Old 12-01-2019, 06:03 PM #1
Naphit Naphit is offline
Naphit is on a distinguished road
LED Light Bar//Headlight Issue
Hey everyone,
I just recently installed a hidden LED lightbar and ran into an issue. After the install, I realized that when I lock my car, the headlights will not turn off with the car. It is a 2016 TEP. Any help is very much appreciated.
Naphit is offline   Reply With QuoteReply With Quote
Old 12-01-2019, 06:08 PM #2
Soneill's Avatar
Soneill Soneill is offline
Soneill will become famous soon enough
Soneill's Avatar
Originally Posted by Naphit View Post
Hey everyone,
How did you wire the light bar?
2011 SR5 4x4, Toytec Ultimate w/ SPC UCA's, Shrockworks Front Bumper, 285/70/17 BFG KO2, NFAB Steps
Soneill is offline   Reply With QuoteReply With Quote
Old 12-01-2019, 06:11 PM #3
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
I am guessing you used the headlights as a hot trigger for a relay. Probably should just wire it up separately.
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
Old 12-01-2019, 11:58 PM #4
I wired the light bar using a mictuning wiring harness directly to the battery and then to the switch.
Old 12-01-2019, 11:59 PM #5
I'm a complete noob when it comes to electrical. I don't know exactly what you mean but I wired it on its on directly to the battery.
Old 12-02-2019, 01:15 AM #6
mailbox mailbox is offline
mailbox is on a distinguished road
Are you saying the switch doesn't work? If it's wired directly to the battery and a switch in the circuit why would turning the car on or off do anything to the led bar
mailbox is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 12:42 AM #7
The switch works fine but ever since I installed the led light bar, if I were to leave my headlights in the on position > turn off the car > then try to hit the lock button, my headlights will not turn off.
Before the installation, the headlights would turn off when I hit the lock button on the key. Now it doesn't
Old 12-03-2019, 11:47 AM #8
mbumpus11's Avatar
mbumpus11 mbumpus11 is offline
Real Name: Bump
mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about
mbumpus11's Avatar
Real Name: Bump
Does your in-cabin lightbar switch have a light/is it backlit so that it lights up when your lightbar lights up?
If so - did you use a t-tap to hack into a hot wire (utilizing the headlight wiring circuit) to make that switch light up?
If so - you could've created a false "hot" which could be making your headlights think they are supposed to stay on. Check into that.
Otherwise, if that's not what you did, I'm not sure why your headlights would stay on when the car turns on. I have a lightbar in my grille, wired it directly to the battery and to an in-cabin switch (backlit switch at that), and don't have this issue.
Let us know!
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
mbumpus11 is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 12:14 PM #9
HanginInUtah's Avatar
HanginInUtah HanginInUtah is offline
Real Name: Ben
HanginInUtah will become famous soon enough HanginInUtah will become famous soon enough
Real Name: Ben
Was that with hitting the lock button once, or twice? Mine does not shut off the headlights immediately unless I hit the button twice. I believe if you lock it once the lights will turn off after a wait time, but I'm not 100% sure about that.
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
HanginInUtah is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 01:15 PM #10
IanB's Avatar
IanB IanB is offline
IanB has a spectacular aura about IanB has a spectacular aura about
IanB's Avatar
Need to hit the lock button 2X to shut the lights off, just wanting to make sure you're doing it right. If the lightbar is wired direct to the battery, it should have no effect on how your headlights function.
'93 Toyota LandCruiser VX Ltd 4.2TD - 3X e-lockers, winch, factory fridge, 285/75/16E Duratracs, ICON Stage 1 3" lift, GTurbo Grunter Extreme
'04 Lexus GX470 Ultra Premium - Dobinsons 2F/1R lift, Tandem 612's w/ 265/70/17 Wildpeaks, XD HID lows
'15 Lexus GX460 - FJC 6-spokes w/ 265/65/17C Duratracs Weathertech HP & Canvasback liners
'15 4Runner Limited - 1" Cornfed level, 255/75/17SL Duratracs on FJC 8-holes, XD HID lows, Sprint Booster, Canvasbacks & Husky Liners - SOLD
'96 Toyota Hilux Surf SSR-G 3.0TD RIP - 265/75/16C Duratracs, '99 tall fronts, OME 906's rear
IanB is offline   Reply With QuoteReply With Quote
Old 12-03-2019, 03:49 PM #11
mlnhtrang's Avatar
mlnhtrang mlnhtrang is offline
mlnhtrang is on a distinguished road
mlnhtrang's Avatar
i doubt the light bar has anything to do with the headlights if its wired directly to battery. And like the others said, you gotta hit lock twice or once and wait like 20 secs before headlight turns off.
2018 T4R TRD Off-Road Premium w/ KDSS - Super White
mlnhtrang is offline   Reply With QuoteReply With Quote
car , issue , led , lock , tep
Headlight issue. Help me out here. sport05 3rd gen T4Rs 4 05-19-2015 07:50 PM
Headlight Issue bzettler83 4th Gen T4Rs 1 01-29-2015 06:55 PM
Headlight Issue dreamali80 3rd gen T4Rs 8 02-11-2011 03:04 AM
Headlight wiring issue Awz Classic T4Rs 2 10-28-2010 10:39 PM
Very odd headlight issue MadMaxx 3rd gen T4Rs 0 07-29-2006 04:40 PM
