Old 02-25-2021, 09:23 PM #286
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough
Real Name: Jason
Originally Posted by Saturnine90 View Post
I agree. At first I thought it was probably a placebo effect but it feels a little more controlled but still plush if that makes any sense.
x2. I’m very pleased with the ride characteristics. Now for Eibach to finish the spring redesign.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 02-27-2021, 12:54 PM #287
mnelson71ss mnelson71ss is offline
mnelson71ss is on a distinguished road
Just installed the Fox TRD Pro Shocks on my 2021 TRD OR. The kit is PTR61-89210. The shocks are identical to those on the 2021 TRD Pro. Sadly, the driver’s side rear is making the noise / clunk which is very noticeable below 50F. This was not an inexpensive upgrade. I’m with a few others who are thinking it might be the lower shock bushing rather than the internals. It sounds and feels like a loose shock to me.
AZ Mike - 2021 4Runner TRD Off Road - KDSS
mnelson71ss is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 01:25 PM #288
MGordo MGordo is offline
MGordo has a spectacular aura about MGordo has a spectacular aura about
The model of shock that you bought isnt the one that had issues clunking.. my guess is its something else. (If you did in fact buy the 2021 version.. I didnt cross check the part numbers)
MGordo is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 01:40 PM #289
bowenarrow bowenarrow is offline
bowenarrow is on a distinguished road
My 2020 clunks occasionally when cold. When the fluid warms up it goes away.
2000 Millennium Silver 4Runner SR5, Sonoran Steel 7.2 Lift
2020 Magnetic Grey 4Runner TRD PRO, Westcott Designs Lift
bowenarrow is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 01:46 PM #290
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
The whole issue with the 19 and 20 fox shocks was in the FRONT shocks. here is a link to the TSB
https://static.nhtsa.gov/odi/tsbs/20...81779-9999.pdf
I have verified this TSB with my dealer so I know its legit. The part numbers listed on the TSB differ from your "kit" as they are likely individual parts and not a "kit".
IF you having issues with the rear, then it may be an installation issue. (not to say they could have a defect).
According to my dealer parts counter, the REAR shocks on a 20 and 21 are the same part number. So I think only the fronts were changed.
lewdog998 is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 02:39 PM #291
ProLee's Avatar
ProLee ProLee is offline
ProLee will become famous soon enough ProLee will become famous soon enough
ProLee's Avatar
With all the horror stories about the dealerships I actually have a positive one recently. About a couple weeks ago while I was changing my oil I noticed that my driver side axle boot was leaking grease. Took it in and the mechanic was able to replace the entire axle under warranty, not just the boot itself.
Then when I went back to pick it up the truck he brought up this TSB and told me to bring the truck back before the warranty expires so he can swap them out for me too. No explaining and no BS with getting this TSB completed, I think I found a great tech and dealership.
Only reason why I'm holding off at the moment is I already have the Eibach springs on the original set and waiting for the new ones to be made so I can get it done at the same time.
ProLee is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 03:24 PM #292
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
Do these shocks have solid lower mounts -- spherical bearings -- or rubber? If rubber, than it's not as likely that it will make the noise. Make sure you recheck torque.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 03-02-2021, 03:27 PM #293
Performance shocks tend to do that. Kind of a trade off one makes to gain that performance; the NVH has to increase most of the time. I don't have the OEM Fox shocks, but do have aftermarket units that also get clunky when cold. It's especially noticeable when it's below zero F. Took me some time to get used to that, for sure.
Old 03-02-2021, 04:09 PM #294
For sure. All my performance cars with aftermarket suspension were noisy when cold. Certainly a trade off.
Old 03-22-2021, 08:30 PM #295
dcguy dcguy is offline
dcguy is on a distinguished road
I learned about this TSB recently and decided to take my 2020 TRDP to the dealer (DARCARS Silver Spring Toyota, MD). I gave them a copy of the bulletin.
They kept the car for a day and were unable to reproduce the issue as the weather has been warming up. They told me to “bring it in next winter” to have it looked at then.
I’m going to try calling another dealer or maybe reaching out to a regional manager if I can find the contact info as this noise is very evident on my 4Runner when the weather is cold.
dcguy is offline   Reply With QuoteReply With Quote
Old 03-22-2021, 09:47 PM #296
Nliiitend1's Avatar
Nliiitend1 Nliiitend1 is offline
Nliiitend1 is on a distinguished road
Nliiitend1's Avatar
This was basically my situation a year ago with my 2019.
Took it back this year in February during one of the coldest weeks of the year and they called me later the same day to tell me they were ordering new shocks but that they were backordered so it may take awhile.
About 3 weeks later they finally came in and were replaced. It really hasn't been cold enough to fully test things and *know* that they problem is fixed but so far so good, and the truck's front end also feels a bit better damped (I don't really think it's my imagination but I'm not discounting the possibility).
Nliiitend1 is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 11:58 PM #297
Redsoxx1918 Redsoxx1918 is offline
Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough Redsoxx1918 is a jewel in the rough
TRD Pro Fox Shock Clunk
Here's a pic I found of the 19/20 shock vs the redesigned "21" shock. After I had mine done, I crawled underneath to make sure they replaced them with the proper updated shock.
Redsoxx1918 is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 07:54 AM #298
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
I think I'm having the clunk. Happens only at slow speeds and I mostly notice in my parking garage. I love my 4R, but I know at the moment there is no way a dealer with be able to replicate it unless they drive in my parking garage. I don't know if I have the energy to deal with it. I might just sell the 4R and take advantage of all the crazy prices and the amount of equity I have in it.
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 09:05 AM #299
All depends on your dealership. Mine only did it in the cold weather so it'll be a tough time of year to replicate it. Print up the TSB and take it with you to the dealership. My dealership didn't give me any problems and agreed to do the swap right away.
Old 09-28-2021, 12:46 AM #300
KMAN4190 KMAN4190 is offline
KMAN4190 is on a distinguished road
2021 trd pro clunk
Hello I don’t post here much but I have the same issue with a clunk. I have a 2021 TRD PRO with 3000 miles on it. I started noticing a clunking sound which you can slightly feel on the floor board when driving over small bumps or uneven pavement. I was reading that this seems to be an ongoing issue. I had a 2017 TRD OFF-ROAD AND A 2021 venture edition before going for the PRO. Neither had any clunks. Kind of bummed on this. What is the final answer if there is one ? Thanks
KMAN4190 is offline   Reply With QuoteReply With Quote
boards , fox , notice , pro , trd
Steering clunk... clunk over hard bumps kruegs 3rd gen T4Rs 30 12-12-2017 03:50 PM
Do LC shock bushing match stock lower shock bushings?? Jc12 3rd gen T4Rs 2 04-10-2012 07:54 PM
Clunk clunk down the road ALt4r 4th Gen T4Rs 9 12-19-2008 08:36 PM
