Old 11-25-2019, 01:20 PM #1
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
C4 Diff Skid for KDSS and Sonoran Steel Trac-bar
Installed the C4 Diff Skid for KDSS Saturday. No problems interfering with the Sonoran Steel Trac-bar as you can see the trac-bar is way above the diff skid. Pretty easy install, just a little neck fatigue laying down under there installing it. Really good product.
Painted the diff skid with a rattle can semi-gloss paint and primer combined in one.
I think these diff skids are part of C4's Black Friday deals plus an additional 10% off. Would be a good time to get one.
C4 Diff Skid for KDSS and Sonoran Steel Trac-bar-c4-diff-skid-jpg
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 11-25-2019, 02:26 PM #2
comtn4x4's Avatar
comtn4x4 comtn4x4 is online now
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Have you taken it off road with a heavy load at all? I am having some issues with my trac bar contacting my diff under extreme compression. (I don't have a diff skid) Steve and I have been working extensively to figure it out, however, it seems unique to my setup. My rig is pretty heavy so Steve thinks that when it's very compressed and at a higher speed the rear axle deflects into the trac bar due to the force.
comtn4x4 is online now   Reply With QuoteReply With Quote
Old 11-25-2019, 03:31 PM #3
mteolus's Avatar
mteolus's Avatar
No issues with mine hitting the diff. I haven't really had a heavy load though. But I did notice some rust above where you have to cut off the piece of metal when installing it. Obviously the rust where I cut is there but perhaps the rust just above that was caused by some light rubbing of the trac-bar? I painted it so I'll check again after some 4x4 to see if the paint has been rubbed off. It's possible I rubbed the paint off when making the cut.
C4 Diff Skid for KDSS and Sonoran Steel Trac-bar-c4-diff-skid-2-jpg
Old 11-25-2019, 03:36 PM #4
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
interested in seeing what the solution will look like! How much weight (other than the rear bumper) are you carrying in the rear?
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 04:00 PM #5
oldschoolpl510 oldschoolpl510 is offline
oldschoolpl510 is on a distinguished road
Good info, Thank You. I was wondering if there would be any fitment issues.
oldschoolpl510 is offline   Reply With QuoteReply With Quote
Old 11-25-2019, 04:50 PM #6
comtn4x4's Avatar
comtn4x4's Avatar
Smile
It's hard to say exactly but as a rough estimate:
Unloaded the rear end is as follows:
bumper at 250#
2 Gallons Fuel 14#
figure half of the weight of my roof rack so 55#?
The rear skids are maybe 45#
I don't know how much moving the spare tire back on the rig to the tire carrier changes things. Either way the spare IIRC is 20# heavier than the stock tire (the tire is 68.5# plus rim)
Tools recovery gear etc maybe 50#
So maybe 350# over stock? Not sure how much the removed items would weigh
Full add 56# water
Hi Lift 35#
The rest of the gear etc. in and on is probably another 300# plus people and dogs
As far as a solution goes we are kind of stumped right now. Initially we thought the trac bar hitting the diff was being caused by a bent rear lower control arm. Those have been replaced so that's not it although that seemed to help. I have ground some off the trac bar which also seemed to help but on a big hit it still hits it. Full is obviously worse than empty.
I have some bigger coils to put on but I have also been chasing a newly developed death wobble on the rear that I haven't quite got resolved yet.
Next step is to get the trac bar repainted this weekend and look for where it's hitting.
Steve has been really helpful and responsive. The whole think kind of has us stumped
Old 11-25-2019, 04:53 PM #7
comtn4x4's Avatar
comtn4x4's Avatar
I noticed something like this also. This may have been/be where I am getting some contact. After I repaint the bar I hope to see what's going on better
Old 11-25-2019, 04:56 PM #8
Glad to see Steve has been helpful in resolving this issue. About to purchase one and was a little worried about contact (also getting the diff skit) but Im not carrying nearly that much weight in the back so hope all is good!
Hope you guys are able to resolve the issue!
Old 11-25-2019, 05:04 PM #9
comtn4x4's Avatar
comtn4x4's Avatar
I would not be at all concerned with rubbing if I was you. Steve said he has shipped about 1400 of these IIRC and never had any issues like mine. I'm just the lucky one. And yes he thinks the weight has something to do with it
Old 12-10-2019, 02:25 AM #10
Any update on a solution for your set up?
Old 12-10-2019, 09:39 AM #11
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Read sonoran steels webpage for the trac bar. The kdss sway-bar is known to contact the diff. It's part of the reason they developed the bar from my understanding.
I need to get under my truck this week. I'll check to see if mine has made contact.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 09:45 AM #12
comtn4x4's Avatar
comtn4x4's Avatar
I'm not sure what you're talking about. I already have the Sonoran Steel trac bar installed and I am having trouble with it hitting the diff during compression. I'm the only one so far that's had the issue and have been working with Steve extensively to remedy the situation.
Old 12-10-2019, 09:52 AM #13
If it's axle deflection what about adjusting the upper or lower links to push or pull the axle to create more space?
interesting side note: PRG is selling a link kit that eliminates the driver side upper link. FJ/4 RunnerGX470 4-Link Kit | PRGProducts.Com
Old 12-10-2019, 09:56 AM #14
comtn4x4's Avatar
comtn4x4's Avatar
So far I haven't had a chance to get it the trac bar painted. With the holidays my work and life schedule has been nuts. However, I did get the heavier coils installed and that seems to have helped. I have had it out on a couple trails recently and tested it and haven't had any issues at slow speed. It seems to be a combination of things, first the rig is pretty heavy. (Steve didn't seem to think to many others that had his trac bar were running a heavily loaded setup.) Second, hitting an elongated speed bump at say 40 mph and coming down hard seems to deflect the axle backwards causing the contact. So the obvious solution there is don't do that... It did seem to improve with grinding the bar out in the diff area. When running a couple trails at 30-40 mph I wasn't able to duplicate the issue anywhere else.
I really don't want people thinking this is a common issue. I seem to be the only lucky one to have it.
I'm not sure I really answered your question but that's my update at the moment
Old 12-10-2019, 10:01 AM #15
comtn4x4's Avatar
comtn4x4's Avatar
I was thinking of that myself. However, Steve thinks that playing with the length of either the upper or the lower will cause problems in the first place. Part of how all this came about was I bent the drivers lower rear control arm. I thought that was causing the issue so I replaced those with the Sonoran steel non adjustable ones. I also replaced the bushings in the stock uppers as well. That change definitely freed up travel in the rear end so that may have exasperated the issue.
Right now I need to get the Sonoran steel trac bar re painted and start looking for areas of contact. Then possibly make additional adjustments as you suggested.
That PRG link looks interesting
diff , kdss , skid , sonoran , trac-bar
New Sonoran Steel Product: KDSS High Articulation/Long Travel Trac/PanHard bar sschaefer3 5th gen T4Rs 128 11-13-2020 08:51 PM
FS: 5th Gen C4 Rear Diff Skid (W/KDSS), $280 Salt Lake City, UT. Purkeypower For Sale: T4R Items 5 01-13-2019 08:13 PM
FS: 5th Gen C4 Rear Diff Skid (W/KDSS), $200 Salt Lake City, UT. Purkeypower For Sale: T4R Items 5 01-13-2019 08:13 PM
RCI Aluminum and Steel Skid Plates for KDSS-equipped On the Way 2013Trail 5th gen T4Rs 24 01-09-2018 12:05 AM
FS : BudBuilt 2010+ 4runner KDSS stainless Steel Front Skid Plate 300.00 reconmarine For Sale: T4R Items 6 11-19-2012 03:19 PM
