Old 12-01-2019, 06:57 PM #16
Off-Camber Off-Camber is offline
Real Name: Brandon
Off-Camber is on a distinguished road
Real Name: Brandon
Originally Posted by 4R4Trout View Post
Thanks Brandon. I think this would work too. https://www.amazon.com/Fastronix-Pin...EWJ0TQZ4Z&th=1
What do you think?
David
That's the same thing i pieced together myself. Im not sure those terminals will direct crimp onto the LED license light wires since its a really small 26ga wire. You could either buy 2 small terminals for the two license plate wires or do like i did to extend my camera wires and butt splice them to the left over 16ga wire that victory supplies.
Does that make sense?
Brandon
Off-Camber is offline   Reply With QuoteReply With Quote
Old 12-01-2019, 07:52 PM #17
4R4Trout's Avatar
4R4Trout 4R4Trout is offline
4R4Trout is on a distinguished road
4R4Trout's Avatar
I知 picking up whatcha putt地 down. This might be easier as all you have to do is splice wires and not have to buy a special tool that I will probably only use once. https://www.amazon.com/Waterproof-El...M0HG1792HCZSQG
2012 TE~Shoreline Blue~KDSS~Nav
ARB Diff Breather, Dobinson 302/700, 723/701, Yokohama Geolandar MT G003 255/75R17, ARB CKMA12 onboard air, IndeFlate, Arclight LED, Victory 4x4 Strike rear bumper
4R4Trout is offline   Reply With QuoteReply With Quote
Old 12-01-2019, 09:06 PM #18
Real Name: Brandon
Real Name: Brandon
That looks like it would work the same way with just some butt splicing. I don't know about the branding. I just know Weather Pack because it's been OEM on several vehicles I have owned. Other than that, functionally it looks good to me.
Old 12-01-2019, 11:53 PM #19
4R4Trout's Avatar
4R4Trout's Avatar
Weather Pack makes a 6 pin pigtail in a 18g and a 14g. Just not sure which one to get. Does the Victory 4x4 License Plate/Camera Relocation come with all the wire you need to make the connection? If so what gauge wire is it?
Old 12-02-2019, 08:50 AM #20
Real Name: Brandon
Real Name: Brandon
The license plate light comes with PLENTY of wiring attached. Victory does send color coded wiring. It was more than enough as I ran the wiring very slack and still had probably 3 feet leftover. The license plate light wiring says 26 ga on it. The Victory wires are not labelled but I'm thinking they are 16 ga. If not, they are 18 ga. Nothing bigger or smaller. I'd go with an 18 ga pigtail, itll splice together with the same size shrink wrap butt connectors that come with the Victory kit. Plus itll match up better to the wiring.
Old 12-03-2019, 10:16 AM #21
PoopSmith PoopSmith is offline
PoopSmith is on a distinguished road
So after much debating, I ended up going with the pre-wired one. I liked the custom-built plug, but couldn't justify the cost of the crimper. I figured I can either find a splice connector that'll handle the thinner gauge of the LED, or just replace the wires altogether. (Plus this gives me a chance to finally use these splice connectors I've had kicking around).
Another issue I noticed: With moving the camera out away from the hatch, it seems to be very exposed to the elements. Several times I have come out to my car after it rains, and cannot see out the camera
I decided to pick up some rain-x and am going to treat the lense to see if it keeps the moisture off. I'll report back once I get it applied.
PoopSmith is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 11:14 AM #22
Another update! So I was walking behind my rig last night and noticed that there was no light shining on the license plate. Popped it off and realized it was full of corrosion. Looking at it closer, it doesn't appear to be weatherproof (snap-fit plastic pieces and the wires feed in loosely through a hole.
Already reached out to Mitchell, but figured I would let you guys know. It might be a good idea to throw some silicon on the base and where the wires enter before installing.
Old 12-06-2019, 04:08 PM #23
4R4Trout's Avatar
4R4Trout's Avatar
Good to know, thanks PoopSmith. My bumper is en route and should be here next Wednesday. Yah!!
Old 03-29-2020, 12:13 PM #24
RJWilliams RJWilliams is offline
RJWilliams is on a distinguished road
Hey @PoopSmith ,
Thanks for your write up. I've been looking at this bumper for ages but had a couple of the same concerns as you - plus a couple of others I'd really like your help with-
1 - What is the light spread from the backup lights like? Any photos at night showing the spread? They are so recessed into the bumper, firstly it looks like a bit afterthought but more importantly seems it'll cut off a bunch of the wider beam area
2 - Do you think a license plate could fit over the little victory logo panel above the hitch - or anywhere else? I am absolutely trying to avoid the plate being on the tire with the camera.
Victory's Tacoma bumper looks like a masterclass - that thing has both the above issues sorted out of the box - not sure if the 4runner was first and they fixed it on the Tacoma or if they forgot on the 4Runner version?!
RJWilliams is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 02:40 PM #25
Originally Posted by RJWilliams View Post
Hey @PoopSmith ,
No problem! I've been meaning to do some more updates and kept forgetting (now I guess I have to!)
1-I'm ashamed to admit I haven't even wired them up yet! If the weather gets nice I will soon, and will update.
2-Plenty of room! I went and grabbed an old plate and you could totally fashion a bracket using the bolts from the logo plate. If you mount it flush with the top of the bumper, you have about a 1/4" of clearance to the top of the receiver.
Old 04-04-2020, 11:23 AM #26
4R4Trout's Avatar
4R4Trout's Avatar
Hey @PoopSmith ,
I could help you out with that question. So I mounted a set of BlackOak light pods in their flood version. The light spread and distance is awesome. Sorry I don稚 have and photos of them at night.
Old 04-07-2020, 11:28 PM #27
Great news! Thanks so much for both your replies - great to hear that feedback.
Old 05-14-2020, 10:33 AM #28
ERMBPA ERMBPA is offline
ERMBPA is on a distinguished road
I happen to notice some discoloration on the latch handle of the swingout. Is that rust or is that just dirty?
ERMBPA is offline   Reply With QuoteReply With Quote
bolts , bracket , bumper , plate , wheel
Pulled the trigger on a new purchase victory blitz front bumper Mudballz 5th gen T4Rs 9 03-12-2020 02:02 PM
Victory 4x4 Bumper, Warn Winch and Dobinsons UCA Installed ProfessorP 5th gen T4Rs 5 08-27-2019 07:43 AM
2015 project thread (week 1 spod and CBI rear bumper) Tengu 5th gen T4Rs 20 04-14-2016 05:05 PM
Valet curbed my rear bumper on my 2 week old 14 LE. PatrickBateman 5th gen T4Rs 8 09-22-2014 12:54 PM
New Bumper being fabbed this week!!! Pikeman 3rd gen T4Rs 113 12-02-2010 04:16 PM
