Old 04-16-2021, 11:44 PM #16
Lexington's Avatar
Lexington Lexington is offline
Lexington is a jewel in the rough Lexington is a jewel in the rough Lexington is a jewel in the rough
Lexington's Avatar
By the way, I’m planning to buy and install a snorkel in the next month or so.
For those of you that have snorkels, I’m curious when you are driving in heavy rain or snow if you do anything to prevent excessive water getting into the air vent or experience snow build up. Do you flip the air intake backwards or do nothing at all?
I’ve watched some installation videos and I’ve seen some people drill small holes in the air filter box to drain water from rain.
I noticed the new Tacoma snorkels by Toyota do have a cool little cut near the top that acts as a water drain. Unfortunately Toyota has made nothing for the 4Runner.
Also, what precautions do you take when going to the car wash?
Thanks
Lexington is offline   Reply With QuoteReply With Quote
Old 04-17-2021, 10:19 AM #17
EmotionCRZ EmotionCRZ is offline
EmotionCRZ will become famous soon enough
I live in New England, I have the Safari snorkel. I do not turn the head around when it snows or rains heavily. I have not had any issues. For car washes, I do sometimes use a touchless car wash. You just have to make sure the dryer in the car wash is a fixed unit. The dryers that move up and down to dry will hit the snorkel.
Thanks
EmotionCRZ is offline   Reply With QuoteReply With Quote
Old 04-17-2021, 12:05 PM #18
Lexington's Avatar
Lexington's Avatar
Hi EmotionCRZ
Thanks for this info. Just our of curiosity, so in heavy rain you never have water get into the air filter box or just not enough to create a problem?
Thanks
Old 04-18-2021, 02:19 AM #19
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Thanks
I'd get something like the Snorkel Upgrade Pre-cleaner. Planning on getting it for my Dobinsons snorkel sometime down the road.
Off Road Snorkel Head Air Pre-Cleaner - for Trucks, Jeeps & SUVs.
– Snorkel Upgrade
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 12:00 AM #20
Lexington's Avatar
Lexington's Avatar
– Snorkel Upgrade
Problem solved! Thank you very much for this info SN_85!
Old 04-19-2021, 10:03 AM #21
KB180 KB180 is offline
KB180 has a spectacular aura about KB180 has a spectacular aura about
Tjm
The only problem I see with TJM is if you plan on putting on a full size Gobi rack. The snorkel will be in the way.
Actually, it doesn't interfere with the roof rack at all. I have this setup on mine with the full size Gobi Stealth rack (no rise option), with the wind deflector installed. The installation procedure is a little more complicated as the snorkel tube runs inside the fender well into the air box (TRD Air Box in my case), requiring the fender liner and fender trim piece to be temporarily removed for proper installation.
KB180 is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 12:35 PM #22
alphabeast's Avatar
alphabeast alphabeast is offline
Real Name: Shawn
alphabeast is on a distinguished road
alphabeast's Avatar
Real Name: Shawn
Hi EmotionCRZ
Thanks
The air box has a drain hole in it so if water does get sucked in, it will drain there. Now I know if you are getting a snorkel for water crossings then it would only make sense to plug this hole. For me, I don't plan on major water crossings, but want a snorkel for cleaner air. Where I go its often super dusty and my filter reflects it.
2014 TE w/ KDSS: ToyTec BOSS Suspension Kit / Toytec 1" Body Lift / JBA A-Arm's / Cooper Evolution MT 35" 12.5" / SCS Ray 10 17 X 9 / Budbuilt Bump Out Slider's / Gobi Stealth (No Rise) Rack / Hefty Fabworks Front Bumper / Ellis Precision Auto Shifter & Transfer Case Shifter/ Rigid D-Series LED Fogs / Precision LED Interior Lighting
alphabeast is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 01:51 PM #23
Lexington's Avatar
Lexington's Avatar
Thanks Alphabeast
I don’t plan on taking it through water that deep but I figure if you’re going to put a snorkel on might as well give it that capability. I plan on adding breathers for the diffs and later waterproofing some of the electronics. I will also need to see if I can modify the modify exhaust to see if I need to make a upside down P trap if there is room.
I’ve done a deep water crossing once in my 1986 M-1044 USMC HMMWV. Nice thing about USMC vehicle they are already rigged for it. Just flip the lever to disengage the fan and drive in. Bad thing about them is they are designed flood inside while crossing so they sink to the bottoms to gain traction. My vehicle reeked for months after that. On top of that I didn’t realize my vent tube for the rear diff breather came off and filled it with water. I ended up just flushing and replacing all my fluids after that just to make sure everything was clean. So I’ll avoid deep crossings unless it’s unavoidable.
Old 04-19-2021, 03:32 PM #24
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
This just got published - might be interesting reading for you.
Safari Snorkel from ARB for 5th Gen 4Runner - Complete Install
rageandlove is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 04:09 PM #25
Lexington's Avatar
Lexington's Avatar
Thank you! Very helpful!
Old 04-19-2021, 11:32 PM #26
ruff4runner's Avatar
ruff4runner ruff4runner is offline
ruff4runner will become famous soon enough ruff4runner will become famous soon enough
So Safari and Dobinson is a look, I get it, it's very traditional. The TJM airtec snorkel is very polarizing. The TJM has one thing going for it, it's low profile. I know thats not what your going for, but when you hit that monster flexing bicep on something your quarter panel and door may do some of their own flexing.
Best Snorkel for 5th Gen 4Runner - Safari vs Dobinson vs FTS-screen-shot-2021-04-19-8-08-56-pm-png  Best Snorkel for 5th Gen 4Runner - Safari vs Dobinson vs FTS-screen-shot-2021-04-19-8-13-46-pm-png
2019 TRD ORP with stuff bolted to it and my Alaskan Malamute benevolent overlord, Farley. KN6HZJ
ruff4runner is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 12:00 AM #27
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
if you guys are interested in precleaners, I run a enginaire on my safari snorkel, its way cheaper than the other precleaners that have a "Overland tax".
Amazon.com: Engineaire 4" Precleaners Composite 150-465 cfm: Automotive
Old 04-20-2021, 04:40 AM #28
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I personally like the looks of the TJM over the other designs.
Good thing there are choices available.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 03:11 PM #29
sn_85's Avatar
sn_85's Avatar
There's the Alpha Equipt snorkels too albeit on the pricey side
Carbon Fiber Air Snorkel - 5th Gen 4Runner - Short Version
– ALPHAequipt
Carbon Fiber Air Snorkel - 5th Gen 4Runner - Long Version
– ALPHAequipt
Old 04-20-2021, 07:06 PM #30
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
So the short version fits all 5th gen but the long only the 14+?
It sure doesn't look like either would fit with the 10-13 antenna. Anybody actually have one of these on a 10-13?
comtn4x4 is offline   Reply With QuoteReply With Quote
dobinson , fts , interested , options , snorkel
New cheap snorkel on the market: the eBay “ARB Safari” snorkel Atomic6 3rd gen T4Rs 108 08-19-2021 03:15 PM
Safari Snorkel confirms snorkel for 4th-gen coming 4WDToyotaOwnerMag 4th Gen T4Rs 488 11-01-2020 10:46 PM
Safari Snorkel releasing snorkel for 3rd-gen 4Runners 4WDToyotaOwnerMag 3rd gen T4Rs 127 03-28-2020 07:56 PM
FS: 4runner/Tacoma Safari Snorkel cj80cruiser For Sale: T4R Items 11 01-10-2012 09:36 AM
