Old 06-16-2021, 10:39 AM #31
dwib44's Avatar
dwib44 dwib44 is offline
dwib44 is on a distinguished road
dwib44's Avatar
A fix to most of these issues.
Originally Posted by PoopSmith View Post
About a month ago I was lucky enough to have my T4R selected to be the model in the bumper install video! I obviously have no advice on installing it, but I've had 2 weeks to play with it. Here are my initial opinions/tips;
-The first is mostly cosmetic, but If running a single carrier, the empty space left from the original plate mounting location is super ugly, and leaves the screw holes open to the elements. I purchased this blank from amazon to fill it in.
-The wheel studs that come with the carrier are 1/2 threads, not 12mmx1.5 like ours. This totally makes sense due to the carrier being originally designed for Jeeps, but I didn't like having to have separate sets of lug nuts. I ordered 3 studs from Rock Auto (PN: PTC 97192) for .89 each and replaced the 1/2 ones.
-I noticed Daryl mentioned it in the video (and I wish I would have known this before) but having the camera moved so far to the passenger SUCKS. Backing up into a parking spot is weird, and backing up to a trailer is damned near impossible now. Additionally, once you mount a tire, It covers most of the "clean" area of the window where the wiper cleans (kinda hard to see in the photo, but it's really noticeable if it's raining or snowing). Because of both of these, I'd highly recommend going with the tire on the driver's side.
-I haven't wired my LED's in yet, but since they are only 24w total for both (2A), I'm just going to tap into the center pin of the 7-pin trailer harness so they come on with the vehicle reverse lights.
-With the removal of the mud-flaps, there is now a pretty substantial increase in road noise in the rain. This doesn't bother me in the slightest but figured I'd make everyone aware of it as it might annoy some.
-Finally (and I think they have already fixed some of these issues), the license plate bracket is an absolute BEAR to take off if you're pulling the wheel off. You have to remove the 2 bolts for the plate, then the 2 vertical bolts for the whole assembly (which I believe they're using wing nuts now), Then the two bolts for the plate bracket, then pull the LED off so the plate bracket comes through the hub. Way too many steps, and if I'm on a trail or in the middle of the night? That's really going to suck. I would have preferred to see a weatherproof connector that allows you to remove the plate/LED assembly completely before removing the wheel.
All those being said though, I LOVE the bumper. Classic Victory/JCR over-engineered quality, and it looks wayyyy better than any of the other options out there. Keep up the good work fellas!
One thing that would fix most of these issues is the expedition one camera relocation kit. It actually mounts to the hatch where the license plate did and then extends from the hatch next to the tire. It is designed for their bumper, but these bumpers seem similar enough that I would imagine that it would work here as well. It also handles the license plate nicely by keeping it on the hatch. This solution looks good as well, atleast when the swing is in. I'll admit it looks a little weird with the swing out as there is a long protrusion from the hatch, but a small price to pay for a good solution. Only possible issue I could see here is the hatch not being able to open as much in a garage. If someone here would be willing to try it out that would be pretty awesome. I have been thinking of going this route, but haven't gotten the bumper yet.
dwib44 is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 11:43 AM #32
scratchhax scratchhax is offline
scratchhax has a spectacular aura about scratchhax has a spectacular aura about scratchhax has a spectacular aura about
I had my bumper installed shortly after yours I think and have made some similar changes. No more wingnut, a single 6 pin plug for the license plate frame. I've just recently picked up a squeak I'm trying to find. I THINK it's between the handle and the nut that is used to provide pressure on the latch mechanism. Outside of that though, it's been a great piece of kit and is holding up very well.
19 offroad premium, icon stage 3 with overland springs, warn semihide front bumper, victory 4x4 rear bumper, victory skids front to back, warn 10s evo, sso sliders and roof rack, magnaflow exhaust, procharger d1-sc, nitro 4.56 gears and a whole mess of little bits and bobs.
scratchhax is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 11:46 AM #33
dwib44's Avatar
dwib44's Avatar
Here is a screenshot of one from a YouTube video for those interested.
Victory 4x4 Rear Bumper - 2 Week Impressions-screenshot_20210607-192432-jpg
Old 04-01-2024, 04:23 PM #34
pisunti pisunti is offline
pisunti is on a distinguished road
I've had this rear bumper with the tire swingout and camera relocation for my 5th gen since 2021, I like it, however here are my observations on some negatives:
- Rust and freezing issues with the quick release pin on the arms every winter, I have to disassemble, clean/treat every spring since the pin seizes.
- Latching mechanism is annoying to reach under the tire (more just my preference). Would be better if it was more towards the middle of the bumper.
-Latching lever piece(the one with the rubber handle) is made of a softer material hence its wearing out where it contacts the bumper piece with use and will need to be replace some time soon.
- In case you have to get your spare, disconnecting the camera relocation kit is annoying (should just be an easy 6pin waterproof connector)
- More of a gripe with the backup cam relocation kit than the bumper, the LED that comes is def not waterproof (Already replaced it twice).
pisunti is offline   Reply With QuoteReply With Quote
bolts , bracket , bumper , plate , wheel
Pulled the trigger on a new purchase victory blitz front bumper Mudballz 5th gen T4Rs 12 02-09-2023 05:28 PM
Victory 4x4 Bumper, Warn Winch and Dobinsons UCA Installed ProfessorP 5th gen T4Rs 5 08-27-2019 07:43 AM
2015 project thread (week 1 spod and CBI rear bumper) Tengu 5th gen T4Rs 20 04-14-2016 05:05 PM
Valet curbed my rear bumper on my 2 week old 14 LE. PatrickBateman 5th gen T4Rs 8 09-22-2014 12:54 PM
New Bumper being fabbed this week!!! Pikeman 3rd gen T4Rs 113 12-02-2010 04:16 PM
