11-24-2019, 12:42 PM
Brakes lack bite?
So being new to 4runners, something has been bugging me for a while but have only now gotten around to asking about it. The brakes seem a bit wonky and lacking bite.
An example would be when I'm starting the truck. I turn it on, depress the brake, and put it in reverse to get out of my driveway. The car, on idle, with my foot on the brake, will start to roll back unless I mash the petal really hard.
Is this normal? I transition from sports cars to 4runners, but am used to powerful yet responsive brakes.
My truck is a 2019 with 18k miles on it (SR5 Premium) which I bought 2nd hand. I'm wondering if the brake fluid might have some air bubbles in it or something. Please advise.
Cheers, and happy Thanksgiving (and happy belated Thanksgiving to our friends up north),
--Me
11-24-2019, 01:15 PM
Real Name: BobH
Real Name: BobH
My old 2013 has the typical soft pedal, but the brakes grab very well and are better than our 2 other vehicles. Sometimes it surprises me on well well it grabs. I'm still on OEM brake pads.
I would do a brake bleed to see if that helps.
11-24-2019, 06:19 PM
Yep it's typical. The brakes are my biggest complaint. Soft until they grab, then they grab too much.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
11-24-2019, 07:09 PM
Real Name: Sparky
Real Name: Sparky
The first 3/4 of pedal travel is jack shit and then the last 1/4 is panic stop.
Old and (c)rusty.
11-24-2019, 07:57 PM
Definitely. On a couple occasions i have braked moderately hard, to make a sudden turn for instance, and my wife and I were nearly launched out the front window. I be like where did THAT come from! I guess the brakes ARE there if I need them.
11-24-2019, 08:28 PM
Real Name: Jim
Real Name: Jim
I quickly got used to them and have found no problem with them whatever. Very rare panic stop really stops the rig. The rest of the time they’re just fine. I really don’t have the complaints everybody else on here seems to have about the brakes. After eight years I’m still on the OEM pads.
Lovin' my 4R
11-24-2019, 09:08 PM
Same experience on my new 2020 Pro. Once I didn't have enough time to make it through a yellow light and was surprised how quick it stopped when I mashed the pedal.
11-24-2019, 09:29 PM
This week I transitioned from a 68 F100 I've been driving since 1986, to a '17 4runner.
I have no issue with the complaints I read on here, lol.
Brakes, headlights, throttle, etc. I'LL HAVE AIR CONDITIONING NEXT SUMMER! I live in the hottest part of AZ.
11-25-2019, 11:50 AM
Honestly it took me a long time to get used to modulating them, especially with simple things like cruising up to stop signs and lights. Spirited mtn roads and hard stops were fine. Then I drove a Chevy Equinox (sucked) in Hawaii for 2 weeks. When I got back in my 4R I almost ran through the first stop sign I came to.
11-25-2019, 12:11 PM
The gas pedal and brake pedal are very similar in which the first half of pedal travel feels like its not doing much. Fortunately the gas pedal has a fix (sprint booster or pedal commander) but the brakes dont really have an easy fix. Once you drive it enough you will get used to it but if you get into another vehicle you might put yourself through the window on the first depress of the brakes.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
11-27-2019, 09:46 AM
Thanks folks - I appreciate the responses. One the one hand I'm glad my brakes are working as intended, on the other, well, yeah.
Cheers!
11-27-2019, 11:48 AM
Real Name: Dave
Real Name: Dave
When I first bought my 4Runner I thought brake travel too long and response too soft. But I quickly acclimated. I live in a rural area and am a conservative driver, slowing down in advance of turns and stops. It all feels normal to me and comparable to my Subaru Outback.
One thing the rig has, which hasn’t yet been mentioned, is a panic stop enhancement (for the lack of a better term). When the vehicle detects you decelerating above a certain threshold, it then kicks in this feature and really clamps on the brakes hard enough the ABS kicks in. I found this out the hard way when someone ran a stop sign in front of me in my small town. Felt like I was going to eat the steering wheel and startled me. I’ve had it happen once since. Checking the owners manual I confirmed what happened was as designed (don’t recall what the manual called this feature).
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
11-27-2019, 09:51 PM
Brake assist. Page 263 in the owners manual
11-28-2019, 09:58 AM
I recently bought a '19 and kept my '08. The brakes on my '19 are soft as you described and my '08s brakes are comparatively VERY touchy. It's hard to adjust going back and forth driving them both.
I dont recall my '08s factory brakes being soft but the last set of brakes were installed at a toyota dealership so... factory vs dealership? Dunno...
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
11-28-2019, 01:10 PM
Another member posted this recommendation in another thread
Start it up. Press HARD, really hard and hold the brake pedal there 5 secs or so. Do this three times
I have no idea why this works but it worked for me, and has been working for over 5 months. Modulation is better and that creeping while stoped is gone. No more putting it in neutral while in a line.
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
