Old 06-19-2020, 08:53 PM #91
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough
Real Name: Jason
Originally Posted by NW4RPro View Post
Why are you running 4 Wheel Drive full time?
Because it’s a limited.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 06-20-2020, 05:03 PM #92
NW4RPro NW4RPro is offline
Real Name: Anthony
NW4RPro is on a distinguished road
Real Name: Anthony
Ahhh, didn't know they ran in 4WD only
2019 White TRD Pro
NW4RPro is offline   Reply With QuoteReply With Quote
Old 06-20-2020, 06:17 PM #93
Real Name: Jason
Real Name: Jason
Yeah. Limited’s are full time awd with option to go to low range 4wd
Old 06-20-2020, 11:38 PM #94
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Yes
L4L - low range 4wd locked center diff
H4L - high range 4wd locked center diff
H4F - high range 4wd unlocked center diff. I'm assuming F stands for Full-time for use on any surfaces.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 06-20-2020, 11:39 PM #95
Daytonaviolet's build thread
Didn’t you notice I changed bumpers, rockers and added trd wheels and roof rack in this build thread :-)
Trd Limited
Old 06-21-2020, 09:11 AM #96
Wolfman’s Brother Wolfman’s Brother is offline
Wolfman’s Brother will become famous soon enough Wolfman’s Brother will become famous soon enough
Originally Posted by daytonaviolet View Post
Trd Limited
Are you considering any rear locker at all? It would line up with the rest of your antics.
2014 Trail Premium - Heritage Grill | TRD Wheels | TRD skid | Bilstein 5100/5160 | 275 KO2s | BD Squadron-R Pro fogs
Wolfman’s Brother is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 01:52 AM #97
Dr. Wh0 Dr. Wh0 is offline
Dr. Wh0 is on a distinguished road
Just got the trd pro roof rack for my limited trd pro conversion, what hardware part numbers are needed to do a proper install?
thanks
This past Saturday I added the following :-)
TRD pro roof rack
Predator steps
Plastic dipped tailgate garnish
Ready to install
Proper gaskets and bolt
Less then 1” clearance
Done
Predators steps
Plastic dipping garnish
Dr. Wh0 is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 02:49 AM #98
thanks
I updated post #35 w/ roof rack install kit :-)
Old 07-06-2020, 02:50 AM #99
Perhaps one day :-)
Old 07-06-2020, 08:52 AM #100
skillzo1 skillzo1 is offline
skillzo1 is on a distinguished road
Hmmmm this forum name seems familiar? M3forum member before it went down?
Sorry for the off topic post.
skillzo1 is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 10:07 AM #101
onelove's Avatar
onelove onelove is offline
onelove is on a distinguished road
onelove's Avatar
Great updates so far, The 1" of clearance is the exact reason I'm going to go with a lower roof rack on our TRD Pro, figure if I can save 1-2-3 inches of roof clearance with a lower profile rack, I can add it back in tires and suspension and still park inside the garage.
onelove is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 02:30 PM #102
Ok, thanks.
With the install kit, is the install just straight forward?
Old 07-06-2020, 03:16 PM #103
Wassup :-)
Yup same guy .. lol. I wasn’t aware M3Forum went down. What happened ? I sold the m3 few years ago but still drive the X5m. :-)
Old 07-06-2020, 03:16 PM #104
I’ve got a gobi stealth on order. Hope to get it by end of the year :-)
Old 07-06-2020, 03:21 PM #105
Ok, thanks.
there’s two things to keep in mind:
1. When removing the oem bolts, remove them in pairs. As a pair, loosen on like 3 turns and then do the other one. The goal is to keep the retaining clip from falling off. Having both bolts in and removing them together will allow the retaining clip to stay in place. Also keep in mind there’s lock-tire on the bolts so it will get tough at times to turn.
2. Keep in mind order in which the washers go in. From bottom up.
Foam washer - adhere to the bottom of rack
Composite washer - top of rack
3. Metal clips - you’ll need to get the metal clips which sit on roof and between the white plastic tubes separately. They are not part of the instal kit. Let me find the part numbers and post it here later.
bumper/valance , install , mods , pro , trd
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
