Old 11-23-2019, 03:57 PM #1
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Anyone install 12v power in glove box(2018)?
I have seen the usb data link moved to the glove box from the center console, but has anyone installed a 12 volt power source or a usb charger that works off the "keyed accessory" while maintaining all the stock locations? I know the older model years have them, but the 2018 does not. Is there a plug and play option without hacking the harness?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 11-24-2019, 12:05 AM #2
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a glorious beacon of light BobsTrail is a glorious beacon of light BobsTrail is a glorious beacon of light BobsTrail is a glorious beacon of light BobsTrail is a glorious beacon of light BobsTrail is a glorious beacon of light
BobsTrail's Avatar
Real Name: BobH
Funny, in 2012 they were both in the glove box. On my 2013 they came to the center stack. I think that was the only difference between a 2012 and 2013.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 11-24-2019, 08:53 AM #3
Charlievee's Avatar
Charlievee's Avatar
Tracking.
Old 11-25-2019, 01:47 AM #4
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
You could run dedicated power from the inside fuse block to the glove compartment. Please avoid guillotine style tap.
Use a 5amp or so fuse to power a cell Phone .
Amazon.com: Pixnor 12V ATO ATC Add A Circuit Fuse Tap Piggy Back Standard Blade Fuse Holder with 20A Blade Fuse - Size M: Home Improvement
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 04:32 AM #5
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
There’s probably nothing that’s plug-and-play. If you’re not going to draw a lot of current, say to just charge a cell phone, you could tap off a parallel circuit from the existing accessory outlet. You’d have to get to the back of the 12 volt outlet under the radio, strip some insulation off of the two wires with a knife, solder (16-18AWG) wires to each, insulate them, and run them to the back of the glove box where you’d install a 12 volt outlet.
After a quick search I found this link that might help:
Help moving USB from center stack to glove box
Good luck. It’s not that hard but be careful and deliberate and do a clean job soldering. I like using this cable braiding sleeve to protect the wires from abrasion (TechFlex F6N0.25BK Flexo F6 General Purpose 1/4-inch Braided Cable Sleeve).
https://www.amazon.com/TechFlex-F6N0...4669837&sr=8-1
Anyone install 12v power in glove box(2018)?-1734fe9c-5ef3-4f75-b1c3-4d5b2645a204-jpeg
Old 08-04-2020, 08:46 AM #6
SendInTheCavalry SendInTheCavalry is offline
SendInTheCavalry is on a distinguished road
Any updates? I am getting ready to install a Ram Mount XGrip on the left side of the radio trim. I was going to run a USB cord from that location to the glove box.
I’d like to install a square dual USB and a second lighter socket in the OE blanks in the glove box.
Seems like it would be fairly easy? I was going to jumper off of the power from the center Plug.
SendInTheCavalry is offline   Reply With QuoteReply With Quote
Old 08-13-2022, 12:50 AM #7
Chubbypanda Chubbypanda is offline
Chubbypanda will become famous soon enough
So any updates so far?
Chubbypanda is offline   Reply With QuoteReply With Quote
glove , older , power , stock , usb
2018 with gunmental glove box trim spider-cracking? 1996_Valencia_Owen 5th gen T4Rs 40 07-05-2020 10:28 PM
2018 Glove Box light replacement 719TRDOffRoad 5th gen T4Rs 5 01-31-2019 02:50 AM
2004 Sport Glove Box Switched Power? airbur Engines / Suspension / Wheels / Tires / Audio / Accessories 0 08-10-2018 06:27 PM
Glove Box Power Outlet Mod Red 4th Gen T4Rs 3 03-28-2012 12:44 PM
Glove Box Closed with Power cord Seansy 5th gen T4Rs 4 01-02-2011 07:24 PM
