Old 11-25-2019, 12:03 PM #1
MaddoxPics's Avatar
MaddoxPics MaddoxPics is offline
MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough
MaddoxPics's Avatar
How To Access Steering Rack?
Anyone have a clear diagram and things of what needs to be done to get to the rack bolts/bushings.
I'm having some crazy wheel shake off-road, and you can even hear it rattling. I have no idea what it is. I have torqued down the UCA, LCA, Heim, ball joint. Basically everything I could think of that could be loose and causing this, but it's still there.
On pavement I can't feel a thing, but I have noticed even after a fresh alignment the vehicle will still pull towards the right. It's not extreme, but it's definitely apparent something is wrong, which is why I'm beginning to think tie rod or steering rack.
From everything I've done, the tie rods appear to be okay. I don't notice any leaks, or movement when under it. So I'm thinking they are okay.
I went to work on the rack, just to tighten down the bolts to spec, and the hell if I can get in there. Way too tight with the hoses and everything else. Is this one of those all day affairs where I need to literally remove a ton of things?
I've been able to find stuff on every generation minus the 5th for whatever reason. Anyone have a diagram or step by step?
Thinking I may just buy some crows feet for the torque wrench, as I was able to get close with a short impact socket, just not close enough.
MaddoxPics is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 12:24 PM #2
money is on heim/uniballs. the wheel shake you feel could be bump steer too.
Old 11-25-2019, 01:33 PM #3
MaddoxPics's Avatar
MaddoxPics's Avatar
I just replaced the spherical bearing in the eyelet, so I would think that area would be okay. Unless something is bent, but it doesn't appear to be.
Uniball looks good too on the UCA. I haven't noticed any sort of wear on it, the lining coming out, etc. They're aftermarket Total Chaos.
Not saying it couldn't be, but I don't think it is.
Old 11-25-2019, 03:21 PM #4
boyguan boyguan is offline
boyguan is on a distinguished road
pull could be from the tires. switch left to right and see if it persists.
boyguan is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 06:19 PM #5
ScarfaceT4R's Avatar
ScarfaceT4R ScarfaceT4R is offline
Real Name: Christoph
ScarfaceT4R will become famous soon enough
Have you checked the front sway bar? After my sway bar relocation kit went in, the nut welded to the frame busted off & caused my sway bar mount relocation spacer part to smack the frame every time i hit a little (or big) bump... took a good few days to track down that issue.
After I fixed that the wobbles weren't so gnarly.
3" lift up front courtesy of 5100 Billys & Toytec HD coils + top hat spacers, 5160 Billys in rear w/ Toytec Superflex 2" coils, front Wheelers bumpstops/2" rear Toytec bumpstop drop, TRD Pro skid, Icon UCA's, Pelfreybilt sliders, HID's & LED's galore, full MBRP Catback, K&N CAI, Fuel Tactic 17x9's -12mm , 285/70/17 Cooper STT Pros, Total Chaos BMC kit, etc..etc..blah, blah
ScarfaceT4R is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 06:30 PM #6
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
If you need to replace the steering rack technically you need to lift the engine to get to it. There is a method though where you cut out the existing bolts and put new ones in oriented a different way. Here is a good video showing that procedure. The Tacoma rack should be pretty similar to ours: YouTube
I’m facing the same issue but waiting until it gets real bad before doing this procedure. It’s a pretty common problem for the Prado 120 chassis if the truck sees a lot of off-road use.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 11-26-2019, 12:25 AM #7
MaddoxPics's Avatar
MaddoxPics's Avatar
I'll give that a try.
I don't run a sway bar up front so I shouldn't have an issue with that. Though I thought I read that the tierods tend to have issues over time without a sway bar?
WELL DAMN!
diagram , rack , step , thinking , tie
Excessive play on drivers side steering - replace steering rack guide cheeser 3rd gen T4Rs 17 05-05-2022 08:15 PM
Power Steering Pump or Steering Rack? *VIDEO* LexusFTW 3rd gen T4Rs 44 08-11-2021 10:11 AM
Interest in a Baja Rack 3rd gen roof access ladder? jmferg 3rd gen T4Rs 29 11-06-2019 04:01 PM
Steering Rack and Power Steering Pump Replacement thebrandon 3rd gen T4Rs 5 07-02-2013 10:07 AM
Power steering/steering rack question (need help fast) alex bland 3rd gen T4Rs 9 01-09-2010 07:37 PM
