Old 01-03-2020, 01:26 PM #31
dom42 dom42 is offline
dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light dom42 is a glorious beacon of light
Dom’s build thread
I still can’t show the part yet but I got a prototype of it on jt’s way to me by next week to test fit. But In theory using simple math. You will be able to run a str8 track bar and extended travel shocks and get full droop and more with out any contact on parts and no fear what so ever if the kdss shock inverting itself.
Teaser with the math lol. I’m not even going to explain what it is because I’ll end up giving it away. Patents are being handled now. Looking to license this to all the companies.
I’ll start a whole new post / thread about this part when it’s time to show off.
dom42 is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 09:40 AM #32
well?????????????
Old 01-14-2020, 10:54 AM #33
cooper_man cooper_man is offline
cooper_man is on a distinguished road
Intrigued to see myself. Great thread, impressive work!
cooper_man is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 06:40 PM #34
I started a new thread for it.
Maximize your KDSS + extended travel shocks
Maximize your KDSS + extended travel shocks - Toyota 4Runner Forum - Largest 4Runner Forum
Old 02-18-2020, 11:19 PM #35
Scanning the truck today making my own files. Sema files were garbage.
Old 03-11-2020, 06:32 PM #36
I wanted to put the switch pros in an area that both the driver and passenger can reach it.
Such a perfect spot in my opinion.
Old 03-11-2020, 07:26 PM #37
super clean.
Old 03-11-2020, 10:59 PM #38
otowntrd otowntrd is offline
otowntrd is on a distinguished road
love this build thread.
otowntrd is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 03:11 PM #39
I added a bezel so I can push buttons with out looking. I’ll do it by feel. Yes I’ll have to remember where’s what. But this location is perfect for me so I can access it from both sides of the runner.
Old 03-16-2020, 11:01 PM #40
Dom’s build thread
Another prototype track bar. Since the kdss drop blocks fix the clearance issue, I’m doing a str8 str8 bar. Female thread end 7/8” heim joints. Final track bar will actually be machine from solid piece. This one I just welded the threaded ends on to the solid bar. 1” diameter for maximum clearance. The final track bar will actually be all machined from one piece and will be 1” oD solid bar and probably going to do stainless.
Also installed the switch pro module into the engine bay. I have a bunch of Baja designs leds laying on the garage floor just need time to get them mounted. For sure putting a 30” onyx behind the upper part of the lower front grill.
And last I’m concerting the front end to trd “super” pro lol. I already have the piece to stick on but I’m doing something different.
Old 03-20-2020, 11:00 PM #41
Well I was hoping this would work out better in real life then it did in my head. I made this bracket to raise the sway bar on the kdss 4runner where it attaches to lower a arm. It works 75% lol. I mean it helps the bushing not being all binded up at ride height if you have a lift or when it droops out. But it’s limiting the steering. Can get to full lock because the tie rod ends will crash into it.
Ok time to figure something else out. .
Old 04-12-2020, 10:30 AM #42
Old 04-12-2020, 10:31 AM #43
Old 04-12-2020, 11:54 AM #44
Moreno Moreno is offline
Moreno will become famous soon enough Moreno will become famous soon enough
You selling this yet? If you are, please pm me info. Thank you!! I am from socal too so i could drive to you.
Moreno is offline   Reply With QuoteReply With Quote
Old 04-12-2020, 03:15 PM #45
Which stuff are you talking about. But yeah that’s the plan. The shock guards are from fjtoyman on insta. He’s on here too I believe. But kdss blocks send me a private message. We have those.
bar , i’ll , i’m , king , links
DHPham's 1997 4runner Build Thread (also 4wd swap thread) dhphamqc 3rd gen T4Rs 15 03-02-2019 03:08 PM
>BUILD THREAD< The4kbeast's 3rd-Gen 2000 T4R SR5 (Highlander Edition) 4x4 Build The4kbeast 3rd gen T4Rs 285 07-25-2018 09:37 PM
STRRAYNGE Build Thread! Or, I should say, After Build Thread?! Pic Heavy STRRAYNGE 3rd gen T4Rs 24 02-11-2016 10:46 AM
1998 T4R Build Thread/Rear bumper build 4running11191 4running11191 3rd gen T4Rs 3 09-19-2014 07:07 PM
