Old 05-01-2020, 06:48 PM #61
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
Originally Posted by daytonaviolet View Post
Now I have a drivers side ohh shit bar :-). I need to make the plastic hole on the installed bracket bigger. I see a slight bulge.
What??? I didn't know that was a thing. My Tacoma has on and always thought the 4runner should too. It should be standard!
itr1275 is offline   Reply With QuoteReply With Quote
Old 05-01-2020, 06:54 PM #62
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Right ! My 4th gen has it and was shocked 5th gen lost it.
There’s a guy on the forum makes/sells the brackets/bolts. Everything thing else is Oem.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 05-02-2020, 02:03 AM #63
The last picture in the driveway looks like you pulled the limited badge.
Your build is exactly what I wanted. The limited innards with the SR5/TRD outside.
I considered the Lexus GX but the front end is super dysfunctional.
Now if you can figure out how to get the e-locker...
Old 05-02-2020, 03:27 AM #64
Yes I think I pulled the limited badge off the day I installed the roof rack. the chrome was bothering me.
Old 05-03-2020, 03:10 AM #65
BradRunner's Avatar
BradRunner BradRunner is offline
BradRunner is on a distinguished road
BradRunner's Avatar
Awesome! I remember seeing someone fabricating brackets for this mod but I’ll dig around to find it, can you list your OEM parts needed for this mod?
BradRunner is offline   Reply With QuoteReply With Quote
Old 05-03-2020, 01:53 PM #66
Drivers Side “A” Pillar Grip Handle Installed on 2014 T4R
https://r.tapatalk.com/shareLink/top...ink_source=app
Old 05-03-2020, 02:43 PM #67
BIGpharma's Avatar
BIGpharma BIGpharma is offline
BIGpharma is a jewel in the rough BIGpharma is a jewel in the rough BIGpharma is a jewel in the rough
BIGpharma's Avatar
If you wanted to, you could get an Tundra OEM black plastic overlay with double sided tape to go over the chrome. That is what I did when I was getting the OEM black out kit..
Daytonaviolet's build thread-kkk-jpg
2015 Limited Blizzard Pearl: OEM TRD Pro Fox Suspension | 2”/2” Cornfed Spacers | TRD-OR 17" | 285/70/17 Firestone Destination A/T | Shrockworks Rocker Panels
BIGpharma is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 12:37 AM #68
HillRunner09 HillRunner09 is offline
HillRunner09 is on a distinguished road
Where did you buy your pro rack from?
HillRunner09 is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 01:38 AM #69
Got it locally from the FS section.
Old 05-05-2020, 01:09 PM #70
Moreno Moreno is offline
Moreno will become famous soon enough Moreno will become famous soon enough
Do you mind sharing the part number of the handles and everything please!!!!
Moreno is offline   Reply With QuoteReply With Quote
Old 05-05-2020, 01:52 PM #71
Please take a look at post #66
Old 05-07-2020, 05:03 PM #72
TRDProx2 TRDProx2 is offline
Real Name: Brian
TRDProx2 is on a distinguished road
Real Name: Brian
Spent a few hours Saturday afternoon and few hours today. I was able to complete the following
1. Fender liners
2. Rocker panels
3. Hood scope insert
4, front bumper
5. Pro grille
Unfortunate while taking off the front fender flares (required when removing fender liners) I broke several clips on the fender flare. I can’t believe how weak these were. I ended up using epoxy to repair the clips. I learned that the clips used to hold in the fender liners are not reusable.
Before
After
Fixed fender flares
It's tough for me to tell (or maybe I'm just slow) but did you have to mod the front and rear fender flares so the lower profile rocker panel trim matched up? Or do the rocker panel trim parts you provided in an earlier thread match up well to the fender flares?
TRDProx2 is offline   Reply With QuoteReply With Quote
Old 05-07-2020, 08:15 PM #73
It’s hard to tell in the pics, but my Oem (limited) rear door flares does not line up with the rocker panels. The fronts do. This is because the limited has a different angle rear door rocker vs non-limited.
I have the correct rear door rockers, but I forgot to have the shop paint it when I got everything else painted :-(
I plan to to do it some day :-)
There are two options, black or body color. I believe the black has a texture to it. Body color is smooth and paintable.
Rear door flare:
75741-35902 right body color
75742-35902 left body color
Clips:
75395-35070 (orange)
75396-35020 (blue)
Old 05-08-2020, 12:45 AM #74
Got the JBA UCA today. The the color really matches well with the TRD springs.
Old 05-08-2020, 07:09 PM #75
Updated my key fobs :-)
bumper/valance , install , mods , pro , trd
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
