Old 11-20-2019, 01:06 PM #16
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Originally Posted by Drobs View Post
One of my favorite youtube channels. No drama - all around good people.
Note on the 4Runner recovery, his Smittybuilt synthetic winch line broke on him. Not a good endorsement for Smittybuilt.
Everyone uses the same rope. There's only a few places it comes from. It comes in different colors, but SK75 is SK75. Not knowing how to repair it in the field - that's kinda inexcusable. For anyone who doesn't know - it's this easy. And you can do it with a pen, a sharpie, or even a whittled stick. I cut my winch rope by pinching cutting it between the hawse and a big rock in Moab in May. Fixing it took about 20 minutes. Everyone that has synthetic rope should know how to do this.
The same goes for steel cable. Everyone should have the right parts in their little winch bag to repair a broken steel cable if you run steel. If you have a winch and haven't broken the rope/cable yet, it's just a matter of time before it happens (assuming you use it). Be prepared to repair it. The cost to be prepared for synthetic is literally zero except some knowledge and I guess maybe a roll of electrical tape. For steel cable - three clamps and a thimble costs less than $15.
Old 11-20-2019, 01:08 PM #17
Chris In Milwaukee's Avatar
Chris In Milwaukee Chris In Milwaukee is offline
Chris In Milwaukee will become famous soon enough Chris In Milwaukee will become famous soon enough
Originally Posted by Jetboy View Post
Also it's kinda the caricature of new 4Runner owners. All the bolt on shit. No experience. Relatively easy obstacle and he has a fawking winch, and still can't get past it? Never used a winch before is my guess. Also didn't ever learn how to repair a synthetic rope it appears. Something easy that everyone with synthetic rope should know how to do. If you don't - spend literally 5 minutes on you tube and learn. It's just everything wrong with buying a 4Runner, bolting on a ton of useless crap, and then not knowing how to use any of it all summed up in a single incident.
We all have to start somewhere. Let's use this as a learning experience.
2019 MGM TRD ORP
BFG KO2 265/70-17
Dobinsons C509-302/GS59-700, C59-505/GS59-705, UCAs
Victory 4x4 Blitz Bumper w/Zeak 12000
Chris In Milwaukee is offline   Reply With QuoteReply With Quote
Old 11-20-2019, 01:24 PM #18
Jetboy's Avatar
Jetboy's Avatar
Fair enough. Instead of criticism maybe some pointers would help.
The cost of one rotopax would have paid for a high lift jack. He could have used the jack to lift up the slider on either side and put some rocks under the tires. He also could have used a high lift on the rear hitch and lifted up the rear to put some rocks under the rear tires.
Traction pads are mostly worthless in my experience, but they could have possibly been used here to make a nice jack base. The spare tire is also often a useful base to jack from in soft sand. And in a pinch it works to dig a hole, bury the spare tire, and then winch from the buried spare tire. This is very common in deep snow off roading. Usually you would use the handle from your high lift jack behind the spare to attach your winch cable to through the center hole.
Like this:
The same could have been done with the bottle jack he has in the back. He's got one arm in a sling, but the bottle jack doesn't take much skill to use and should be operable one armed. Lift up the tires. Put something firm under them.
His first choice though should have been the winch. So it would be useful to learn how to use a winch and how to put a new brummel eye in it. I posted a video above. Doing this one handed would be kinda challenging. He should have had his kid help.
Also he should have had a tow strap. I'd bet that the winch rope was looped back onto its self and the rope broke because of that, or he wrapped the winch rope around a rock and it cut it on a sharp corner. He should have used either a tow strap or a tree strap to wrap around the rock and then hooked the winch rope to that. You don't need an expensive recovery strap. A typical $30 strap will work just fine.
Or in the alternative if you didn't have any thicker strap like that, the next best thing to do would be to use either a thick coat (carhart style) or the floor mats to protect the winch rope on the back side of the rock so that it doesn't get cut by the rock sharp edges. Putting synthetic plastic rope on sharp edges and pulling is a recipe for cutting the rope.
Between the winch and jack, this should be a non-issue to get free from.
Finally - get rid of that hitch rack. Even if he did manage to get over that log - he would have come down in the rear on the hitch rack and probably either bent the rear frame cross member or collapsed the hitch rack. Put that shit on top or in the back or leave it behind. Hitch racks like that are a major liability off road.
Old 11-20-2019, 01:33 PM #19
Also he should have had a two strap. I'd bet that the winch rope was looped back onto its self and the rope broke because of that, or he wrapped the winch rope around a rock and it cut it on a sharp corner. He should have used either a tow strap or a tree strap to wrap around the rock and then hooked the winch rope to that.
Great feedback. Thanks for sharing that
2019 MGM TRD ORP
BFG KO2 265/70-17
Old 11-20-2019, 01:44 PM #20
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
Cordless chainsaw..cut the obstacle out of the way. Easy to remove from the side. Deadwood probably only a few hundred pounds..
Put that kid to work..the one arm guy? He can drag wood with one good arm right?
Jetboy I hear you on the highlift. Ive got one along with an offroad base pad. I dunno...the ****er makes me nervous.. so its nicely mounted on the wall, in my garage!!
Grug556 is offline   Reply With QuoteReply With Quote
Old 11-20-2019, 02:41 PM #21
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
For $800 you can get an ARB hydraulic long travel jack that is much safer. It can probably be used by a one-armed person too. Taking a tire off might be difficult though.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
cool , guy , lot , road , tube
4Runner pulling loaded jeep on trailer in alaska usaf_fire 5th gen T4Rs 33 09-01-2015 10:07 PM
Recovery/Pulling-Out Other Vehicles - 4WD?? [email protected] 3rd gen T4Rs 37 01-20-2014 11:25 AM
4wd Problem and jeep recovery story... jmt2404 3rd gen T4Rs 13 04-06-2012 01:28 AM
JRD (Jeep Recovery Division) Stickers for Sale ksunami44 For Sale: T4R Items 10 11-04-2011 04:45 PM
4runner pulling a jeep 05SportV8 Off Topic 4 04-18-2006 07:07 PM
