Originally Posted by 71gs3504sp
They are located on the lower control arms, two on each side. You will need to remove the front skid plate to get to the front two lower control arm bolts out. The OEM upper control arms are not adjustable.
If one bolt is done at a time, should the alignment hold? Don't want to throw anything off. I've only got 2k miles on it. Also, will the antiseize used on spark plugs for aluminum heads work on the bolts?
