Old 11-25-2019, 08:41 AM #16
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Originally Posted by mteolus View Post
Yes, the KDSS bar is maybe 1/4 inch from my 285/70R17 if I push it as far as I can back towards the rear bumper as I finish raising it up. No way a tire any bigger will fit. Seems like a 34 inch tire would fit without the KDSS bar in the way but maybe not. I was just under there today installing the C4 diff skid and checked it out up close.
mteolus, no contact between the diff skid and the trac bar? Steve has been helping me to trouble shoot some contact between his trac bar and my diff and he said the diff skid could be a problem
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 11:50 AM #17
the_fornicator the_fornicator is offline
the_fornicator has a spectacular aura about the_fornicator has a spectacular aura about
I can't think of anything disappointing, regretful, or negative effects from going to 285s. I love mine.
Wait, I lied. The logistics of figuring out whether you need a BMC and/or UCAs was the biggest "challenge" from a time perspective for me. i.e. how many times do you want to lug your 4runner to the shop?
You might not even need a BMC or UCAs -not everyone that goes to 285 needs them, but I imagine that depends on your usage and suspension travel. I think the process would go something like this:
* Put on 285s
* See if they rub and if so, assess mod what you can e.g. remove front mudflaps, splash guard mod, and probably trim some of your front bumper (keep in mind, if you get UCAs down the road, you might have to trim some more of the bumper depending how much clearance you give yourself the first cut around)
* With my bilstein 5100s and stock UCAs, I can't get more than 1 degree of caster. So, it'll be a toss up at this point whether you get one or both re: BMC and UCAs. If you get the BMC, you can forget the UCAs altogether since you'll have clearance, but if caster means anything to you, UCAs might be for you.
* If the BMC bothers you at all (e.g. I hate rust and the minor rubbing that occurs brothers me less than potential rust from a less-than-perfect BMC job so no BMC for me), you might want to try the UCAs first. All depends on your comfort level.
Or, you can commit to both and get it done in one quick trip to a shop and be done with it. Super fast peace of mind.
I don't do anything hardcore with my runner so I put up with the little bit of rubbing at full articulation (more so in reverse). The front mod/splash guard rubbing is starting to bug me so I'll take care of that in the spring (I run OEM sized winters during winter).
$0.02
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
the_fornicator is offline   Reply With QuoteReply With Quote
bumper , coopers , hole , rationalize , rear
Butt hole moved after Body lift (Spare tire access hole) KSWAY 3rd gen T4Rs 3 03-13-2013 11:09 PM
Bigger spare tire fit? TOYLUVA 4th Gen T4Rs 9 10-18-2011 12:29 AM
gas milage / bigger tire ?? Falls 4th Gen T4Rs 6 04-11-2008 07:48 PM
Bigger tire's & a lift,mean's....what? MACROSS8511 3rd gen T4Rs 7 02-27-2008 04:47 PM
How much bigger in inches. is a 285 to a 265 tire? gkatmar 4th Gen T4Rs 2 01-10-2007 10:36 PM
