Old 12-07-2019, 02:35 AM #16
Axix23's Avatar
Axix23 Axix23 is offline
Axix23 will become famous soon enough Axix23 will become famous soon enough
Axix23's Avatar
I love them tires and suspension kit!
Axix23 is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 03:25 AM #17
papadop88 papadop88 is offline
papadop88 is a jewel in the rough papadop88 is a jewel in the rough papadop88 is a jewel in the rough
Originally Posted by dom42 View Post
Full droop and full bump. 34” tires ( 285/75 17) on trd forged wheels with +6 offset 7.5 wide. This wheel is sooooo perfect for this truck. I still have about 3/8” from body mount. No need to chop. I just got trim some stuff up front.
Actually I lied. There’s some slight scuff at full bump on the upper inner fender liner. Heat gun will fix that. Or let it self clearance lol.
Yo Dom, Pistolpapa here. Can't believe I found you man. Looking forward to seeing the build complete. I'm sure it'll be just as good as your stippling...
Looking to pick up my T4R soon.
papadop88 is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 05:43 AM #18
dom42 dom42 is offline
dom42 is just really nice dom42 is just really nice dom42 is just really nice dom42 is just really nice dom42 is just really nice
Hey what’s up bro .
Thanks man.
dom42 is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 09:41 PM #19
honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of honda250xtitan has much to be proud of
whats she pulling? 9" of travel? I've never seen someone actually pull the coil off and cycle the suspension lol. However i do see lots of guys crank the preload all the way lolol
Old 12-08-2019, 01:51 AM #20
I got her on the ground today and mobbed it around town. I am also experimenting not running the front sway bar on the kdss system. It’s interesting because it makes the front end come a live with these kings and the valving I have. But it’s still pretty anti roll because the huge sway bar out back. Playing around with the alignment today. But I’ll take it to a shop on Monday.
Old 12-09-2019, 03:55 PM #21
Old 12-09-2019, 09:46 PM #22
I’m trying out my prototype rear coil. Suppose to settle down to 2” of rear lift.
Old 12-18-2019, 01:59 PM #23
Dom’s build thread
I posted this in another thread about abs and trac control. I installed this custom switch and tapped into the 4wd control until to trick the truck to think it has the locker on. This allow me to turn abs off which you want when wheeling at speeds. You want to be able to lock up the brakes vs abs trying to kick in.
Also having the trac off allows you to spin the tires with out the truck trying to control it with the ebrake.
This is a link to my video on Instagram. There’s a diagram there as well.
Dom Ruangnol on Instagram: “Get the switch from @cruiserheadsmiami. Easy process. Quick shipping as well. .. .. If you guys want the diagram for to wire this up. Swipe…”
Old 12-18-2019, 04:02 PM #24
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
i really like this suspension and wheels. best setup out there
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 12-21-2019, 01:47 PM #25
Well since King decided to not put the bypass exactly where I designed them to put it, I had to notch the lower links to clear one of the bypass tubes. It clears the stock links fine but it’s real close and with my links being a little wider then Oem. I had to. Or make new links. But I don’t want to hand fab anymore. Takes too long. Next links will be all cad designed as we just got the 4Runner CAD files from SEMA
Old 12-23-2019, 10:28 PM #26
Dom’s build thread
Alright. First prototype rear kdss track bar. Going to test fit it this weekend hopefully. But soon. I’m sure I’ll have to tweak something.
But what I did was take as many measurements from all angles. The mis alignment widths for the Oem track bar are 50mm. I only had 40mm mis alignments for these heims but I will use shims/ washer to fine tune. This actually will help me figure out if I need more or less bends by being able to shift the track bar towards front or back of truck.
I know there’s already a track bar out there but it’s the ugliest thing in the world. Welds look scary even tho I’m sure they are good structurally. It’s just not for me. Plush I think 7/8th wall DOM with the heims threaded in is a way stronger option and lighter.
The best part is this is not even the cool part that I figured out how to get even more travel out for the kdss system. I’m working on the design of that said part and the patents now. Can’t believe not even icon did this yet.
Watch this story by Fine Line Tactical, LLC |DOM on Instagram before it disappears.
Old 12-24-2019, 01:28 PM #27
Moreno Moreno is offline
Moreno will become famous soon enough Moreno will become famous soon enough
If you need a second test subject let me know.
Moreno is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 09:32 PM #28
Dom’s build thread
On and off on and off on and off. Been doing this a lot lately trying to figure this kdss track bar bind deal.....
I test fitted today. Almost worked. But I totally figured out how v2 needs to be. Needs to be simpler with less bends and a special part I can’t show or talk about yet until the patent pending at the very least is in order.
Old 12-28-2019, 12:39 AM #29
2barevo 2barevo is offline
Real Name: Chris
2barevo is on a distinguished road
Real Name: Chris
Following. Are you planning to offer this setup?
Sent from my ONEPLUS A6013 using Tapatalk
2barevo is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 12:57 AM #30
Yessir that’s the plan. Thanks for following along.
bar , i’ll , i’m , king , links
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
