Originally Posted by landcruiser92
In fact the steelies are from when I had my FJ. However my 4Runner spare is the exact spec. I do run spider trax on all four corners, otherwise your truck ‘s stance/track will look very narrow, like it’s on stilts. I think 1.5” spacer would be perfect but spdertrax don’t have that size.
The DO bumper is great, I love the lines and the full 3 hoop, just wish the powder coating was thicker. Im starting to see slight rust in areas with thinned out powder coating.
Wheel on!
-Ed
Thanks for info!
Recently bought this 2021, with 20k miles that came with the aluminum roof rack, doube swing away steel rear bumper, Front/Rear coil 3 inch bilstien lift, Bilstien shocks, remote reservoir in rear. Baja designs auxillary lights in front and rear bumpers and S-Pod switch pro installed under hood for compressor, etc.
I went the OEM steel wheels (only $75 per wheel 👍) and the Mickey Thompson baja boss A/T 255/85/R17 34" tire with the 1.25" spidertrax spacers. I dig the skinnier tire look on the T4R. Really think a taller 10.5" tire looks much better than the 285/70/17's wider tires everyone else runs...
Wheel On!
-High Shelter
