11-20-2019, 05:41 PM
#16
Originally Posted by daytonaviolet
It was actually a used set which the owner stated had ~ 5k miles. I was shocked at the lack of wear so I wanted to give them a try. The Cornfed spacers was an after thought after a saw the TRD pro lifted thread.
Aren’t those bilstein shocks? I thought the 2019 pros had the fox setup.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
11-20-2019, 05:45 PM
#17
Daytonaviolet's build thread
Yes they are. These are from 2018 TRD pro when they were using Bilstein. First page typo fixed :-)
11-20-2019, 05:52 PM
#18
Good question . The TRD pro suspension is a very capable stock suspension which I got at a very reasonable price. I’ve driven a few of them and liked the stock feel but yet firm and it’s ~ 1” higher then other runners. I wanted a stock ride feel but wanted to level it a bit .
I saw this thread and saw that Cornfed was a good solution. It would feel like a stock TRD pro but with a little lift. I figure I’d give this option a try before deciding on which lift to go with.
Trd pro lift question
Trd pro lift question - Toyota 4Runner Forum - Largest 4Runner Forum
I get it and it makes sense however I was under the impression that adding a spacer lift would limit suspension travel, thus kind of defeating the purpose of putting on the trd pro suspension.
2019 4Runner ORP
2017 Porsche Macan GTS
2017 Ram Rebel 4x4
11-20-2019, 06:00 PM
#19
The guys on that thread with pros and did the Cornfed are happy with it. I guess I’ll find out soon. I hope to have my suspension in perhaps thanksgiving weekend. I’ll eventually get a real lift (Kings, toytech , icons) but I just need to collect a few more dead presidents :-)
11-21-2019, 10:44 PM
#20
Just picked these up from the paint shop tonight. The valances use to be silver. The scoop was unfinished. I was going to use the finished scoop which is already black but I want the valances to match. I’m sure these will chip in a few weeks
But for now .. they look so purty :-)
11-22-2019, 01:06 AM
#21
Nice, wish mine were black.You puting those on the limited? Ready to cut 27 holes? That was a fun mod on my prestine sr5.
2019 SR5 Premium 2WD - TRD PRO Front Struts & Coils w/ Toytec 1" Perch Spacer / Dobinson's C59-505 Rear Springs / ICON VS 2.0 Rear Shocks / TRD PRO Grill & Valences/ TRD CAI /URD MAF Calibrator / TRD PRO Wheels / BFG KO2 275 70 17
11-22-2019, 04:04 AM
#22
This is the build that I want to do
11-22-2019, 04:21 AM
#23
Mine are pre-cut
11-25-2019, 04:20 AM
#24
Spent a few hours Saturday afternoon and few hours today. I was able to complete the following
1. Fender liners
2. Rocker panels
3. Hood scope insert
4. Front bumper
5. Pro grille
Unfortunately while taking off the front fender flares (required when removing fender liners) I broke several clips on the fender flare. I can’t believe how weak these were. I ended up using epoxy to repair the clips. I learned that the clips used to hold in the fender liners are not reusable.
Before
After
Fixed fender flares
11-26-2019, 09:46 PM
#25
trd trim on limited
Hi Daytonaviolet,
Im looking to do the same TRD conversion to my 2016 limited.
What parts were needed to complete the front bumper?
Thanks any info helps.
11-26-2019, 10:59 PM
#26
Originally Posted by Rjeezy
Hi Daytonaviolet,
Here's my bumper list. Let me know if you have any questions. Some of the items I put qyt5 as I was unsure how many clips I needed. But most of the clips I re-used. Let's just say, I have some extra clips.
11-27-2019, 12:23 AM
#27
sweet thanks man, how much was the paint job for the bumper? looks pretty spot on
11-27-2019, 01:56 AM
#28
Could we get some side shots to see how the bumper hangs as compared to the rear? Is the rear bumper noticeably lower now? Also, did you retain the rear parking sensors?
2015 Limited Blizzard Pearl: OEM TRD Pro Fox Suspension | 2”/2” Cornfed Spacers | TRD-OR 17" | 285/70/17 Firestone Destination A/T | Shrockworks Rocker Panels
11-27-2019, 01:36 PM
#29
I actually got a few items painted. Front/rear bumpers, front/rear valances, hood and hood scoop for $1500. Keep in mind these are Bay Area prices.
11-27-2019, 01:39 PM
#30
I’ll take some today. As for the rear TRD bumper, I may install those tonight. If not for sure this weekend. But yes, the rear will hang down like 2”. I plan to re-install both front and rear parking sensors. For the rears, the outer ones will be in the standard location. The two inner ones will be on the valance. Well that’s my plan.
