is online now   Reply With QuoteReply With Quote
Old 11-17-2019, 01:47 PM #5
rsimi72 rsimi72 is offline
rsimi72 is on a distinguished road
Symptom:
Cause/details:
Solution:
I hear a squeak from there when slowly rolling over speed bumps. Never when driving. I just assumed noisy springs. Thanks.
rsimi72 is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 01:58 PM #6
stay_tuned stay_tuned is offline
stay_tuned will become famous soon enough
possible for someone to post some pics of the bracket that needs to be bent, i just came across this recently and might be the same thing
stay_tuned is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 02:53 PM #7
Georgiey22 Georgiey22 is offline
Georgiey22 is on a distinguished road
Thanks. I’ve had a similar squeak for ages and couldn’t find the issue. Just jumped under the truck and the brake line definitely rubs the circular bracket and can see the rub mark on the brake cable. Hopefully this does it. Thanks for the hot tip.
2016 T4R SR5 Premium + Bilstein 6112 Coilovers front + Bilstein 5100 Rear + TRD 17" rims + 265/70R17 Nitto AT Grappler G2's + Tinted Windows + OEM Running Boards + Rigid Industries D2 Driving Lights in OEM Fog Light location
Georgiey22 is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 03:53 PM #8
Looking front to back. Same on the other side. Check both.
Kings, Icon UCAs, 285s, full armor, rear diff breather relocation, ECGS diff bushing, Rokmen trailing arms
Old 11-17-2019, 06:23 PM #9
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
I had a weird squeak that I suspected was probably gonna be what you described but it turned out to simply be the spare tire wasnt tight enough and was sliding from side to side. Think I'll spray some white lithium grease on those things anyway.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 11-17-2019, 07:43 PM #10
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
YES, This was it!
I’ve been chasing this squeak for a month. The two brackets were the problems. They were cocked a little to one side and pointed down a bit. With pliers and a long screwdriver I straightened them, tightened the 12mm bolt, and lubed them up with silicon spray. Finally it’s quiet! Thanks for the advice and photo.
Old 11-17-2019, 10:24 PM #11
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
Thanks for posting this up. Will crawl under and check when my wife brings the truck home from Montana this weekend. This noise has been bugging me.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 11-19-2019, 06:19 PM #12
Thank you so freaking much, that picture completely helped just went out and pushed the bracket back a bit and completely got rid of the noise
Old 11-19-2019, 06:20 PM #13
I have an 18 so its probably just 5th gen specific but hit or miss
Old 11-19-2019, 08:00 PM #14
HanginInUtah's Avatar
HanginInUtah HanginInUtah is offline
Real Name: Ben
HanginInUtah will become famous soon enough HanginInUtah will become famous soon enough
Real Name: Ben
This is awesome. I haven't thought about the noise much until I saw this post. I hear it when I'm off road, windows down, etc. Gotta be the same thing. Now I know what to look for!!
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
HanginInUtah is offline   Reply With QuoteReply With Quote
Old 01-24-2021, 07:35 PM #15
412Runner's Avatar
412Runner 412Runner is offline
412Runner is on a distinguished road
412Runner's Avatar
Sorry for the thread resurrection, but I’m not having this large creaking on the left hand side between the front drivers door and rear wheel.
Is this picture of this black representing the “way it should look” or “the way it should NOT look”?
412Runner is offline   Reply With QuoteReply With Quote
bracket , noise , rear , suspension , swaybar
Squeak/creak from front end Rwm514 3rd gen T4Rs 3 08-22-2018 05:20 PM
NV004-03 04/26/2003 Interior - Front Seats Squeak/Creak CBR_GUY_IA TSB 0 07-12-2009 11:01 PM
Rear cabin creak/squeak clem18 Problems & Warranty Issues 0 10-19-2007 10:17 AM
Anyone get seat rattle/creak resolved? ATLRunner Problems & Warranty Issues 7 12-29-2004 12:05 AM
Front Seat Squeak/Creak '03 Limited bluduk15 Problems & Warranty Issues 2 02-04-2004 11:25 PM
