Old 02-07-2020, 09:41 AM #1
benhalleniii benhalleniii is offline
benhalleniii is on a distinguished road
2017 TRD OR with KDSS: Toyota dealer or off road shop for lift/wheels/tires?
Hey there. I'm new to the forum and just bought a 2017 TRD OR and working on wheels/tires at the moment.
Since my truck has KDSS I'm wondering if I should be going to a Toyota dealer to install a lift on the 4R since it has KDSS or do you think that it's not beyond a local off road shop's ability? Meaning, does the fact that it has KDSS make it too complicated for a tech who isn't familiar with it? Looking to do the Bilstein 5100 mod.
Thanks in advance for any feedback!
b
e
n
2017 TRD Off Road
benhalleniii is offline   Reply With QuoteReply With Quote
Old 02-07-2020, 09:52 AM #2
kevinb_NJ's Avatar
kevinb_NJ kevinb_NJ is offline
kevinb_NJ is on a distinguished road
kevinb_NJ's Avatar
b
e
n
First off, welcome! You'll probably get 100 different opinions on here and also a few people telling you to do a search for wheels/tires and lifts "there's tons of info bro if you only look".
Most reputable 4x4 shops will be able to deal with KDSS, I don't actually think its that hard even for the DIY guys (I didn't have KDSS so I don't know really). The one thing to consider is if you've got a warranty and if going to an outside shop might void said warranty.
Good luck and make sure you share some pictures!
2015 Barcelona Red Limited
Bilstein 5100 lift with OME springs
Spidertrax spacers
Shrockworks skids
General Grabber 285 70 17's
kevinb_NJ is offline   Reply With QuoteReply With Quote
Old 02-07-2020, 10:38 AM #3
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I have KDSS and did the shocks replacement myself. There is a write up by SP8BALL somewhere on here. I didn't lift, but the KDSS wasn't hard to work around for the shocks. I'd say it depends on how high you are going.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 02-07-2020, 11:30 AM #4
osideplayer osideplayer is offline
osideplayer will become famous soon enough osideplayer will become famous soon enough
There is a detailed write up. Ask the shop first, if they know what KDSS- then follow up if they know how to work on it.
osideplayer is offline   Reply With QuoteReply With Quote
Old 02-07-2020, 01:20 PM #5
Angelo's Avatar
Angelo Angelo is offline
Angelo will become famous soon enough
Angelo's Avatar
I have KDSS and did the lift myself. Whichever route you go between dealer or shop, the most important thing is to make sure they have experience lifting and aligning IFS- experience with KDSS is a definite plus.
Before you pull the trigger, make sure you are familiar with the procedure to loosen the pressure in the KDSS system by using the bolts underneath the cover on the drivers side frame rail. Metal Tech has a write up on it floating around (pdf) specifically for the 4R, and ARB has a Youtube video where they describe the procedure on a LC to even out a lean after installing a lift, but it's the same KDSS system. It's possible to do the lift without releasing pressure on the KDSS but wrestling with those hydraulics is a bear and will effect whether or not you need a spacer to even out a lean afterwards.
Good luck man.
Eibach - Dobinsons - Falken - Rigid
Consolidated Lighting Info Thread
Angelo is offline   Reply With QuoteReply With Quote
Old 02-07-2020, 11:23 PM #6
Thanks all!
Hey I will search for the KDSS specific write up. And thanks for not just giving me the "just google it bro" treatment! Looking forward to spending more hours on here.
b
e
n
2017 TRD Off Road
Old 02-08-2020, 11:55 AM #7
WRM1 WRM1 is offline
WRM1 is on a distinguished road
Good luck man.
I installed a 2" front lift on my 2010 Trail with KDSS and never had to wrestle with the KDSS hydraulics. I just unbolted the sway bar and installed the new springs/shocks, then reconnected the sway bar. It's a lot easier to get it all together if you put the wheels back on and put weight on the front wheels. I didn't have any lean at all.
WRM1 is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 09:17 AM #8
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
b
e
n
You definitely don’t want to mess with the valves on the KDSS. Seems like most that do complain about absurd lean soon thereafter. I’ve had mine lifted for about 40k miles and no lean. Make sure they set the front shocks to the same height and you’ll be good.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 02-09-2020, 09:19 AM #9
Good luck man.
Fake news
Old 02-09-2020, 11:31 AM #10
Jivewalker's Avatar
Jivewalker's Avatar
I concur, no need to mess with pressure valves. Just put a bottle jack under the piston, unbolt the brackets, and lower the bottle jack a little to roll the brackets back enough for tab to release. Opposite to re-attach.
For the install, try to have 2 jacks. A floor jack for the LCA and a bottle or floor jjack for the KDSS piston. Use some wood to bl;ock the hub up. there is a good write up on here with instructions. See attached. I didnt write these and reccomend you fully understand what you are doing, springs have a good bit of tension on them!!!
I am fragile.
Not like a flower.
But like a bomb.
Old 02-13-2020, 06:11 PM #11
Angelo's Avatar
Angelo's Avatar
Originally Posted by EddieV4runnin View Post
Fake news
@benhalleniii Definitely not saying you have to go this way, but it definitely ain't fake news. There are two options- either release some of the pressure in the system, or use jacks or the truck's weight to manipulate the LCA / KDSS sway bar coupling back together. Either way, again, good luck!
https://www.metaltech4x4.com/content...do_4Runner.pdf
dealer , kdss , road , toyota , trd
FS: 5th Gen: 2017 TRD Off Road Premium Wheels and Tires $600 - San Diego CA 2112 R For Sale: Suspension/Wheels/Tires 8 07-26-2018 06:58 PM
SoCal: 2017 TRD Off Road Premium Wheels and Tires Bishop98 For Sale: Suspension/Wheels/Tires 1 12-06-2017 03:25 PM
FS: 2017 4Runner TRD Off-Road Wheels & Tires (5; $650 OBO) - Atlanta TheRuggedGent For Sale: Suspension/Wheels/Tires 5 11-19-2017 01:38 PM
FS:OEM Wheels/Tires/Suspension 2017 TRD Off Road Premium w/KDSS (So Cal) MikeDBC For Sale: Suspension/Wheels/Tires 9 05-15-2017 09:31 PM
