Old 12-21-2019, 06:08 PM #46
fr4c fr4c is offline
fr4c is on a distinguished road
Tons of inputs here since I posted, really glad I'm not the only one. I'm 50/50 about the posted bulletin from Toyota, especially if they knew about it. Whether or not there will be a fix, only time will tell.
Just to confirm that this is a temperature issue, I'm here in Atlanta for the holidays visiting family. Temperatures was mid 50's and the truck was silent. Maybe I should just stay here...
2019 Voodoo Blue TRD Pro
fr4c is offline   Reply With QuoteReply With Quote
Old 12-21-2019, 06:31 PM #47
ForRun ForRun is online now
ForRun is a glorious beacon of light ForRun is a glorious beacon of light ForRun is a glorious beacon of light ForRun is a glorious beacon of light ForRun is a glorious beacon of light
Thought I read somewhere the 20s are fine. Mine has not done it yet. If so ask the dealer for new shocks/ struts?
Rig - 20 orp, stock for now
ForRun is online now   Reply With QuoteReply With Quote
Old 12-21-2019, 09:57 PM #48
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R will become famous soon enough
Real Name: Jason
Tough to say. My dealership said that it was a known issue and their expectation was resolution for the 20s during assembly, but I think I saw a few posts from people with 20s.
Hopefully Iíll have something to report before NYE. At least for 19s.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 12-22-2019, 12:31 AM #49
Chett Chett is offline
Chett is on a distinguished road
Yeah. 3 posts with the Ď20ís doing it as well. So apparently itís not fixed. My wifeís actually started doing it when it was in the low 50ís, high 40ís here. It only gets worse the colder it gets. It does get a bit better after itís driven but it doesnít go away.
Chett is offline   Reply With QuoteReply With Quote
Old 12-22-2019, 09:58 AM #50
honda250xtitan is a jewel in the rough honda250xtitan is a jewel in the rough honda250xtitan is a jewel in the rough honda250xtitan is a jewel in the rough
you are upset your high performance shock makes noises? must be rough owning a TRDBRO... /troll
2016 TE : Grocery Getter, 285/70R17 K02's, Prinsu Rack, 6112, T13, Fox 2.0, DirtKing Fabrication
2017 F250 6.7: ICON, BajaDesigns, DIY Retrofit headlights
Old 12-22-2019, 10:44 AM #51
BadTrainDriver BadTrainDriver is offline
BadTrainDriver will become famous soon enough
Exactly!!
BadTrainDriver is offline   Reply With QuoteReply With Quote
Old 12-23-2019, 01:55 PM #52
MGordo MGordo is offline
MGordo will become famous soon enough MGordo will become famous soon enough
I had Icon 2.5 ET coilovers on my previous GX and they didnt make any sounds... while its not super loud or super consistent, its not something you want from a brand new vehicle.
MGordo is offline   Reply With QuoteReply With Quote
Old 12-23-2019, 06:54 PM #53
AMLOR AMLOR is online now
AMLOR is on a distinguished road
Ok, mine don't make noise; at least none I can hear over the tire noise, wind noise, and the JBL stereo....
The question is: Do the shocks DO what they are supposed to? Mine do.
Is the "noise" a problem, or is it just a characteristic of the Internal Bypass system Fox uses. Raptor guys also hear shock noises. Same type shock; same noises...coincidence? I think not. that doesnt make them "bad".
As long as the shocks DO what they are designed to, turn up your stereo and enjoy the PRO.
2019 TRD PRO - Victory 4x4 alum. Blitz bumper/Smittybilt 12K,
Factor 55, Bubba Rope, Van Beest, Overland Vehicle Systems, Whiteline Poly Bushings, C4 Fab, BPF, M.O.R.E., Power Tank, Xenon Depot, Cali Raised, ARB, SPC UCA's, Rad Rubber, Metal Tech 4X4 Rear UCA & LCA, Eibach Load -Leveler rear spring set.
Waiting on Eibach to finish the TRD FOX front spring set...
AMLOR is online now   Reply With QuoteReply With Quote
Old 12-23-2019, 11:12 PM #54
I get what your saying. Honestly. But the problem I have with that reasoning is at what point do you draw the line?
Your brakes squeal everytime you use them. Don’t worry. They’re working fine. Doing what there supposed to be doing. Just a characteristic of these new high performance brakes we’re using. Only does it when it’s cold. Do you draw the line then?
Your a/c compressor makes weird noises. Don’t worry. It’s working as intended. Just this new high performance compressor we’re using. It’s a characteristic. Nothing to worry about.
Transmission makes a loud clunk everytime it shifts. Don’t worry. New transmission we’re using. Just a characteristic of this high performance transmission. It’s working fine. Only does it in cold weather. No worries.
You get what I’m saying?
Old 12-23-2019, 11:22 PM #55
crawler78 crawler78 is offline
crawler78 is on a distinguished road
Iím actually the guy that posted months ago first about this issue and am a still fighting Toyota about it. I got my pro back in February and lived in South Dakota. It was actually a blizzard the weekend I got it and with neg 0 temps regular within two or so months heard it. It actually started after I was off roading and was fine for the first two months. Itís sounds more like a blown sway bar bushing but you can actually feel the floor board on the passenger side move. It was so bad passengers would hear it on the bumps from ice on the road and ask whatís wrong with the rig. I started a case with Toyota and am pretty sure I drove them crazy calling every week to find out when they would fix it. At the time only three reported cases and all from the same regional tech. I also called Fox and talked to them about it and they were not happy Toyota blames the shock. Iíve had many stories told to me from Toyota techs that itís hard to believe any they say. They even told me that Toyota rushes the shock out for 19 and used the Tacomaís settings that clearly isnít correct for the 4runner and they just need to figure out the tuning.
Iím moved now to Mo and let the dealer here look at it in hopes of fixing it. They tried to order a new shock and Toyota blocked it saying itís a know issue with the Pro and will not replace them. Iím sorry but my alignment goes off very often and has to be reset, any low speed bump is a hollow thump at any temp so the low temp only makes it worse and noticeable. You can feel it on the floorboards at lower temps. I even considered trading it on a 2020 today while there and of course they want to give a low ball for them as expected. This isnít my first 4runner or off road truck, but Toyota messed it up and clearly doesnít care about making it right.
To the guy that said tune the taboo up btw, the thing was so loud youíd blow your speaker. Also at highway speeds the truck was becoming unstable. This isnít a flaw. Itís a f..k up. You donít drop that kind of coin to put up with shot Warrenty and customer service.
crawler78 is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 09:05 PM #56
Your brakes squeal everytime you use them. Donít worry. Theyíre working fine. Doing what there supposed to be doing. Just a characteristic of these new high performance brakes weíre using. Only does it when itís cold. Do you draw the line then?
Your a/c compressor makes weird noises. Donít worry. Itís working as intended. Just this new high performance compressor weíre using. Itís a characteristic. Nothing to worry about.
Transmission makes a loud clunk everytime it shifts. Donít worry. New transmission weíre using. Just a characteristic of this high performance transmission. Itís working fine. Only does it in cold weather. No worries.
You get what Iím saying?
Absolutely I do. There was a certain amount of sarcasm in the above post...
That said, when you read a post like Crawler 78's issue, that definitely needs to be shoved in Toyota's collective in box until you get some kind of resolution.
My .02 on Crawler's issue sounds like way more than a shock noise, sounds like something that is supposed to move isn't OR something that is not supposed to move is...The 4Runners are notorious for frozen adjusters on the LCA's. I would be surprised if that was connected to the noise, but ya never know.
I suppose I was poking a bit of sarcastic fun at the "automotive hypochondriacs" and you just know they exist.
Now as I said, mine are absolutely silent, no noise, no squeak, no thump, cold temps or otherwise. I have even tried to make mine do it after sitting overnight in 23F degree weather. Nada, nothing. Silent as a tomb, dead nuts stable at 80mph.
FWIW a 2019 Pro with 9342 miles and about 6 months old. One of the first mods I did was to replace the sway bar bushings with urethane ones. Super easy and cheap. I was amazed at how soft the stock rubber Toyota ones were, already significantly deformed at 1800 miles. Anecdotal? yes, coincidence...maybe. Food for thought....?
Old 12-24-2019, 10:23 PM #57
Real Name: Jason
Real Name: Jason
I think your entrance to the thread was just bad timing. There were a few troll posts before yours and then your addition just seemed to pile on a bit.
That said, you also came with some additional information regarding part of the suspension youíve replaced. Youíve added value with your insight to the stock bushings, so thank you.
All I know is my courtesy vehicle is a 4R limited and I really donít like it. Even if itís currently out of commission, Iím still happy I chose my Pro over a limited.
Old 12-25-2019, 10:20 AM #58
I fully agree I think mine has something besides the shock issue but Toyota is refusing to let the techs replace anything due to it. I told them the first time I dropped it off I thought the sway bar bushing went out as is reminds me of when they went bad on my past jeeps. Same noise and feels very close to it. They completely torn apart the undercarage in SD and the other day here in MO while having the service the let me come out and look at it with the plate off and check things out. I do want to replace the bushing as well as I know a lot of 4runners had issues with them.
As far as over night I do work 12 hrs rotating shifts and it would be outside in -50 all night and covered in snow. Hell the way home youíd need ear plugs. I asked if I replaced the shocks and it didnít go away if they would do anything. They said theyíd pull them and tell me to send them back for a refund and then keep looking. Wtf Toyota. Iíve never seen the company be such a pain. Normal they have been great with this kind of thing from what Iíve seen
Old 12-25-2019, 10:41 AM #59
Maybe weíre on to something here. Quick search shows similar issues with the sway bar bushings:
Front End Clunk / Sway Bar Bushings
Old 12-25-2019, 03:14 PM #60
I actually was trying to talk them into replacing the sway bar bushings. Like that link said they look and feel right but with them you never really know. They are one of those small things that seem like it shouldnít effect as much as they do Iíve always thought. I really Want mine changed to see if it fixes the issue. Its just a let down from Toyota
boards , fox , notice , pro , trd
Steering clunk... clunk over hard bumps kruegs 3rd gen T4Rs 30 12-12-2017 03:50 PM
Mysterious clunk in driveline (not the clunk you're thinking of) netchemica 4th Gen T4Rs 16 07-27-2014 06:50 PM
Do LC shock bushing match stock lower shock bushings?? Jc12 3rd gen T4Rs 2 04-10-2012 07:54 PM
Clunk clunk down the road ALt4r 4th Gen T4Rs 9 12-19-2008 08:36 PM
