Old 12-22-2019, 07:52 PM #31
shdw03 shdw03 is offline
shdw03 will become famous soon enough shdw03 will become famous soon enough
Slow going on progress... Ran some of wires. Just pita doing this after work couple hours a night
Sent from my ONEPLUS A6013 using Tapatalk
shdw03 is offline   Reply With QuoteReply With Quote
Old 12-29-2019, 09:38 AM #32
Power wire done. Re-wired passenger door
Old 01-31-2020, 05:00 AM #33
Well I bit the bullet and bought the factory sub enclosure. A little sound deadening and sample the stock jbl.... Not bad at all! Powered off my rf prime 500, hits pretty good. The sub bass is not there, but probably better than an under seat mini sub. Waiting for my subwoofer spacer to arrive.
Old 02-01-2020, 04:17 AM #34
What it looks like with panel back one. Time for a beauty panel. Gonna have to rethink the subwoofer spacer. No room behind the pocket separator
Old 02-04-2020, 06:32 AM #35
Well it fits
Old 02-04-2020, 04:38 PM #36
Removed some internal bracing. Added poly-fil. Sounds much better than stock. Tighter, deeper and more controlled. Now the beauty panels
Old 02-06-2020, 07:03 PM #37
Added a little protection, a jl 8w3 cover
Old 02-24-2020, 02:46 AM #38
Bought a JL 8w3. Ported the stock enclosure to see how it would sound. Not bad
Old 02-24-2020, 08:02 AM #39
philipn126 philipn126 is offline
philipn126 is on a distinguished road
I an really interested in changing my stock sub to the JL you have. Do you think it would perform well with the stock JBL sub amp?
I appreciate the hard work you have put into your 4R. Nice job!
Sent from my SM-G965U using Tapatalk
philipn126 is offline   Reply With QuoteReply With Quote
Old 02-24-2020, 11:37 AM #40
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
With an enclosure that small wouldn't a ported sub make it worse? i thought you needed like 1 cubic foot for a ported 8" enclosure, versus .25 cubic foot for an enclosed 8" sub with batting?
llDemonll is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 04:47 PM #41
Well finally made my cover panel. Used 1/8" abs (all I could get locally here in Hawaii). Made tabs that secured it to the back of the stock trim brackets. Sorry forgot to take pics of the back side. Still need to mount the lower cover, just press fit on there for now, still a little loose.
Want to check for rattles and clean up the sub hole a bit. Then make a mount for the lower section.
Old 05-02-2020, 07:15 AM #42
Looks awesome.
Old 08-27-2020, 01:19 AM #43
Originally Posted by Dude View Post
Did you have to cut any of the trim panel to remove the inner shelf? Or does it just separate from the outer trim panel?
Just removed the pocket and outer trim. There are a couple tabs that you have to flush cut as well as 2 screw posts. Depending on sub and grill, it pushed out that center bar section about 1/2 inch
a6013 , oneplus , shdw03 , speaker , upgrade
Audio Upgrade - Audio guys come in and help wfo9 5th gen T4Rs 18 03-21-2015 07:24 PM
05 Audio Upgrade to Nav OlBlackBetty Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-10-2013 01:40 PM
Audio upgrade! Stuntmonkey 3rd gen T4Rs 31 04-11-2013 05:10 PM
94 audio upgrade bates Engines / Suspension / Wheels / Tires / Audio / Accessories 6 03-10-2010 11:31 PM
Help me upgrade my audio skategoat Engines / Suspension / Wheels / Tires / Audio / Accessories 6 08-30-2004 11:32 AM
