11-17-2020, 12:21 PM
SPCs need ball joints. Repair or move on?
These spc uppers were on the 4R when I bought it used years ago. The ball joints in them are toasted and I’m seeing them for about $160 pair.
I’m unsure if I want to just fix them, or go another route. The adjustability of the SPC could be nice, if alignment techs knew what they were doing with them....but they don’t. And the local off road shop never even heard of them. And unfortunately, I can’t do the alignment myself.
So rather than deal with this pita every single time, I’m thinking of just getting some Dobinsons, JBA, or Freedom units (that are just a bit more than the ball joints alone).
I have a two inch lift and run larger wheels & tires so I don't want to put stock UCAs.
What would you guys do?
P.s. I don’t really do any hard wheelin, just absolutely horrible roads and trails.
Reason: Typos
11-17-2020, 03:43 PM
Interesting, I thought for sure somebody would have an opinion on this or had dealt with a similar situation before
11-17-2020, 04:58 PM
I would probably just replace the ball joints. There's got to be an alignment shop near you who can set them correctly. It's really not that difficult. And the cost of new BJs is going to be cheaper than any other option.
11-17-2020, 05:01 PM
Definitely just replace the ball joints and be done.
2014 4Runner TE w/KDSS. Fox 2.5 FRS/2.0 w/ Toytec Superflex. 285 WILDPEAK M/T. SSO Slimline w/ Stage 2. Smittybilt X20 10K. Shrockworks Sliders. SP-9100. VIAIR 444C On-Board Air. Sprint Booster. DD SS3. BD LP4. Rigid Ditch.
11-17-2020, 06:16 PM
I agree with everyone else. The cost to replace the UCA will be much higher than the ball joints considering much of the work has to be done in either situation. And at a minimum a new set of high caster UCA's would be 3-4 times more than the ball joints.
11-17-2020, 07:13 PM
Many aftermarket UCA's are designed so you can replace the ball joints. It's a wear and tear part.
11-18-2020, 04:16 PM
SPC is a huge company, they make quality OE and aftermarket parts and also work closely with mechanics and alignment shops. you should be very weary of a shop that hasn't heard of them
just replace your ball joints but more importantly find a better alignment shop
11-18-2020, 04:30 PM
I agree with all of you about the costs.
The alignment is a problem though. I have called the "off road" shops around here (all two of them lol), and countless shops scattered around in this tiny state (I've been in RI for 48 years), and no one seems to understand the configuration of these UCAs and how the caster can be adjusted by rotating the balljoint assembly.
So I print out the directions from the SPC website and present it to them when I show up for alignment. This is not ideal.
Not sure what choice I have. Much like tire work, it's just not equipment I have. fwiw, I have been a mechanic my entire life (military and civ) in some form or fashion.
So, with that said, I figured if I got a set of arms with "fixed" caster...it would be easier
Thanks for the help
Reason: Typos
11-18-2020, 04:46 PM
it doesn't seem like it would change your situation since in both cases the shop is not doing anything about adjusting your caster.
it would be worth it to find a shop that's further away and more knowledgeable to get your UCAs rebuilt. that way, when they're apart, you can specify the caster setting you want and ask them to reinstall at your desired setting
11-18-2020, 04:56 PM
Thanks for the help
I have had better luck with big name shops giving me a good alignment than some 4x4 "specialty" shops. Firestone and Big O Tires have been good to me. As far as getting the ball joint set in the correct position for your setup that should be a one time thing. After that all the adjustment would be in the more traditional fashion. As was said, if you are hitting multiple shops that can't adjust standard caster that's crazy.
11-18-2020, 05:50 PM
Real Name: Sparky
Real Name: Sparky
If they're the older two piece SPC UCAs, those were prone to breaking so I'd replace them.
Old and (c)rusty.
11-18-2020, 05:55 PM
I dont use them, but the dobinsons and Icon UCAs have a protected ball joint. It will last longer, not get buggered up with salt ect.
Dobinsons Front Upper Control Arm Kit (UCA's) for Toyota FJ Cruiser, 4 – Dobinsons Direct
must be lifted to use these...
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
11-18-2020, 06:00 PM
Originally Posted by badattitude
If you grease the SPC ball joint every oil change they will be fine.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
11-18-2020, 06:19 PM
The general alignment isn't an issue so much as the setting of the caster with that unique rotation of the balljoint assembly. That seems to baffle techs
It's pretty difficult finding quality mechanics for anything, outside of standard wrenching, around here. There really isn't much of a motorsport atmosphere in this part of the country. I have to drive 3 hrs to the nearest drag strip, 4 to the circle track or road course, off-roading is all but choked off completely, so you have to leave the state for anything legit. Most people think driving on the beach is hardcore lol
So I tend to do all my own work and fabrication. There just a few things I cannot do in my garage. I could align my old jeeps with a tape measure, but that's different ;)
11-18-2020, 06:35 PM
I think these are later than those, but I'm not exactly sure. Like I said, they were on it when I bought it years ago.
Here's a couple picks
